Acom 2000a and SDR
FlexRadio Systems Forums
Acom 2000a and SDR Expand / Collapse
Author
Message
Posted Tuesday, December 12, 2006 8:40 PM
Forum Newbie
Group: Forum Members
Last Login: Monday, February 16, 2009 10:24 AM
Posts: 1, Visits: 51
I have been experiencing a problem with the Acom amplifier going into the protect mode when transmitting with the Flex radio. The amp seeing an arc fault stops transmitting constantly. I have to reset the amp only to have it keep happening every time I transmit. This faulting problem does not occur with any of my other transmitters. The 160 meter band seems to be the common denominator. Has anyone else had this problem and if so what was does to cure the flex. The problem is not with the amplifier. Is there a calibration that can be done to stop this from happening? The SWR is fine and all else looks fine with the panadapter readings and metering.
Post #93
Posted Wednesday, December 13, 2006 12:50 PM
Junior Member
Last Login: Sunday, January 25, 2009 7:08 AM
Posts: 20, Visits: 46
I have no problems with my Acom 1000. I am using the rear SDR1000 db15 connector using pins 7 & 15 going straight to the amp.
Post #95
Posted Thursday, May 10, 2007 8:16 PM
Forum Newbie
Last Login: Friday, May 11, 2007 7:35 AM
Posts: 1, Visits: 5
Do you have any issues with ALC?
I thought the Acom relied on ALC.
I'd hate to blow up my amp (VL1000) solid state amp.
W9OL in Chicagoland
webcams at http://76.16.160.118:8080
weather at http://hhweather.webhop.org
Post #285
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 9:57am
Powered By InstantForum.NET v4.1.4 © 2018
Execution: 0.047. 7 queries. Compression Disabled.
