PowerSDR and firmware installation
FlexRadio Systems Forums
PowerSDR and firmware installation Expand / Collapse
Author
Message
Posted Friday, October 26, 2012 3:17 PM
Forum Newbie
Group: Forum Members
Last Login: Friday, October 26, 2012 2:48 PM
Posts: 1, Visits: 1
When installing PowerSDR 2.2.3 (and 2.0.19-RC1) and get this:
"A radio firmware update is required in order to continue.
(Looked for v2.0.7.2 and found v2.1.3.0)
Would you like to update your firmware now?
If not, PowerSDR will be closed. "
When I click yes, I get this:
" The firmware revision chosen does not meet the requirements of this
version of PowerSDR. Please obtain firmware version v2.0.7.2 and try again. "
The release notes for 2.2.3 says that if I did not have a previous version of 2.x then I must first upgrade to 1.18.6 and associated firmware and drivers. One of the documents says that you use the PowerSDR installer to install firmware to the radio, but if that fails (as it is for me) what do I do next?
Post #6118
Posted Saturday, October 27, 2012 12:10 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Friday, May 9, 2014 11:20 AM
Posts: 38, Visits: 119
You didn't say what kind of computer Laptop or PC. I had that problem I'm using a PC windows 7 64 byte with 8 geg ram . Turn out to be the firewire card was wrong chip set. I was using express pci slot. When I order new card ordered one for a pci slot. Now all works perfect.
SIIG 3-port PCI 1394 FireWire Adapter - 3 x IEEE 1394a FireWire External - Plug-in Card - NN-400012-S8
The card is about $30.00 or less
Jim w4wwj
http://w4wwj.com/flex3000.html
Jim W4WWJ
Post #6119
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 8:18pm
Execution: 0.031. 11 queries. Compression Disabled.
