Flex 1500 with Win8 Tablet
FlexRadio Systems Forums
Flex 1500 with Win8 Tablet Expand / Collapse
Author
Message
Posted Saturday, July 20, 2013 10:29 AM
Forum Newbie
Group: Forum Members
Last Login: Saturday, July 20, 2013 10:26 AM
Posts: 6, Visits: 13
Is anyone using a Flex1500 with a Win8 tablet? I cant get the usb driver to load properly. Have gone through the uninstall and install process to no avail. Could be these drivers are just not suitable for WIN 8 - would appreciate a comment on this.
Post #6724
Posted Monday, July 29, 2013 12:30 PM
Forum Newbie
Last Login: Tuesday, September 3, 2013 11:17 AM
Posts: 4, Visits: 69
I have connected my Surface Pro running Windows 8 Pro to the Flex 1500. Drivers from the Power SDR installed without issue. I did several QSOs using digital mode (HRD) and all worked. I used VAC plus vspMgr and HRD version 6.
Post #6740
Posted Tuesday, August 13, 2013 1:06 AM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
You should not have any problem with Win8 , unless you did not wait long enough for all the drivers to load for the radio.. I suggest that you disconnect the radio and power down the slate, then power it up and reconnect and power up the radio, be sure to wait at least 3 or 4 minutes for all the drivers to load, you should see a Ready to Use message.. If still fails, remove the radio and remove PowerSDR and the USB driver. REBOOT the computer before reloading. After the computer is completely rebooted after the second reboot, then reconnect the radio and wait.. There are 5 drivers that have to load initally and after that there are 4 that load if you move to a different USB port.
If you still are having issues , then contact the FlexRadio Help Desk, http://helpdesk.flexradio.com
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
Post #6781
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 3:28am
Execution: 0.016. 9 queries. Compression Disabled.
