Recording on Flex 1500
FlexRadio Systems Forums
Recording on Flex 1500 Expand / Collapse
Author
Message
Posted Wednesday, February 6, 2013 10:07 AM
Forum Newbie
Group: Forum Members
Last Login: Wednesday, February 6, 2013 10:03 AM
Posts: 7, Visits: 12
I am an avid broadcast band listener and would like to record what i hear for future use and to "pass on" to other Dx'ers......
The built in recording feature does not allow very long broadcasts to be be recorded, and they are in .wav format which is a huge file system.
does any Flex user have any suggestions for me please?
many thanks.....
Steve. UK.
Post #6377
Posted Thursday, February 7, 2013 3:00 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Wednesday, September 25, 2013 11:09 AM
Posts: 38, Visits: 151
Hi Steve use an OGG Vorbis recorder like this: http://www.blazemp.com/ogg_recorder_software.htm to make records in smaller dimensions. You have to use VAC and you can set it up in the recorders control center.
73´s
Call: DF5WW (Class A) ... OP: Juergen (Joe) .... Rig: Only QRP with Flex 1,5k and 2 x 25 m folded doublet with balance feedline for all bands (under the roof). Also a 10,3 m Quadloop for 10 and 6 ... feeded with ladderline too and also under the roof.
Post #6383
Posted Monday, February 18, 2013 2:25 PM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
Steve,
One suggestion is to run a double male stereo 1/8" cable from the headphone jack to your sound card input. Then use a program to record the audio as a MP3.. Yo can also set VAC1 "Output" to the SoundMapper and record that way, but the internal volume and mute will not function, then set the program to the SoundMapper.
One program that can record direct to MP3 is Audacity
http://audacity.sourceforge.net/
Another I really like is Audio MP3 Editor
http://www.audio2x.com/ameditor/index.htm
Easy to use
Hope this helps.
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #6398
Posted Tuesday, August 13, 2013 12:54 AM
Supreme Being
Steve,
As mentioned you can use VAC to send the audio to a recorder, like MP3 Editor or Audacity , both free. or you can just use the built in WAV recorder, but set it to simple wave recording so that it doesn't take so much space. Set the options of Wave recorder to Post Processed , RX (audio in ) and Pre Processed for TX , or radio buttons to the "inside" on the Wave , Options menu.. Then use these programs to convert from wav to mp3 or use VAC and record direct.
MP3 Editor
http://download.cnet.com/Free-MP3-Editor/3000-2170_4-75685443.html
Audacity -
Hope this helps.
Dudley
Post #6779
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 3:11am
Execution: 0.078. 11 queries. Compression Disabled.
