Rec/Play Feature Problem
FlexRadio Systems Forums
Rec/Play Feature Problem Expand / Collapse
Author
Message
Posted Tuesday, February 12, 2013 10:24 PM
Junior Member
Group: Forum Members
Last Login: Tuesday, March 19, 2013 4:10 AM
Posts: 12, Visits: 17
The Rec button on the front panel works as described. It records the audio from the Mic and generates the specified .wav file. When I open the file in Windows, it has the recorded audio.
When I press MOX + Play, there is no rf modulation. The play light stays on for the duration of the audio and then turns off. No RF modulation can be seen on the Scope or on the Watt meter. What am I missing?
Post #6386
Posted Thursday, February 14, 2013 4:16 AM
Junior Member
Problem solved. I was using VAC1 to listen to the radio. Turning VAC1 off, for some reason, allows the voice recording to modulate the RF.
Post #6389
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 9:46pm
Execution: 0.047. 11 queries. Compression Disabled.
