Posted Monday, April 23, 2012 4:14 PM |
Forum Newbie
Group: Forum Members
Last Login: Monday, April 22, 2013 3:39 PM
Visits: 18
Can anyone please tell me how to pre-record my voice for transmission, e.g. CQ CQ CQ this is... It seems that this should be a fairly easy task for the PowerSDR but ther is no obvious option for this... Thanks in advance Ray EI3GD
Ray
EI3GD
Posted Monday, July 16, 2012 11:45 PM |
Junior Member
Last Login: Sunday, January 13, 2013 3:26 PM
Visits: 18
Ray, The Flex can record or playback post processed audio using the quickrecord or similar buttons. It actually saves the data as a wave file in one of the flex directories - if you have a play it tells you where it is saved IIRC. So in theory (not tried yet) you cold record a .wav file in the smae format using windows sound recorder or whatever, rebame it and pop it in that folder. Your new ' CQ de xxxxx' file should then appear in the list. Or if you save it as thw Quickrecord.wav (or whatever) you can hit it from the PLAY button at the top left of the screen. I havent quite mastered how it all fits though myself - so just a suggestion  Steve
Kind Regards,
Steve M1BJR
Somerset UK
Posted Tuesday, July 17, 2012 8:07 AM |
Moderator
Group: Administrators
Last Login: Friday, August 30, 2019 8:35 AM
Visits: 1,478
Posted Tuesday, July 17, 2012 11:38 AM |
Forum Member
Last Login: Saturday, June 22, 2013 1:08 PM
Visits: 44
its so eazy that we over look it...key your mic,then press the rec button and make your cq call.. it will record it. next time you key the mic,press play and it will playback your recorded cq... but i cain't make it record over agian..i suppose you have to go find the file and delete it first!!
Chuck n4oyt
Posted Friday, July 20, 2012 1:17 PM |
Junior Member
Visits: 18
Chuck - genius
Kind Regards,
Steve M1BJR
Somerset UK
Posted Thursday, July 26, 2012 7:46 PM |
Supreme Being
Last Login: Sunday, January 27, 2013 2:39 PM
Visits: 89
Every time you record, the recorded file is over whiten. To record I pres rec and then key the mic, make my recording than pres rec again to stop recording. A message comes up telling were the recording is saved. To play back over the air pres mox and than play and it will send audio over the air. As soon as the mox light goes out after the recording is finished pres mox to un key the radio. Thats it. All files are saved as wav files and can be moved to for use on any wav player.
