SDR-1000 No TR transition on RFE J2
FlexRadio Systems Forums
SDR-1000 No TR transition on RFE J2 Expand / Collapse
Author
Message
Posted Friday, February 29, 2008 8:06 PM
Forum Newbie
Group: Forum Members
Last Login: Wednesday, March 5, 2008 1:27 PM
Posts: 5, Visits: 6
I have a weird problem with either my RFE board or software setup.
As you know, the J2 connector on the RFE board is used for the internal or the external transverter.
RF wise, the port is working. I fed in a signal from a generator to this port and it receives well. Measured the output during transmit and got 0.8dBm on this port. All within spec.
The problem is with the TTL TR signal that is supposed to be with the RF on this connector. If I set it up with Positive TR Logic, then the DC voltage on this connector stays at 0v whether I am transmitting or not. If I set it up with Negative TR Logic, then the voltage stays at 5V whether I am transmitting or not. The problem is that it is not making a transition from 0 to 5V or vice-versa.
This has me baffled.
Any help appreciated.
Thanks,
Raj, N2RD
SDR-1000 #0611-9435
Raj, N2RD
SDR1K, K3
Raj, N2RD
SDR1K, K3
Post #498
« Prev Topic | Next Topic »
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 2:40am
Execution: 0.016. 8 queries. Compression Disabled.
