Posted Sunday, January 29, 2012 8:35 AM |
Supreme Being
Group: Forum Members
Last Login: Sunday, January 27, 2013 2:39 PM
Visits: 89
What is needed to use PSK on the Flex, and how is it done,,thanks,,,73
Posted Tuesday, January 31, 2012 12:46 AM |
Forum Newbie
Last Login: Tuesday, January 31, 2012 12:45 AM
Visits: 2
Just checkout this link might help you.
http://hanclinto.com/site/index.php/psk-docs/53-getting-started-setting-up-a-platformer-starter-kit-environment
Shaw Flooring
Posted Tuesday, January 31, 2012 1:48 PM |
Supreme Being
Visits: 89
wow, there must be a better way to use PSK31 to go through all that setup. There must be other Flex radio users using it?
Posted Tuesday, January 31, 2012 5:05 PM |
Junior Member
Last Login: Monday, May 13, 2013 7:49 PM
Visits: 101
VA3WTB (1/31/2012) wow, there must be a better way to use PSK31 to go through all that setup. There must be other Flex radio users using it?I use HRD and the included DM780(digital) and Logbook. In HRD the main program to control the radio is replaced with MiniDeluxe. MiniDeluxe handles passing cat data between PSDR and DM780 and/or Logbook. I could use the main HRD program, but I don't need the application overhead that involves. Audio is handled by Virtual Audio Cable (VAC). VAC is a program you have to purchase (Ver 10.4) handles the audio out/in between PSDR and DM780. I use vspMgr to handle cat data between PSDR and MiniDeluxe which is a Virtual Serial Port utility. All of the above was found in the Knowledge Base picking away one piece at a time over 3-4 days. I was already familiar with HDR running a IC-7000 so the learning curve was not as steep. Good Luck Mike
The road goes on forever and the party never ends...
Posted Wednesday, February 1, 2012 12:20 PM |
Supreme Being
Visits: 89
Ok thanks, I have a good idea what I need to do,,,,Bill 73
