TX Power output when running JT-65
FlexRadio Systems Forums
TX Power output when running JT-65 Expand / Collapse
Author
Message
Posted Wednesday, February 13, 2013 1:29 PM
Forum Newbie
Group: Forum Members
Last Login: Friday, February 15, 2013 8:10 PM
Posts: 2, Visits: 2
Wondering how much power it is safe to run when running JT-65. Also curious, WJST manual specifies no AGC - set AGC to "fixed" to turn it off? Manual is a little vague.
Tnx
Post #6387
Posted Thursday, February 14, 2013 5:34 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Friday, May 9, 2014 11:20 AM
Posts: 38, Visits: 119
I use both a 1500 and a Flex 3000 on JT65HF on the upper top right corner the TX Meter tick on it bring up ALC meter. The meter should read 0 or -1 but never above 0 no +1 you'll shorten the life of the rig.
Now when in transmit, the VAC TX GAIN to left of the filter the bottom slider used read "0" or "-0" or maybe lower.
You don't need more than a couple watts to maybe ten watts to work the world on this mode
One other thing in any mode digital mode the VAC RXGain should be -5 to -10
Hope that helps
I you need more help or screen shots of setup email me . email is correct on QRZ
73 Jim
W4WWJ
Jim W4WWJ
Post #6390
Posted Friday, February 15, 2013 8:13 PM
Forum Newbie
Posts: 2, Visits: 2
Jim,
Very useful. And pretty much the same operating parameters as PSK and the other digital modes - duh!
Thank you for your quick response.
John, K4SQC
Post #6394
« Prev Topic | Next Topic »
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 9:58pm
Execution: 0.031. 10 queries. Compression Disabled.
