S meter versus Panadapter levels
FlexRadio Systems Forums
S meter versus Panadapter levels Expand / Collapse
Author
Message
Posted Wednesday, December 14, 2011 1:37 PM
Forum Newbie
Group: Forum Members
Last Login: Wednesday, December 14, 2011 1:18 PM
Posts: 3, Visits: 6
I have noticed that the average signal levels seen on the Flex 5K S meter as compared to the panadapter seem to be quite different. For example, on 40 meters on a section of the band with no signals, the panadapter shows a very flat line centered at -110db which should correspond to and S meter reading of about S3. However, the S meter reads S6 with the meter set to either "signal" or "sig avg". That is an 18db difference which is quite large.
I checked with Dudley the other day and he indicated that the panadapter would never read as high a signal level as the S meter since the panadapter is limited by the display frame rate. He indicated that the S meter should read the correct value. I guess this translates into some difference in the sampling rate.....not sure. When I switch to my Icom, the S meter there seems to agree with the Flex panadapter much more closely. I would think the Flex should agree more closely as well. However, I don't have any first hand experience with any other panadapters. So I wondered if anyone had any thoughts/experience on this.
Post #5210
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 9:44pm
Execution: 0.047. 10 queries. Compression Disabled.
