Posted Monday, March 5, 2012 7:38 PM |
Junior Member
Group: Forum Members
Last Login: Sunday, April 22, 2012 12:47 PM
Visits: 20
I want to demo the Flex at a local club.
Can I , record 30 minutes of say 40M CW, or 15M JT65.
take the file on a laptop, with the Flex demo, and then play it With out the real Flex hooked up?
Better yet, could I also put the JT65 software on the laptop and then use it with the recorded
wave and decode some stations?
Before I go borrow a laptop to use I thought I'd ask first.
Frank KA1QW
Posted Thursday, March 8, 2012 8:01 AM |
Junior Member
Visits: 20
Ok, maybe someone from Flex Support could answer this ?
Posted Saturday, March 10, 2012 3:40 PM |
Forum Member
Last Login: Tuesday, May 22, 2012 9:59 PM
Visits: 29
I've never tried it with digital modes so I can't help there but you can make a recording of the band then play it back later. You don't need the radio to play it back, just PSDR. I've also done it with a little softrock radio using Rocky instead of PSDR.
Posted Wednesday, April 18, 2012 12:10 PM |
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Visits: 274
Yes, you can record a JT65 and play it back, just like you were there. Best to do it with the radio there to take care of the analog to digital conversion. Record with complex wave or with the Audio menu set to RX on Pre-Processed and TX on Post-Processed. Running in the mode in Demo can be a problem due to having to rely on the laptop sound card, you will most likely need to lower the sample rate of the Audio tab to 48K to be within capabilities of the sound card. Also don't forget to load your purchased version of VAC too, do not use the Demo version ..
Also remember that there is no absolute frequency data kept in the complex wave recording, only relative to the I/Q bandwidth itself. In otherwords, you will be tuning about in the bandwidth of the recorded I/Q file, the width it was recorded at, so the frequency displayed in VFOs is not accurate. So set the VFO to the frequency it was originally recorded plus 9 khz (or you IF offset) to be close.
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Posted Sunday, April 22, 2012 10:33 AM |
Junior Member
Visits: 20
Thanks for the answer, Dudley !
I like doing a demo of the PSDR with a recording of 40M during a contest. Adding the ability to show off
the digital modes is even better. !
