Flex 3000 and externel mixer
FlexRadio Systems Forums
Flex 3000 and externel mixer Expand / Collapse
Author
Message
Posted Sunday, August 7, 2011 3:09 PM
Supreme Being
Group: Forum Members
Last Login: Sunday, January 27, 2013 2:39 PM
Posts: 86, Visits: 89
I would like to use a mic that needs a mixer to work. Is there a way to connect my Eurorack 6 channel mixer to my Flex 3000. The mixer has RCA jacks for audio out,,,thanks
Post #4700
Posted Sunday, August 7, 2011 4:35 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Tuesday, May 22, 2012 9:59 PM
Posts: 25, Visits: 29
Since the Flex has a mixer in PSDR I'm not sure why you need an external mixer but I'm sure you can make it work. You'll need to make an adapter from the plugs on the mixer to the RJ-45 connector on the radio. Do you know what the output impedence of the mixer is?
The mic jack pinout is in the quick start guide that came with your radio or you can download it from flex-radio.com.
Kerry, WD5ABC
Post #4702
Posted Sunday, August 7, 2011 9:07 PM
Supreme Being
Hi thanks for posting.There are a number of flex users using micks that run on 28 volts through a audio mixer. I have not learned how they connect to the Flex yet. I don't know if I can just go into the mic input or not. They recommend my mixer model on the Flex knowledge center.
Post #4704
Posted Monday, August 8, 2011 12:47 PM
Supreme Being
Last Login: Thursday, October 25, 2012 10:13 AM
Posts: 191, Visits: 505
My first choice for connecting an external mixer to the Flex 3000 would be through the Flexwire connector on the rear of the 3k. Pin 1 is ground, Pin 2 is "line in".. Then select line in on the PowerSDR Mixer.
You could add a foot switch to the rear PTT inpur jack..
See page 7 for the 3000 Owners manual.
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #4707
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 6:37pm
Powered By InstantForum.NET v4.1.4 © 2021
Execution: 0.047. 10 queries. Compression Disabled.
