Heil Proset-6 headset with FLEX-3000
FlexRadio Systems Forums
Heil Proset-6 headset with FLEX-3000 Expand / Collapse
Author
Message
Posted Saturday, August 3, 2013 1:56 PM
Forum Newbie
Group: Forum Members
Last Login: Wednesday, February 24, 2016 1:56 PM
Posts: 2, Visits: 6
 I am trying to get my Heil Proset 6 headset to work with my FLEX-3000, on the mic boom it is marked "HC 6", not sure if this is the mic element or not.
 It appears the mic can't drive the FLEX-3000, with a dummy load connected and the mic gain all the way up, I get very slight movement on the meter and very little audio on the 'monitor' output when I tap the mic element., and I know max gain is not a good thing with DAC.
 When I use this headset with my Kenwood TS-850S, I have to have the 'Processor' enabled and also adjusting the mic gain.
 The hand held mic that came with the FLEX works fine, but I am used to a headset for hands free operation.
 If I need to change out the mic element, any good choices?
Warren Greenberg AE4WG
Post #6743
Posted Sunday, August 4, 2013 10:11 AM
Forum Newbie
Posts: 2, Visits: 6
 Problem solved.
 I had a bad crimp on my male RJ-45 connector, causing an open on one of the mic leads, new CAT-5 cable, and now I have mic signal into the FLEX-3000.
 I will now be doing the MIC/Mixer/ALC/.... setup and building the profile for the Heil.
Post #6747
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 9:40pm
Execution: 0.047. 11 queries. Compression Disabled.
