PowerSDR 2.2.2 "BIN" reception?
FlexRadio Systems Forums
PowerSDR 2.2.2 "BIN" reception? Expand / Collapse
Author
Message
Posted Wednesday, August 24, 2011 11:28 PM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Group: Forum Members
Last Login: Sunday, September 29, 2013 11:01 AM
Posts: 58, Visits: 64
Running 2.2.2 beta with my F1500. I noticed that "BIN"aural reception does not seem to work is SSB. When I switch to 2.1.5 it works fine.
Before I log this in the "bug tracker", I wanted to know if I might be missing a setting.
Bruno, W4AFK
West Melbourne, Florida [EL98qb]
[FLEX-1500 w/Pixel RF PRO-1B HF Loop (RX) Antenna & MFJ-1786 & 1788 HF Loops (TX), HLA-150 Plus amp | TenTec RX-320D & Kenwood R-2000 w/Timewave DSP-599zx, sharing LF Engineering H-800 SkyMatch HF Probe Antenna, various software packages for data modes]
Post #4760
Posted Friday, August 26, 2011 8:40 PM
Junior Member
Last Login: Wednesday, September 7, 2011 7:13 AM
Posts: 12, Visits: 19
I seem to see the same thing here with 2.2.2 using a 5KA. Selecting the BIN does nothing.
Post #4770
Posted Saturday, August 27, 2011 1:12 PM
Junior Member
Last Login: Thursday, January 12, 2012 1:49 PM
Posts: 10, Visits: 9
Hello
Binaural works fine here with the 2.2.2 release.
The rig is flex 1500
Computer is Panasonic Toughbook with centrino 1.2Ghz and 1.5 Go Ram - OS winXP Pro 32bits.
No bug found on 2.2.2 after a day of test with this portable configuration
Best regards
Eric, F1NSK
South west France
Flex 1500 user
Post #4776
Posted Saturday, August 27, 2011 1:51 PM
Forum Guru
Très bizarre Éric (Interesting)...
Perhaps I need to clarify something: In 2.1.5 clicking on the BIN button toggles between BINaural and normal. In 2.2.2 beta, clicking on it does nothing. I am also using a Flex-1500.
The other oddity is that when VAC is started in 2.2.2 (VAC button is pushed), my USB based Webcam turns on and stays on. When I turn off VAC or shutdown 2.2.2, the webcam shuts off. This does NOT occur when I use 2.1.5 or with earlier versions.
Computer: CPU: AMD Phenom-II X6 1090T (6x @ 3.2 GHz overclocked to 3.8 GHz) | Corsair H50 Liquid-cooling | Mobo: ASUS M3N78-EM | RAM: 4096 MB (Kingston KHX8500D2K2/4GR) | Video: nVidia GEFORCE GTX460 w/1GB DDR5 | HDD1: 1TB 7200 RPM Seagate, HDD2: 300GB 7200RPM Seagate, HDD3: 1TB 7200RPM Seagate | OS: Microsoft Windows 7 Professional x86 SP1 | Audio Out: BOSE Companion-5 (USB) | Audio In: On-board Motherboard | Monitor/LCD: SAMSUNG SyncMaster 245BW (24", 1900 x 1200) | Case: Antec 902 V3 | PSU: CORSAIR GS700 700W "Gaming Series"| APC XS-1300 (1300VA) | Bright House 40/5 Cable Modem
Bruno, W4AFK
Post #4778
Posted Sunday, August 28, 2011 5:10 AM
Junior Member
Hello Bruno
Perhaps a bug with Windows 7 ?
New test 2.2.2 today with my main computer.
HP xw6400 workstation with Quad core Xeon 3GB ram OS winXP pro 32 bits
Nvidia quadro FX video card dual screen.
2.2.2 works perfectly.
I have tried all features to find a bug and help other hams.
VAC = ok
Virtual Serial Ports = ok
3rd party softs tested
HRD = ok
mixW = ok
WSPR = ok
Ros 6.6.8 = ok
bobsmeter = ok
Sorry, I can't help you more.
I've tried W7 when it was free for test.
Discarded fast !
With a computer I want remain the BOSS !
Eric, F1NSK
South west France
Flex 1500 user
Post #4783
Posted Sunday, August 28, 2011 11:09 AM
Forum Guru
Hello Éric,
Thanks for the feedback. I would suspect Windows 7 (which I believe is Microsoft's best operating system since Windows 2000 ;-) However, the problem ONLY occurs with beta 2.2.2. It doesn't appear with 2.1.5 or earlier versions which I still have on my computer.
In any event, this is a beta and I did list this in their bug tracker so I assume that it will be looked at then either dispelled as something on my computer or fixed.
Mes salutations ;-)
Bruno, W4AFK
Post #4784
Posted Sunday, August 28, 2011 9:13 PM
Forum Guru
Mystery has been resolved regarding BIN & Webcam operation. It winds up being all on my side.
Beta 2.2.2 changes the VAC audio settings (Setup| Audio | VAC) by selecting "MME" as the driver and "Primary Sound Capture" for the input. I changed the first to "Windows Direct Sound" and the later to "Line In (HDA)" as I use the audio output from the F-1500 to drive my sound card via the line-in for data modes. VAC is used for voice.
Essentially, if I select MME for the driver, my Webcam starts every time ;-)
Bruno, W4AFK
Post #4788
Posted Tuesday, August 30, 2011 3:25 AM
Junior Member
Hello Bruno,
Fine Business !
2.2.2 notch filter add-on is terrific !!
A great job from Flex-radio.
Merci pour les remarques en français venues du soleil de Floride !
QRZ.com m'a appris que vous étiez un "cousin" du Canada comme l'on dit chez nous !
Eric, F1NSK
South west France
Flex 1500 user
Post #4798
Posted Tuesday, August 30, 2011 8:21 PM
Forum Guru
Effectivement, je suis d'origine Québécoise (de Laval-des-Rapides, tout près de Montréal). Nous avons déménagé en Californie il y a presque 18 années déjà. Depuis, nous sommes devenus américains. Par contre, j'ai gardé ma citoyenneté Canadienne ce qui me donne le droit de maintenir VE2EQ en plus de W4AFK.
OK... back to our regular programming now ;-)
Since I figured out what I was doing wrong, I can say that beta 2.2.2 is pretty good. I really like the notch filter as it does a very good job indeed.
Ciao!
Bruno, W4AFK
Post #4804
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 6:11am
Execution: 0.062. 12 queries. Compression Disabled.
