How to upgrade firewire interface?
FlexRadio Systems Forums
How to upgrade firewire interface? Expand / Collapse
Author
Message
Posted Sunday, August 26, 2012 9:36 AM
Forum Newbie
Group: Forum Members
Last Login: Monday, August 27, 2012 3:26 PM
Posts: 1, Visits: 4
I have been using the FireWire interface that is built into my PC's motherboard successfully
with the FLEX-5000, except that when I first start up the SDR software, the audio is
"choppy".  Restarting the SDR software always fixes it.  I have a 64-bit PCI card that I
would like to use in place of the internal FireWire interface.  Is there a special procedure
for getting this to work, or can I just get the card working, plug the cable in, turn the
FLEX on, and start the SDR software?
Thanks in advance and 73,
Bob  WA4FOM
"So let it be written. So let it be done."
Post #5966
Posted Monday, August 27, 2012 8:40 AM
Supreme Being
Last Login: Sunday, January 27, 2013 2:39 PM
Posts: 86, Visits: 89
You can install your new card, it will ask for a driver, just install driver and go. As long as the right chipset is used on your new card it should be fine. However I think something else is going on there. It may be a buffer setting, sample rate setting, video, check all this out first. If there is a setting problem then the new card will not help much. I think I have seen that choppy thing on my Flex 3000 before. Changing the sample rate fixed it.
Post #5968
Posted Thursday, August 30, 2012 4:54 AM
Forum Newbie
Last Login: Thursday, August 30, 2012 4:41 AM
Posts: 1, Visits: 1
No need for a special procedure you can just do it in the above manner!!
leased line
Post #5970
« Prev Topic | Next Topic »
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 10:29pm
Execution: 0.031. 11 queries. Compression Disabled.
