DRM
FlexRadio Systems Forums
DRM Expand / Collapse
Author
Message
Posted Wednesday, December 12, 2012 10:31 AM
Forum Newbie
Group: Forum Members
Last Login: Wednesday, February 6, 2013 10:03 AM
Posts: 7, Visits: 12
Hi Everyone.
I would appreciate any advice in getting my Flex 1500 set up to receive DRM broadcast transmissions. I primarily purchased my Flex 1500 to listen to the HF BC bands.
Any help/advice on obtaining software would be appreciated.
Many Thanks.
Steve. UK.
Post #6224
Posted Wednesday, December 12, 2012 10:50 PM
Forum Newbie
Last Login: Sunday, August 18, 2013 5:41 PM
Posts: 8, Visits: 21
Howdy,
I fire it up every once in a great while. It really works quite well!
link to evaluation panel
Here's the worldwide broadcast schedule:
DRM schedule
If you Google "Dream DRM", somewhere you will find the compiled source with the codecs.
The combination Flex(PowerSDR) and Dream will require some robust processing power.
GL
Guy - W6MSU
http://twitter.com/w6msu
Post #6228
Posted Saturday, December 15, 2012 6:23 AM
Forum Newbie
Hi There Guy.
Many thanks for your prompt reply......i shall certainly take a look and report on my findings....thanks also for the DRM schedule.......
73.....Steve.
Post #6237
Posted Wednesday, January 16, 2013 12:25 PM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
Steve,
Here is the Knowledge Center link for setting up DRM . It's showing a much older version of PowerSDR , but the set up is the same ..
http://kc.flexradio.com/KnowledgebaseArticle50353.aspx
Works great if you can get enough signal.. Here in the states, the signals usually are too low for good reception. Takes a good 60 dbm signal and no signal fade for good steady reception.
Hope this helps,
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #6299
Posted Sunday, January 20, 2013 6:13 AM
Forum Newbie
Hi Dudley.....
Sorry for late reply......i will give your recommendation a try.......
Love the Flex 1500 and just to point out i really enjoy using it as my sole RX for BC listening!!!!
I did offer up via the correct channels, a suggestion whereby a record facility (enhanced to the exsisting one) could not use .wav files as they eat up hard drive like a goat.
I have tried to record my BC stations (DX) via the pc out jack whilst using the Flex as the point of output for monitoring, but its just not happening. I am just using the simple "recorder" that i have installed on my pc. Any ideas Dudley as to how i may overcome this minor problem.
Many Thanks again for your your help!!!
73.....Steve. UK.
Post #6309
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 10:19pm
Execution: 3.672. 19 queries. Compression Disabled.
