12 Volt requirement for accessories don't exist
FlexRadio Systems Forums
12 Volt requirement for accessories don't... Expand / Collapse
Author
Message
Posted Monday, December 26, 2011 3:31 PM
Forum Newbie
Group: Forum Members
Last Login: Thursday, March 14, 2013 6:49 PM
Posts: 6, Visits: 25
Hello,
So far i hearing from my 6M band friend using a Flex 5000A a preamp is highly required to use on the RX loop on the backside of the Flex5000A.
That's very great to be able to connect a preamp but the only problem is to find the required power to connect them without to use the Flex I/O connector.
Hardware suggestion is to add a protected 12 volt output separately for low amperage device accesories inteast to use the Flex I/O DB9 connector
Michel VE2XK
Post #5264
Posted Friday, January 6, 2012 2:19 PM
Junior Member
Last Login: Wednesday, July 17, 2013 7:46 AM
Posts: 10, Visits: 24
As you know there is 12v there on the port , but sure would have likes to have other options as far as available switched  12v, for preamps relays ect, but its probably to keep the RF from getting into the radio through the back door
ve2xx
Stu
Post #5303
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:57pm
Execution: 0.031. 12 queries. Compression Disabled.
