60M changes
FlexRadio Systems Forums
60M changes Expand / Collapse
Author
Message
Posted Saturday, November 19, 2011 6:37 PM
Junior Member
Group: Forum Members
Last Login: Sunday, April 22, 2012 12:47 PM
Posts: 16, Visits: 20
I'm anticipating numerous questions about how to get changes in the Flex radios to cover the approx Dec16th improvements to 60M.
I will attempt to provide a basic overview of the
changes and rules in plain language, as they apply to the
Amateur Radio Service in USA. See the synopsis
below, but please rely only upon the actual FCC rules.
http://www.fcc.gov/document/amateur-radio-service-5-mhz
Regards,
Bonnie Crystal KQ6XA
USA's Federal Communications Commission
released a REPORT AND ORDER on November 18, 2011
with new 5MHz rules for the Amateur Radio Service.
The effective date: 30 days after publication in the Federal Register.
The FCC adopted the use of the name "60 meter band",
to refer to 5MHz amateur radio in the frequency
range 5330.5-5406.4 kHz, but USA hams are still only
allowed to transmit on 5 specific channels in the band.
The FCC changed the rules to allow:
Phone (Upper Sideband), RTTY, Data, and CW;
with specific limitations on the use of these modes.
Amateur radio is a "secondary user" in this band, and
must not cause harmful interference to other services!
Amateur Radio Service must accept interference from
other primary services and other nations services.
Operators transmitting data or RTTY must exercise care
to limit the length of transmission so as to avoid
causing harmful interference to US Government stations.
New 60 meter band 5MHz Channel List:
General, Advanced, or Amateur Extra Class license only.
Suppressed
Carrier
VFO Dial freq
5330.5 kHz USB (center of channel = 5332.0)
5346.5 kHz USB (center of channel = 5348.0)
5357.0 kHz USB (center of channel = 5358.5) New!
5371.5 kHz USB (center of channel = 5373.0)
5403.5 kHz USB (center of channel = 5405.0)
Note: FCC deleted the channel at 5366.5 USB (center=5368.0)
and "replaced" it with channel 5357.0 kHz USB (center=5358.5)
The maximum allowed power level is now 100Watts PEP (ERP)
effective radiated power referenced to a dipole.
If another type of antenna is used, the station licensee
must maintain a record of either the antenna manufacturer’s
data on the antenna gain or calculations of the antenna gain.
Upper SideBand Phone, Data, or RTTY transmissions
may use dial (VFO) USB suppressed carrier frequency
at 1.5kHz below the center of the channel.
Transmissions must not exceed the 2.8kHz bandwidth channel.
RTTY modes such as PSK31 must not exceed 60Hz necessary
bandwidth. Data modes must not exceed 2.8kHz bandwidth.
CW bandwidth must not exceed 150Hz bandwidth and the CW
frequency should be at the center of the channel.
Data stations operating under section § 97.221
automatically controlled digital station, are not
allowed on these 5MHz channels.
Post #5131
Posted Friday, November 25, 2011 6:00 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Friday, May 9, 2014 11:20 AM
Posts: 38, Visits: 119
That will be nice but the new Channel will not let me trx with my flex. Think flex is going to come up with a fix on this, and what about digitial mode like psk that will be there . That will not work eighter at the present time. My rig is a SDR-1000 .
Anybody check there rig and see if it work on the new frequency?
Jim W4WWJ
Post #5150
Posted Sunday, November 27, 2011 4:49 PM
Forum Member
Last Login: Saturday, December 31, 2011 7:26 PM
Posts: 30, Visits: 47
They will work I'm sure when the time to be able to use the new channel is in fact legal.
I think Flex will have the updates ready when the date is legal for us U.S. operators to infact use the new channel and digital modes. I would not count on there being a release before that time! as if you are trying and succeed to operate the new channel and or digital modes now you are in violation of the 60M operating previlages.
See
http://www.arrl.org/news/view/fcc-releases-new-rules-for-60-meters
or
http://transition.fcc.gov/Daily_Releases/Daily_Business/2011/db1118/FCC-11-171A1.pdf
as stated in both of those doucments the changes will not take effect or be legal until
There has been a lot of postings on the flex reflector and other sites, but it seems a lot of users are jumping the starting gun with thinking they can go and operate the new channel and use digital modes there now, as that is NOT the CASE!
hopefully reading either of the links will help resolve some of the rummors and mis conceptions of when and what is allowed on 60M.
Rick
KD8LCD
Post #5160
« Prev Topic | Next Topic »
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 10:21pm
Execution: 0.031. 10 queries. Compression Disabled.
