Flex 3000 / fldigi / VAC
FlexRadio Systems Forums
Flex 3000 / fldigi / VAC Expand / Collapse
Author
Message
Posted Tuesday, June 5, 2012 3:40 PM
Forum Newbie
Group: Forum Members
Last Login: Wednesday, June 6, 2012 6:21 PM
Posts: 2, Visits: 2
Basically since getting my Flex 3000 I have not really been very successful in getting a good working digital station going.
I have 2 setups. First is the Kenwood-TS2000 with Signalink USB, works flawlessly with fldigi, always decodes well and the received signal always holds steady as shown by the green bar in fldigi.
Second setup is Flex 3000, fldigi and VAC. When observing the received signal the green bar is jumping up and down and never holds steady therefore decoding is terrible.
VAC set up is:
SR: 8000 - 192000
BPS: 8 - 16
NC: 1-2
Line In only checked
Max Inst: 20
Ms per Int: 5
Stream fmt limit: Cable range
Volume control: unchecked
I have this set for both Cable 1/2
Sample Rate in fldigi is 48000, Buffer Size 2048
Any others with issues or suggestions on how to get this working as so far it's unusable as a digital station.
Post #5745
Posted Wednesday, June 6, 2012 1:51 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Saturday, June 22, 2013 1:08 PM
Posts: 32, Visits: 44
if you'r using the free ver. of vac,problem might be the :buy me nag:in the audio stream that breaks up a digital signal,,,payed ver. works much better...just an idea!!!
Chuck n4oyt
Post #5749
Posted Wednesday, June 6, 2012 6:21 PM
Forum Newbie
Posts: 2, Visits: 2
I am using the full paid for version.
Post #5750
Posted Thursday, June 7, 2012 2:53 PM
Forum Member
I had to make changes in vac  to make mine work ...may not fix yours, but worth a try.. chuck
sr- 22050-4800
bps-8-32
nc-1-8
Chuck n4oyt
Post #5755
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 12:13pm
Powered By InstantForum.NET v4.1.4 © 2021
Execution: 0.016. 12 queries. Compression Disabled.
