Posted Friday, August 16, 2013 12:32 PM |
Forum Newbie
Group: Forum Members
Last Login: Friday, August 16, 2013 2:18 PM
Visits: 2
The tracking notch filter is very effective once it is set.
How does one make fine adjustments to the width and center frequency of a filter?
I have expanded the display and zoomed in as much as I can.
Width - When I left click on the filter, and want to make a small width adjustment (say from 20 Hz to 25 Hz), generically the "expanded display" pops up (in 1 second), and then I am unable to adjust the width. If I am fast enough to successfully get the width adjusted, I have moved the center frequency of the filter.
Center Frequency - Even on the "expanded display" pop-up, moving the slider left and right to adjusts the center frequency in steps of 8 or 10 Hz - it seems to vary.
Has anyone else encountered this issue?
I am thinking a pop-up window that allows the user to manually enter text to change the settings would be nice.
Bob, WB8ILI
Posted Monday, September 16, 2013 3:02 AM |
Junior Member
Last Login: Monday, October 21, 2013 1:45 AM
Visits: 21
I also get this problem, but have suggest a change to flex for the notch filter, which I hope they will introduce in the next software version update.
