Monitor
FlexRadio Systems Forums
Monitor Expand / Collapse
Author
Message
Posted Sunday, September 2, 2012 2:12 PM
Junior Member
Group: Forum Members
Last Login: Saturday, November 17, 2012 12:09 PM
Posts: 14, Visits: 19
Guys
Why this Flex radio 3000 has a big delay while you are monitoring your transmission ?
I can not hear how I am sounding .
TBD
Post #5982
Posted Monday, September 3, 2012 9:19 AM
Supreme Being
Last Login: Sunday, January 27, 2013 2:39 PM
Posts: 86, Visits: 89
It is normal to hear this delay as you will with most radios. the best way to hear yourself is to record your audio then play it back.
Post #5984
Posted Wednesday, September 5, 2012 1:07 PM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
Then monitor latency is the delay of going through the SW to the radio and back again.. You can effect this by the overall speed of the computer system. The actual computer speed, (set your Power Option to High Performance) the Operational mode in the FlexRadio Driver, ( 3000 and 5000 only) your sample rate, higher sample rate is less latency and lower buffer size (again less latency) . The operational mode/Sample/Buffer size is all dependent on the DPCs that are happening with the computer. As you change these, the CPU percentage needed to run PowerSDR will go up..
Hope this helps.
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #5989
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 10:11pm
Execution: 0.047. 9 queries. Compression Disabled.
