Posted Thursday, August 30, 2012 10:51 PM |
Junior Member
Group: Forum Members
Last Login: Saturday, November 17, 2012 12:09 PM
Visits: 19
Hi guys, I'm wondering if I can record somebody on air and then re-transmit (Play the recorded audio on the air)
That way I can show someone else their audio instead of giving a signal report.
If it's possible which program you can recommend me to use.
TBD
Posted Friday, August 31, 2012 7:13 AM |
Forum Member
Last Login: Wednesday, September 25, 2013 11:09 AM
Visits: 151
You only need PowerSDR for recording and playback of audio
See attached picture where do you find the "wave" function ....
Call: DF5WW (Class A) ... OP: Juergen (Joe) .... Rig: Only QRP with Flex 1,5k and 2 x 25 m folded doublet with balance feedline for all bands (under the roof). Also a 10,3 m Quadloop for 10 and 6 ... feeded with ladderline too and also under the roof.
Posted Friday, August 31, 2012 10:04 AM |
Junior Member
Visits: 19
Thanks Juergen, I did this procedure but when play back is distorted, I really don't know what I have wrong on the settings
Also on program POWER SDR the record button works but play is inactive.
TBD
Posted Friday, August 31, 2012 11:57 PM |
Supreme Being
Last Login: Sunday, January 27, 2013 2:39 PM
Visits: 89
Hi I think you are using a Flex radio there.
To record, press rec button and it will record, than press rec again to stop recording. To play back on the air, press mox and than play and it will send what you hear.
Posted Sunday, September 2, 2012 2:09 PM |
Junior Member
Visits: 19
Thank You, for the response.
I just found out the problem. Just downloaded the VAC software and now the player works just fine.
Posted Monday, September 3, 2012 7:10 AM |
Forum Newbie
Last Login: Thursday, September 27, 2012 11:48 AM
Visits: 8
Can you explain to me how to download the vac firmware
Posted Monday, September 3, 2012 9:44 AM |
Junior Member
Visits: 19
Actually VAC is not a firmware it's a software, and it's easy to install
Just download it at http://software.muzychenko.net/trials/vac412.zip
Unzip it and then install it (it will do the rest)
Then you are ready to use it.
cheers
TBD
