What is PAL?
FlexRadio Systems Forums
What is PAL? Expand / Collapse
Author
Message
Posted Thursday, September 24, 2009 10:25 AM
Forum Newbie
Group: Forum Members
Last Login: Sunday, March 14, 2010 7:51 PM
Posts: 5, Visits: 16
There are a couple of branches that refer to PAL. What does the acronym PAL stand for?
Bill - K7UOP
Post #1946
Posted Thursday, September 24, 2009 11:18 AM
Supreme Being
Last Login: Tuesday, January 17, 2012 4:25 PM
Posts: 215, Visits: 503
I am not sure what PAL stands for, but it is a different method of passing control signals across the Firewire cable that is supposed to be more efficient than the previous method (MIDI). It seems to reduce CPU loading a bit.. The PAL/MIDI controls streams are not the same as the digitalized audio data streams. The PAL versions of PowerSDR require compatible versions of Firewire driver (3.4.2.6300) and firmware (2.0.0.0). I don't think the new firmware is compatible with non-PAL versions of PowerSDR.
AL, K0VM
SDR-1000, Flex5000, Flex user since 2006
Post #1947
Posted Thursday, September 24, 2009 6:49 PM
Forum Newbie
Thanks Al, for the info. From your input, I googled 1394 pal and came up with this:
"The 1394 Trade Association... announced that it has approved the WiMedia Alliance's MAC Convergence Architecture (WiMCA) as a platform for a high-speed wireless 1394 protocol adaptation layer (PAL) development. The PAL permits <snip> 1394 devices and protocols to be used in a wireless environment at speeds up to 480 Mbs <snip>."  So, this seems to show us where the PAL started.
From other sources I see that it operates as a layer between the application and the IEEE1394 protocol. And from what you say, replacing MIDI in our case.
Because of a problem I was having with Remote Power Up and PTT keying I can confirm that the new firmware does Not work with non-PAL versions of PowerSDR. It does work "as advertised" with the latest release of firewire driver, firmware and pb-pal. It fixed my problem.
Bill - K7UOP
Post #1948
« Prev Topic | Next Topic »
Forum Moderators: Admin, w4tme, KE5DTO
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 11:24am
Powered By InstantForum.NET v4.1.4 © 2012
Execution: 2.506. 9 queries. Compression Disabled.
