VISTA Software
FlexRadio Systems Forums
VISTA Software Expand / Collapse
Author
Message
Posted Saturday, January 15, 2011 2:07 PM
Forum Newbie
Group: Forum Members
Last Login: Thursday, March 10, 2011 12:19 PM
Posts: 8, Visits: 10
I see from reviewing the older forum history that running VISTA is supposed to create problems.   However, those posts are years old.  I know some issues like the availability of NET have been solved.   Are there any remaining major reasons I need to go back to XP on the newer machine I just bought or can I use it with the VISTA software?
Post #3742
Posted Saturday, January 15, 2011 2:35 PM
Moderator
Moderator
Group: Administrators
Last Login: Friday, August 30, 2019 8:35 AM
Posts: 588, Visits: 1,478
The issues are primarily with 64-bit Vista (PowerSDR with the SDR-1000 doesn't work due to a lack of the proper 64-bit hardware drivers).
If you do 32-bit Vista, then you have the sound card driver challenges to overcome; especially if you are using the Delta 44 sound card.
IMHO, Vista is a pile of poop. If you want to upgrade beyond XP, do yourself a favor and install Win7 x86 (32-bit) on a computer that has a working parallel port since the USBIO drivers only work on XP.
Tim - W4TME
Post #3743
Posted Saturday, January 15, 2011 4:28 PM
Forum Newbie
I have the Eiderol soundcard.  Being retired cost is an issue.  I knew VISTA was an issue and I did try to get a fast computer with XP, but the vendor I bought from only had the dual core fast units with VISTA.    Does having that allegedly better model soundcard reduce the issues enough for me to use it or do I definitely need to change the OS?   If I gotta, I will bite the bullet and eat dogfood for the next month.  HI! HI!.
Post #3748
Posted Saturday, January 15, 2011 8:08 PM
Moderator
Moderator
Using Vista isn't necessarily a "show stopper". You should be OK with the Edirol FA-66 Vista drivers.
I don't have enough info about your PC and its configuration to answer the question regarding changing the OS.
1.) Do you have the 32 or 64-bit version of Vista loaded on the PC?
2.) Do you have or plan to use a parallel port for radio control?
Tim - W4TME
Post #3750
Posted Saturday, January 15, 2011 10:32 PM
Forum Newbie
Computer is Dell GX745 Core 2  duo Pentium D 3.4 GHZ with 750 GB Drive.  Got the 32 bit version of VISTA Business allegedly with all drivers.
I was planning on using either the parallel port or USB.  The deal with rig came with a parallel to USB cable.   I heard that I might have to use straight parallel to parallel cable and could not use the USB connection with VISTA.  Is that true?
Post #3753
Posted Sunday, January 16, 2011 8:25 AM
Moderator
Moderator
The PC will be fine.
The USB cable does not work well with Vista, so if you use a native parallel port, you should be OK.
Good luck. Enjoy the radio.
Tim - W4TME
Post #3756
Posted Sunday, January 16, 2011 9:49 AM
Forum Newbie
Thanks for all the info.
Bruce
K4CMC
Post #3760
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 2:37pm
Powered By InstantForum.NET v4.1.4 © 2021
Execution: 0.031. 11 queries. Compression Disabled.
