CPU use
FlexRadio Systems Forums
CPU use Expand / Collapse
Author
Message
Posted Tuesday, September 20, 2011 3:01 PM
Forum Newbie
Group: Forum Members
Last Login: Tuesday, September 20, 2011 2:38 PM
Posts: 8, Visits: 19
Since installing PowerSDR 2.2.3 on my newly formatted PC and Flex 3000 that previously ran the previous version at 12-25% it now runs at 80-100% and is stalling and stuttering, has any one experienced this issue. My other PC much lowered spec (Also newly installed), is running at around 45-50% with my Flex 1500 with 2.2.3
System Spec
Flex 3000
Intel Core 2 Quad 6600
4 Gb fast ram
System drive 60 Gb Crucial SSD
Software drive 500 Gb Sata
Onboard firewire
Complete new install Win 7 Ultimate 64
V2.0.19 12-25% cpu use V2.2.3 80-100%
Flex 1500
AMD athlon 64 x2
2 Gb ram
500 Gb HD
USB
V2.0.19 45-50% no problems
Previously with 2.0.19 i ran both radios, tv software, email and web browsing at the same time and never ever got near 80% cpu usage, now with dedicated PC's for both radios the "High Spec" one will not run 2.2.3, the radios even run better on my Samsung N150 550 atom netbook. Any ideas from experienced users?
Regards Simon M6AQL
Post #4896
Posted Sunday, October 2, 2011 11:10 PM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: Sunday, September 29, 2013 11:01 AM
Posts: 58, Visits: 64
MellyFlex (9/20/2011)
System Spec
Flex 3000
4 Gb fast ram
Onboard firewire
Flex 1500
AMD athlon 64 x2
2 Gb ram
500 Gb HD
USB
Regards Simon M6AQL
As a FYI, I am using PowerSDR v2.2.3 with my FLEX-1500 and the average CPU usage is < 20%. This is the same % as with earlier versions of PowerSDR I had been using. 80%+ does not seem to be normal.
BTW, as you know, the F-1500 uses USB and My USB Driver Buffer settings (General | Options) is set midway between Conservative and Aggressive.
Computer: CPU: AMD Phenom-II X6 1090T (6x @ 3.2 GHz overclocked to 3.8 GHz) | Corsair H50 Liquid-cooling | Mobo: ASUS M3N78-EM | RAM: 4096 MB (Kingston KHX8500D2K2/4GR) | Video: nVidia GEFORCE GTX460 w/1GB DDR5 | HDD1: 1TB 7200 RPM Seagate, HDD2: 300GB 7200RPM Seagate, HDD3: 1TB 7200RPM Seagate | OS: Microsoft Windows 7 Professional x86 SP1 | Audio Out: BOSE Companion-5 (USB) | Audio In: On-board Motherboard | Monitor/LCD: SAMSUNG SyncMaster 245BW (24", 1900 x 1200) | Case: Antec 902 V3 | PSU: CORSAIR GS700 700W "Gaming Series"| APC XS-1300 (1300VA) | Bright House 40/5 Cable Modem
Bruno, W4AFK
West Melbourne, Florida [EL98qb]
[FLEX-1500 w/Pixel RF PRO-1B HF Loop (RX) Antenna & MFJ-1786 & 1788 HF Loops (TX), HLA-150 Plus amp | TenTec RX-320D & Kenwood R-2000 w/Timewave DSP-599zx, sharing LF Engineering H-800 SkyMatch HF Probe Antenna, various software packages for data modes]
Post #4980
Posted Tuesday, October 4, 2011 4:39 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Saturday, December 31, 2011 7:26 PM
Posts: 30, Visits: 47
System Spec
Flex 3000
4 Gb fast ram
Onboard firewire ? WHAT Chip SET?
Since this sis a new install is it possibly that maybe Win& is out in the background apply updates? also have all the device drivers been loaded correctly there are no BANGS (Yellow marks) in device manager ?
Flex 1500
AMD athlon 64 x2
2 Gb ram
500 Gb HD
USB
Regards Simon M6AQL
I am running an AMD X565 at 3.5 Ghz with 4 Gb ram on an MSI motherbaord with win 7 Professional 32Bit I also use an dedicated TI chipset PCI-e X1 firewire card and a dedicated PCI-e video card, thus I am not using anything extr like on-board video processing.
On average with nothing else running but PowerSDR and the normal try Icons I see about 12-23%
using Outlook email, and HRD logbook/DM780/VAC/DDutil and Mini-deluxe with SDR It normally hangs around 46-53% and have had no lag or drop outs.
make sure all the device drivers are up to date, if this is a store bought system check for bloatware! thats the stuff that many store bought off the shelf computers install claiming to be free or trails of programs lots of them just run idle in the background and or worthless check MSCONFIG and look in start up is there extra stuff there that is getting loaded when windows starts?
Another big issue I have seen is some of these FREE antivirus programs they are MEMORY hogs! and will drag down systems bad!
Avast / Norton and McAfee suites are a few that come to mind. Most antivirus programs will let you suspend there scanning or disable them for a short time look and see if you can and if so then check your CPU usage will it is disabled you might find it is a culprit.
I have had very good results with Eset antivirus it is not one from my personal experiences have found that slows down a PC and provides very good protection.
post back what you find.
and good luck
rick
KD8LCD
Post #4989
Posted Tuesday, March 19, 2013 7:36 AM
Forum Newbie
Last Login: Friday, August 29, 2014 4:51 PM
Posts: 7, Visits: 8
Melly Flex asked :
Since installing PowerSDR 2.2.3 on my newly formatted PC and Flex 3000 that previously ran the previous version at 12-25% it now runs at 80-100% and is stalling and stuttering , has any one experienced this issue. My other PC much lowered spec (Also newly installed), is running at around 45-50% with my Flex 1500 with 2.2.3
System Spec
Flex 3000
I am alsio interested in the stalling and stuttering.
i run a Flex SDR-1000 and the FA-66 card
This has to be the best set up for ESSB voodoo but have been recorded with a couple stutters now and agian more like a popping every so often.
Anyone have any experience of this popping and cures found so far would be good
Best regards,
voodoo from Plymouth
Post #6470
Posted Friday, April 26, 2013 1:10 AM
Forum Newbie
Last Login: Friday, April 26, 2013 12:57 AM
Posts: 2, Visits: 2
CPU stands for Central Processing Unit, as we know that cpu is the mind of system which handle all the things in our system.
The free norton antivirus
Virus and spywares
Latest Download Manager
Post #6533
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:10am
Powered By InstantForum.NET v4.1.4 © 2021
Execution: 0.016. 12 queries. Compression Disabled.
