How to memorize the antenna port selection w/PowerSDR 2.0.22?
FlexRadio Systems Forums
How to memorize the antenna port selection... Expand / Collapse
Author
Message
Posted Sunday, June 26, 2011 9:02 AM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Group: Forum Members
Last Login: Sunday, September 29, 2013 11:01 AM
Posts: 58, Visits: 64
Essentially, I am using a Pixel Technologies RF PRO-1A active HF Loop for receive through the "XVRX" port and plan on using a MFJ-1788 antenna via the "PA" port for TX.
However, whenever I turn off PowerSDR (v2.0.22) then restart it, both TX & RX are back to using the "PA" port. As I am using an active antenna for RX, I will NOT want TX RF to reach it, hence my selection.
Question: It is probably very simple so I must be blind, but how can I tell PowerSDR to memorize my antenna port selection settings?
Bruno, W4AFK
West Melbourne, Florida [EL98qb]
[FLEX-1500 w/Pixel RF PRO-1B HF Loop (RX) Antenna & MFJ-1786 & 1788 HF Loops (TX), HLA-150 Plus amp | TenTec RX-320D & Kenwood R-2000 w/Timewave DSP-599zx, sharing LF Engineering H-800 SkyMatch HF Probe Antenna, various software packages for data modes]
Post #4533
Posted Sunday, June 26, 2011 3:02 PM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
This is a problem in the 2.0.22 version .    I beleive that this was corrected in the RC3 version ..
http://support.flex-radio.com/Downloads.aspx?id=369
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #4535
Posted Sunday, June 26, 2011 3:31 PM
Forum Guru
Thanks Dudley ;-)
I'll have a look at "RC3"
Bruno, W4AFK
Post #4536
Posted Sunday, June 26, 2011 3:56 PM
Forum Guru
Dudley... a few quick follow-up questions:
1. As I am running 2.0.22, are there are precautions I need to do before installing 2.1.2 RC3?
2. Can I install 2.1.3 RC3 into another directory so that I can revert to 2.0.22 if I encounter problems?
3. Lastly, can I "import" 2.0.22 settings and frequencies into my 2.1.3 RC3 setup?
Bruno, W4AFK
Post #4537
Posted Monday, June 27, 2011 3:25 PM
Supreme Being
Last Login: Thursday, October 25, 2012 10:13 AM
Posts: 191, Visits: 505
Yes you can install 2.1.RC3 and still have 2.0.22 installed... Each version will be installed in its own directory by default and not interfere with the other. The both use the same firmware version.
I would set up 2.1.RC3 and test it before attempting to import setting from 2.0.22..
But rather than importing the 2.0.22 database directly into RC3, I would use K9DUR's SDRdatatransfer utility to import you settings into the new database..
see: http://k9dur.rnaconsultingservices.com/Downloads.aspx
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #4546
Posted Monday, June 27, 2011 5:46 PM
Forum Guru
Thanks Al... I'll install into another directory then use the database transfer utility ;-)
Bruno, W4AFK
Post #4550
Posted Tuesday, June 28, 2011 4:53 PM
Forum Guru
FYI... 2.1.2 RC3 memorizes the antenna selection info ;-)
Bruno, W4AFK
Post #4557
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:53am
Execution: 0.047. 10 queries. Compression Disabled.
