Rcvr frequency marker in display
FlexRadio Systems Forums
Rcvr frequency marker in display Expand / Collapse
Author
Message
Posted Sunday, January 20, 2013 11:30 PM
Junior Member
Group: Forum Members
Last Login: Tuesday, March 19, 2013 4:10 AM
Posts: 12, Visits: 17
The vertical line that shows the Rcvr (and Xmit) frequency appears about 3/4 of the way to right of the Panadaper display. Is there any way to get this line (and function) to move to the center of screen?
Why is it so far to the right and not in the center to start with?
Also, Pan slider does nothing. What's up with that?
Post #6312
Posted Monday, January 21, 2013 4:48 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Friday, May 9, 2014 11:20 AM
Posts: 38, Visits: 119
Looking at the screen see the drive slider below that is the SQL slider to the right of that is a very long slider  left side label PAN right side label CENTER move that slider to the left or right should solve your problem,
Jim
Jim W4WWJ
Post #6313
Posted Wednesday, January 30, 2013 3:29 AM
Junior Member
That slider does even begin to have an effect until the zoom slider is moved about 1/3 of the way to the right.
At that point you can move the rcv window around inside the zoomed in window. Zoom back out and the window is still 3/4 of the way to right.
Post #6347
Posted Wednesday, January 30, 2013 6:59 AM
Forum Member
On your main display where the NR NB buttons are the SR button is tick it on and off this will also move the center display from left to right.This is also part of your filtering system. I am using version v2.5.3 so not sure how this works on older version. Pages 73 and 103 of the manual tell about this button .
Also from setup General Options you can also tick this feature on off (called Spur Reduction.
73 Jim W4WWJ
Jim W4WWJ
Post #6349
Posted Sunday, February 3, 2013 2:27 AM
Junior Member
The SR button moves the window left or right by a whole 0.005 kh.
What, exactly is Spur Reduction?
Post #6361
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 8:04pm
Execution: 0.047. 12 queries. Compression Disabled.
