FLEX-5000A & Ham Radio Deluxe (HRD)
FlexRadio Systems Forums
FLEX-5000A & Ham Radio Deluxe (HRD) Expand / Collapse
Author
Message
Posted Monday, October 26, 2009 9:40 AM
Forum Newbie
Group: Forum Members
Last Login: Monday, November 12, 2012 5:14 AM
Posts: 9, Visits: 33
OK.... Flex-5000 now working OK
Has anybody got an idiots guide to connecting the Flex-5000A with Ham Radio Deluxe (HRD)
I have looked through the postings but I have drawn a blank
73's
Post #2002
Posted Monday, October 26, 2009 4:05 PM
Supreme Being
Last Login: Thursday, October 25, 2012 10:13 AM
Posts: 191, Visits: 505
If you have not already tried the Flex Knowledge Center, may I suggest you try there next.
http://kc.flex-radio.com/search.aspx
Entering HRD will give you several articles to start with.. If you are going to use HRD/dm780 for digital modes you may wish to use 'VirtualAudioCables' (VAC). You may also wish to use a serial port emulator program such as com0com. Although the HRD article mentions vcom, com0com is currently recommended by many. Suggest search the KC for VAC and com0com.
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #2003
Posted Wednesday, October 28, 2009 10:33 AM
Forum Newbie
Thanks for the tip
Have been in the knowledge-base for many things as I have so many questions..
Simple things like DSP / NR / NB settings.... can get any to work properly..
I am sure they do but it is getting the settings right.
Post #2006
Posted Friday, October 30, 2009 5:01 PM
Supreme Being
In the 4 years that I have been using PowerSDR, I have had very little reason to change any of the DSP, NR, NB setting except just to see what the did.. Defaults work just fine for 99% of my operation.
Don't let the quest for "optimum" settings get in the way having fun with the radio ( unless the quest is the fun ! )
AL, K0VM
Post #2009
Posted Tuesday, November 3, 2009 4:57 AM
Forum Newbie
OK.... I got HRD working fine....
Not sure how .. it was a case of "Poke & Hope"
Re DSP & NB Settings.... I assume that the controls are there for a reason.
On my IC7000 the NB suppresses static crashes.... I haven't yet found a setting on the Flex-5000 that does anything as good.... having said that I am still playing.
I am resorting to using the BHI DSP Box for comfortable 'Noise free' reception until I get everything under control on the F5K
Post #2014
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 7:10am
Execution: 0.016. 8 queries. Compression Disabled.
