ALC on Flex 5000
FlexRadio Systems Forums
ALC on Flex 5000 Expand / Collapse
Author
Message
Posted Thursday, June 9, 2011 11:30 AM
Forum Newbie
Group: Forum Members
Last Login: Monday, June 13, 2011 3:33 PM
Posts: 3, Visits: 5
I finally got my new Flex 5000A operational over the weekend. I have noticed that operating the radio at 100% drive my WaveNode meter is displaying 112-120 watts on peaks (SSB). Getting good signal and audio reports however I am a bit worried that I'm over driving the radio. Also using an EQ+ on the front end and feel I have all adjusted properly. Is there a procedure for adjusting ALC?
Al
Post #4443
Posted Thursday, June 9, 2011 12:23 PM
Supreme Being
Last Login: Thursday, October 25, 2012 10:13 AM
Posts: 191, Visits: 505
AL,
Unlike many other radios, the flex ALC is an all software thing.. i.e. no feedback from the PA.
The PA in the F5k is quite rugged and immune to a bit of overdrive.. If your concerned, just back off on the drive a bit..
(my F5K will show 145 watts out on 15m at 100% drive.. )
If you have concerns about setting up the transmit chain and ALC see :
http://flexradiowiki.com/frsradoiowiki/index.php?title=Setting_Audio_Gain
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #4446
Posted Thursday, June 9, 2011 2:34 PM
Forum Newbie
Posts: 3, Visits: 5
Thanks Al,
Being software driven I thought that was the case. Just wanted to be sure, didn't want to blow the thing up before I got off the ground!
Al
Post #4448
Posted Friday, June 10, 2011 9:14 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Thursday, August 30, 2012 8:45 AM
Posts: 39, Visits: 38
The Flex can handle 100% power (CW Key down) forever, according to Gerald.  SSB peaks over 100 watts will not blow up the amp, but you may be clipping the audio.
A much worse clipping condition is caused by ALC peaks over 0dB. This is noticeable and annoying.  Don't let that happen.  To avoid this, check out the the Flex wiki article on how to tune the different audio stages to get good power and no ALC clipping.   It's very worthwhile.
Post #4455
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:52am
Execution: 0.031. 10 queries. Compression Disabled.
