Junior Member
Group: Forum Members
Last Login: Sunday, March 04, 2012 2:56 PM
Visits: 75
Ok I have my SDR 1000 all set up with an Edirol FA66 and I am using the 2.0.22 software.
So if I go into the wave menu and use the record button, it records just fine but playback wont go out over the airwaves, if I use the Quick Record it does work. Anyone have any idea what the problem could be ??
I'm on windows 7 32bit and everything else works GREAT !
Junior Member
Last Login: Tuesday, April 17, 2012 1:43 PM
Visits: 33
| I get the same results with 2.0.22 and 1.18.6 on win xp!! are you useing parrallel port or usb on win 7 ??? chuck n4oyt
Chuck n4oyt
Junior Member
Visits: 75
n4oyt (5/21/2011) I get the same results with 2.0.22 and 1.18.6 on win xp!! are you useing parrallel port or usb on win 7 ???
chuck n4oyt
I am using a Parallel port, and its funny because it actually does work intermittently, kind of strange. Some times I just shut the radio off and turn it back on, restart the software and it works just fine, however it wont play back any of the other audio files that werent recorded prior to the shut down.
Junior Member
Visits: 75
| Well I dropped back to 1.18.6 and everything works perfectly so the newer stuff seems kind of buggy with the SDR-1000. So I guess I'll stick with 1.18.6...
Forum Newbie
Last Login: Thursday, December 15, 2011 8:09 PM
Visits: 17
