Primary Sound Card tab empty - No Sound
FlexRadio Systems Forums
Primary Sound Card tab empty - No Sound Expand / Collapse
Author
Message
Posted Sunday, August 21, 2011 1:31 PM
Forum Newbie
Group: Forum Members
Last Login: Tuesday, November 22, 2011 3:25 PM
Posts: 2, Visits: 5
Windows XP
Laptop
Powersdr 2.15
Reinstall
I uninstalled the PowerSDR software along with com0com and VAC. I reinstalled PowerSDR first. Install seemed OK but the Primary sounds card tab is blank with the exception of Mic Boost check box and Rate box.
Only way to get audio is to enable VAC. Before, VAC was free for digital modes only.
I reset to factory defaults but this had no effect.
Sound card drivers were no fooled with and show good
Please help!
Post #4747
Posted Sunday, August 21, 2011 3:48 PM
Supreme Being
Last Login: Thursday, October 25, 2012 10:13 AM
Posts: 191, Visits: 505
You didn't say which radio you where using...
For the Flex 1500,3000,5000 there is not much under the setup>audio>primary tab.. except rate and boost ..
Sound card selections will show up if your radio is SDR-1000 or SoftRock.. (or maybe demo ?? )
To hear sound with 1500,3k or 5k you will need to use the hardware output from the radio or route the audio through VAC.
You may wish to reset to factory defaults and see how that works.. Goto Setup>Factory Defaults..
Unininstalling and reinstalling PowerSDR does not reset you profile to Factory defaults..
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #4748
« Prev Topic | Next Topic »
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:46am
Execution: 0.016. 8 queries. Compression Disabled.
