1500 has clicking sound on headphone output
FlexRadio Systems Forums
1500 has clicking sound on headphone output Expand / Collapse
Author
Message
Posted Monday, March 4, 2013 9:09 PM
Forum Newbie
Group: Forum Members
Last Login: Saturday, November 18, 2017 7:32 PM
Posts: 2, Visits: 3
I get a light clicking sound out of the headphone output no matter where the audio levels are set. The level of the clicks stay the same. I can mute everything and the click is still there. I used a couple of different receivers to amplify the audio and it didn't help. If I change the receiver audio input it goes away. It is coming from the 1500 unit. It is a random pattern of clicks not any further apart then a few seconds. Some times there will be a quick string of 3 or 4 clicks. Clicks or ticks would be a good description of the sound. If I stop the radio while it is still powered up, it goes away.
Thanks for any help and info
Post #6432
Posted Friday, March 8, 2013 4:24 AM
Forum Newbie
Last Login: Friday, March 8, 2013 4:22 AM
Posts: 1, Visits: 1
Otto - cant be any help Im afraid but have exactly the same problem on 5000A - also looking for answers
M0BPS
Post #6436
Posted Saturday, March 9, 2013 4:58 AM
Junior Member
Last Login: Tuesday, March 19, 2013 4:10 AM
Posts: 12, Visits: 17
Try running totally shutting down your home power (at the main circuit breaker) and running your rig from a battery.
If the noise goes away then your QTH is generating the noise.
...and then have fun setting all those clocks and things....
Post #6439
Posted Wednesday, March 13, 2013 4:59 PM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
Make sure that you are using a stereo plug or not shorting one leg to ground or together.. This can cause an overcurrent in the internal chip and a constant clicking.. Also if the headset is too low an impedance , this will cause high current and overloading also...
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #6455
Posted Thursday, May 9, 2013 1:27 PM
Forum Newbie
Last Login: Thursday, May 9, 2013 8:04 PM
Posts: 1, Visits: 2
Exactly the same problem appeared at my Flex1500 when upgrading from 2.06 to 2.64. I am using stereo phones, problem with cw monitor delay is now solved, but new audio srcatches becomes very naughty.
73, Niko 9j3a
Niko, 9j3a
Post #6582
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:56pm
Powered By InstantForum.NET v4.1.4 © 2018
Execution: 0.047. 10 queries. Compression Disabled.
