Flex 3000 : no receive
FlexRadio Systems Forums
Flex 3000 : no receive Expand / Collapse
Author
Message
Posted Monday, January 28, 2013 5:46 AM
Forum Newbie
Group: Forum Members
Last Login: Thursday, May 30, 2013 9:00 AM
Posts: 9, Visits: 21
The flex 3k was working fine.
This morning, i had no receive..on any band
The BNC leads measures 2ohms (with my cheap multimeter...so i question accuracy) across
I can run the ATU
I can then send out a 10W tune w/no reflected power..so no Tx issues?
I used the antenna analyzer (MFJ 259B) and it shows resonance points (X=0, R=whatever) at various bands
as it should.
What am i missing here?
jim
Post #6329
Posted Tuesday, February 5, 2013 11:48 AM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
Are you not get receive audio or no signals in the panadapter?
No receive audio but seeing signals in the panadapter may point to a FireWire compatibility issue. Not all the threads are getting started.
No signals in the panadapter may be a fault in the T/R relay.. Trigger the PTT quickly several times to see if this will free up the T/R relay in the radio. If you are using an amp, try putting the antenna directly to the radio and not through you amp or other switches..
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #6373
Posted Tuesday, February 5, 2013 11:53 AM
Forum Newbie
Hi Dudley
This was solved on the phone with you
Everything works now.
thanks
jim
Post #6374
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 9:27pm
Execution: 0.047. 13 queries. Compression Disabled.
