failed new install
FlexRadio Systems Forums
failed new install Expand / Collapse
Author
Message
Posted Friday, October 19, 2012 7:13 PM
Forum Newbie
Group: Forum Members
Last Login: Sunday, December 16, 2012 7:45 PM
Posts: 4, Visits: 8
New install - just received today. Had running as demo since Tuesday. Order# AB-4946
Followed install guide to the letter
Attempting to start FlexRadio Driver Error: Device is not accessible
PowerSDR first tried to backup eeprom and failed, can't repeat to get error
second and subsequent atempts prompt for Firmware Update, tries then says update complete
Attempted full uninstall and reinstall
Logged in as Administrator with UAC on
SIIG Firewire 1394a PCIe card with Texas Instruments chipset
Post #6091
Posted Monday, October 22, 2012 8:13 PM
Forum Newbie
Posts: 4, Visits: 8
Received following reply from Flex Tech Support
Two suggesions. Win7 machines many times runs better with using the legancy driver instead of the TI driver or the native Win7 FW card driver. So follow this procedure to see if the radio is then recognized.
http://kc.flexradio.com/KnowledgebaseArticle50433.aspx?Keywords=legacy
If the radio still is not being fully recognized, the registry of Windows may be confused with the reinstall, so follow this procedure.
1. Go the the Windows Control , then to Programs and Features.
2. Uninstall the FlexRadio driver 4.0.0.xxxx and PowerSDR 2.4.4 , turn the radio off.,
3. REBOOT <= real important
4. Rerun the PowerSDR 2.4.4 installer.
5. Reboot again .
6. Let the computer completely reboot.
7. Turn the radio on , you should receive a New HW is ready to use measage, but this might take up to 5 minutes..
8. Open the FlexRadio icon on your desktop , see if the 3000 is showing up in the Global Settings window..
Post #6104
Posted Monday, October 22, 2012 8:14 PM
Forum Newbie
Posts: 4, Visits: 8
Tried the above and got following results:
After step 3, I checked Control Panel | Programs and Features and it was removed. however FlexRadio was still in Device Manager.
I Right Clicked | Delete the FlexRadio device and selected delete driver files.
Then rebooted again.
Attempting to run FlexRadio resulted in the following message:
Driver Error: Driver streaming parameter locked.
Check the driver configuration or device connections
Then changed the Firewire driver to Legacy per the KB article and rebooted.
Flex3000 was then visible but attempting to change the radio name from MyProduct resulted in a blue screen.
Going into FlexRadio still showed MyProduct after the reboot but did not attempt to change anything.
Went into PowerSDR and this time is showed the installed FirmWare version (2.0xxx) and prompted to upgrade to 2.1xxxx) Confirmed and got to 9x% and then blue screened again.
Now each time I try to start PowerSDR, I get a Blue Screen with IRQL_NOT_LESS_EQUAL on OHCI1394.sys.
Post #6105
Posted Monday, October 22, 2012 8:16 PM
Forum Newbie
Posts: 4, Visits: 8
Stopped at Frys Electronics and picked up a Belkin Firewire PCIe card
waited for Firewire drivers to install
Started FlexRadio, same result
Switched to Legacy
same result
Started PowerSDR 2.4.4
BSOD
Post #6106
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 1:54am
Powered By InstantForum.NET v4.1.4 © 2019
Execution: 0.031. 10 queries. Compression Disabled.
