Junior Member
Group: Forum Members
Last Login: Sunday, March 25, 2012 1:44 PM
Visits: 52
| I am running a Windows 7 - 64 Bit computer with a internal PCI-E Firewire card. The card has 1 Port 400 and 2 Port 800 Mbps ports. When the drivers do load, I can verify that the Firewire Card is compatible using the Flex Radio Driver System check. Issue is when booting the PC, the Flex Radio Drivers do not always load. ( I get a computer audio sound when the SDR Drivers Load). Also, I can open the Flex Radio Driver and I receive the NO Devices Found. Opening the FlexRadio driver and selecting SYSTEM, I can validate that the OHCI 1394 Host Controller card is installed and Compatible, no known issues. However, the Flex 5000A Firmware is not loaded and the Power SDR v2.0.19 RC1 Does not find the radio. I do not like to do the following step. However, If I turn the Flex-5000A Radio off wait about 10 seconds and turn it back on, It may install and the Firewire shows the radio. HOwever, I have to do this several times to get it to LOAD. The computer will make the FOUND Device audio sound when the Flex-5000A radio has loaded. Can anyone help with this problem since I do not want to wear out the Power switch on the 5000A.
