Posted Saturday, August 11, 2012 11:12 AM |
Forum Newbie
Group: Forum Members
Last Login: Sunday, September 9, 2012 6:10 PM
Visits: 7
I recently purchased a Flex-1500. I'm really enjoying the equipment. However, I noticed a strange problem. After some time on, the radio goes down abruptly. All that remains is the characteristic noise radio off the air. I need to start the Power SDR and everything returns to normal. But in some minutes, perhaps 30 minutes, the problem occurs again. I appreciate all the help you can give me.
73, Clovis-PY3OG
Posted Thursday, August 16, 2012 7:15 PM |
Junior Member
Last Login: Monday, November 25, 2013 7:31 PM
Visits: 25
Set your Computer power settings to maximum performance.
Posted Tuesday, August 21, 2012 7:04 PM |
Forum Newbie
Visits: 7
Thank you. I will try your suggestion.
Posted Thursday, August 30, 2012 10:24 AM |
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Visits: 274
Be sides setting for High Performance, make sure that the power settings for each USB Root Hub is set to prevent the OS from powering down the USB ports. In some cases this will completely stop PowerSDR or cause noise burst when the port is powered down while PSDR is still running.
Windows is configured to shut down the USB device. Check the Universal Serial Bus Controllers->USB Root Hub properties in Windows Device Manager and make sure that the "Computer can shut down this device" option is UNCHECKED under Power Management. With this checked, if there is little or no activity, Windows will close that port and device down. While in Universal Serial Bus Controllers->USB Root Hub properties look at the Power tab, make sure the devices connected are not drawing more than 500mA per port (unpowered hubs combines all the current drawn by the connected devices on that USB port) .
This should help also.
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Posted Sunday, September 9, 2012 6:12 PM |
Forum Newbie
Visits: 7
Ok Dudley, I'll check. Thank you.
Posted Monday, December 3, 2012 9:05 AM |
Forum Newbie
Last Login: Sunday, December 16, 2012 7:58 AM
Visits: 21
Thanks Dudley, it always pays off to surf the forum.... Thanks agn, 73, John
73,John KC4RSN
