15 meter High SWR faults .. fixed
FlexRadio Systems Forums
15 meter High SWR faults .. fixed Expand / Collapse
Author
Message
Posted Saturday, April 19, 2008 6:03 PM
Supreme Being
Group: Forum Members
Last Login: Thursday, October 25, 2012 10:13 AM
Posts: 191, Visits: 505
For some time PSDR has been giving indications of HIGH SWR on 15 meter band even though external indications were < 1.5: 1. These occurred on voice peaks, or High output CW (tune) > 80 watts. Readings were normal a low power and then suddenly indications of High SWR and several hundred watts output on PSDR with normal readings on external meter.
After some debugging I discovered the that the readings were caused by RF pickup on the digital line running between the PA and the TRX board. This signal is routed in a multiconductor shielded cable between the PA and the RFE board and then a single unshielded wire from the RFE board (J3) to the TRX board. Replacing the unshielded wire with a shielded wire grounded at the RFE J3 connector solved my problem.
Al, K0VM
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #748
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 4:49am
Execution: 0.016. 6 queries. Compression Disabled.
