Forum Newbie
Group: Forum Members
Last Login: Sunday, June 06, 2010 6:07 PM
Visits: 12
| Hi, I need a litle advice please. Last year I bought a Flex3000 which, due to Family commitments, I have not been able to set up. The Radio is exactly as purchased and hasn't had any updates. The PC is running Windows 7 64bit....I5 core processor with 6Gb RAM. Question is, bearing in mind the original state of the 3000, and that software and drivers have been updated several time...... What do I need to download and instal?? Mant thanks Roger G0IUW
Moderator
Group: Administrators
Last Login: Monday, June 20, 2011 6:07 PM
Visits: 1,447
Roger,
All of the current software for the FLEX-3000 is listed on the left hand side of the FlexRadio Systems' web page.
www.flex-radio.com You want to use the current versions of the FLEX Firewire driver and PowerSDR.
There is also a Quick Start Guide that will tell you the order in which you need to install things.
FLEX-3000 Quick Start Guide
After getting things up and running, you may need to do a firmware update. That software too is found on the FlexRadio Systems' web page and here is the instructions for installing it.
How to Update the FLEX-5000/3000 Firmware (prior to v2.0.0)
Tim - W4TME
Forum Newbie
Visits: 12
| Thanks for that. Tim, Seems to be fine now. 73, Roger G0IUW
