Flex 3000 no Fwd Power reading
FlexRadio Systems Forums
Flex 3000 no Fwd Power reading Expand / Collapse
Author
Message
Posted Friday, February 04, 2011 5:29 AM
Junior Member
Group: Forum Members
Last Login: Saturday, May 14, 2011 12:45 PM
Posts: 21, Visits: 84
Hi
A brand new Flex 3000 just setup. No Fwd Pwr reading on TX.
PSDR showing Tune signal in window and relay clicks to TX mode, power supply shows increased draw, fans kick in on Flex. ATU in PSDR disabled by me.
Pwr meter on antenna shows no power and cannot tune antenna on external ATU because of zero power.
Any ideas ?
Kind regards
Post #3884
Posted Friday, February 04, 2011 6:33 AM
Moderator
Moderator
Group: Administrators
Last Login: Sunday, April 15, 2012 2:14 PM
Posts: 618, Visits: 1,449
Contact FlexRadio Support (support@flexradio.com) and talk to Dudley about your initital setup issues.
Tim - W4TME
Post #3885
Posted Saturday, February 05, 2011 5:30 AM
Junior Member
Thank you, I have done this and I am awaiting a reply.
Kind regards
Post #3888
Posted Sunday, February 06, 2011 3:56 AM
Junior Member
Tried everything. Finally rolled back the firmware to 1.2.5.6 and PSDR 1.18.6 and it's working.
However the PSDR still shows 0 watts Fwd Pwr but my external power meter shows roughly the correct power reading and I can tune the antenna
using the external ATU, the internal PSDR ATU still not working
Post #3894
Posted Sunday, February 06, 2011 5:51 AM
Junior Member
Ok TX failed again after machine reboot. Reinstalled Win XP and only PSDR 1.18.6
Reset database and flashed firmware with 1.2.5.6 still no TX
What do I do now ?
Post #3895
Posted Wednesday, February 16, 2011 8:33 AM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: Tuesday, April 24, 2012 8:50 AM
Posts: 55, Visits: 62
Hi, I had the same thing happen to me, if you see some of my post here. I noticed that one of the black wires on the power plug had unpluged from the connector. I pushed it back in and everything worked after that incuding proper trasnmit. I am still not sure if that is what it was as there are other things I had done also,,but it may be that it needs all wires connected properly to work.
Post #3933
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 10:20am
Powered By InstantForum.NET v4.1.4 © 2012
Execution: 1.553. 8 queries. Compression Disabled.
