Flex-1500 as Shortwave Receiver
FlexRadio Systems Forums
Flex-1500 as Shortwave Receiver Expand / Collapse
Author
Message
Posted Sunday, June 5, 2011 8:18 PM
Forum Newbie
Group: Forum Members
Last Login: Sunday, June 5, 2011 8:10 PM
Posts: 1, Visits: 1
I am considering purchasing the Flex-1500 to use primarily as a shortwave receiver for commercial international transmissions.
I see in the spec sheet the following "Receiver Frequency Range (MHz) [optimized for amateur bands] 0.01 – 54 MHz". What does "optimized amateur bands" mean?
What are your experiences?
How well does the Synchronous AM work?
Scott - KD7WCE
Post #4428
Posted Monday, June 6, 2011 11:32 PM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: Sunday, September 29, 2013 11:01 AM
Posts: 58, Visits: 64
ScottC (6/5/2011)
Scott - KD7WCE
Scott, I am using my FLEX-1500 as a SW and Utility receiver for now. I made this choice after reading the review in the current Monitoring Times. They rated the receiver as one of the best around. By "optimized for amateur bands", I believe that they are mainly referring to the TX side. BTW, you can have the radio unlocked (TX everywhere) if you have a valid FCC license (Experimental). In this case, the published specs are not guaranteed when the radio is used outside of the ham bands.
Up to now (one week of use), I have used it to receive HF data (3rd party software for PSK31, RTTY, FAX, JT65, etc.), voice (AM, S-AM & SSB) and DRM (3rd party DRM software). I have been very happy. S-AM works fine.
The FLEX-1500 is so customizable that at times one gets lost in the settings. For example, the DSP based noise reduction does a great job... but not everyone understands the relationship between "taps, delay, gain, leak". One just wants to adjust the aggressiveness but you almost need a training course to understand the relationship between these items (sigh).
If there was one item I do miss is an Ethernet port. As it stands, the only easy way to remote control this puppy is by making sure you leave a computer connected to your FLEX-1500 and then using a remote access application (Go-to-my-PC, etc.).
Bruno, W4AFK
West Melbourne, Florida [EL98qb]
[FLEX-1500 w/Pixel RF PRO-1B HF Loop (RX) Antenna & MFJ-1786 & 1788 HF Loops (TX), HLA-150 Plus amp | TenTec RX-320D & Kenwood R-2000 w/Timewave DSP-599zx, sharing LF Engineering H-800 SkyMatch HF Probe Antenna, various software packages for data modes]
Post #4431
Posted Tuesday, October 9, 2012 11:00 AM
Forum Newbie
Last Login: Wednesday, February 6, 2013 10:03 AM
Posts: 7, Visits: 12
Hi....having recently purchased my Flex 1500 soley for using it for broadcast band listening and i am finding it is better than my Perseus.......
Post #6063
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:34am
Execution: 0.047. 9 queries. Compression Disabled.
