Flex 3000 SWR meter
FlexRadio Systems Forums
Flex 3000 SWR meter Expand / Collapse
Author
Message
Posted Thursday, July 30, 2009 10:07 AM
Junior Member
Group: Forum Members
Last Login: Monday, March 17, 2014 6:27 AM
Posts: 11, Visits: 16
Dear all,
 I have noticed that when I transmit and the TX meter is on SWR it always give me a 0.0 to 1 reading even if I do not use the ATU. Using another rig I do get some SWR on my TH3jnr, so I am perplexed that I get nothing on the Flex 3K.
I also have a windom and I use the ATU and also this give me a 0.0 to 1 ratio when I tun on the other bands.
Any suggestion?
Regards
Chris
Post #1836
Posted Thursday, July 30, 2009 10:11 PM
Forum Newbie
Last Login: Thursday, August 13, 2009 9:08 AM
Posts: 5, Visits: 8
I received a response on just this issue from Dudley today. Apparently, this is as designed.
Pete
AG7C
Post #1837
Posted Saturday, August 1, 2009 6:52 AM
Forum Newbie
Last Login: Sunday, February 20, 2011 12:38 PM
Posts: 6, Visits: 131
Pete
AG7C
Then what purpose is the meter and what explanation did he give?
Pierce
W4ZDI
Pierce W4ZDI
Post #1838
Posted Sunday, August 2, 2009 12:36 PM
Junior Member
Pete & Pierce
I am asking the same question. How will I measure the swr to see that i am tuned well? Infact reflected power does work so I know how much power is being reflected back, however i feel much better using SWR.  Do they intend to rectify the matter?
73s
Chris
Post #1841
Posted Sunday, August 2, 2009 9:20 PM
Forum Newbie
Posts: 5, Visits: 8
Hi guys,
I guess the real answers must come from FLEX.... But here is Dudley's reply to me.
Pete,
If you are in SSB, the TX Reflected power may not be accurate. The true reflected power will only be accurate in a continuous carrier mode, CW, AM, or Tune. The reason is that the sampling is not taking place fast enough in SSB for the sake of taking time away from radio performance.
Hope this helps,
Dudley
At home I use a Palstar AT1KP and its metering has spoiled me.
Portable, I am using the Flex-3000 alone. Yes, I would like the SWR to be available, but the addition of tuner memories in the future would be of much more use to me.
Pete
AG7C
Post #1843
Posted Monday, April 23, 2012 7:12 PM
Forum Newbie
Last Login: Saturday, January 26, 2013 7:45 AM
Posts: 5, Visits: 9
The SWR on my Flex 3000 is also always at 0.1 on AM, FM it does not matter, if 5 or 99 on drive power.
The High SWR warning does come up, but how am I supposed to use an external
Antenna Tuner, if I can't see the SWR at the radio??
73 K2HAT
73 K2HAT fn32
Post #5596
Posted Tuesday, April 24, 2012 8:56 AM
Supreme Being
Last Login: Sunday, January 27, 2013 2:39 PM
Posts: 86, Visits: 89
Interesting, When I press the tune button on the Flex the SWR reading is close to the reading on the MFJ tuner meter. If I move away from a good tune the meter on the Flex reflects that change. I like to use the meter in the MFJ tuner as it is active all the time and I don't have to keep setting the Flex meter to SWR. I set it to ALC most of the time.
Post #5597
Posted Sunday, April 29, 2012 10:47 AM
Junior Member
Last Login: Monday, June 10, 2013 5:53 AM
Posts: 19, Visits: 30
This is how it should work(does with me!)
Select Setup and than Transmit.
On the left part of the screen just under drive select SWR!
Set the drive lets say at 5 watt.
Close the screen.
On the TX meter above the S meter of PowerSDR select SWR.
Press Tune!! It does not work with SSB.
That should work!
PD2HE
Post #5612
Posted Monday, April 30, 2012 9:48 AM
Supreme Being
Last Login: Tuesday, August 13, 2013 12:47 AM
Posts: 109, Visits: 274
Chris,
As an additional comment, the SWR meter works correctly in Tune or solid carrier as AM, in SSB the 1000ms refresh is not quite enough to keep up with peaks. But in Tune, select SWR while in tune, have the RF at greater than 10 watts for better accuracy.
Dudley
FlexRadio Systems Support
512-535-4713, Option 2
http://helpdesk.flexradio.com
Post #5614
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -5:00, Time now is 5:21am
Powered By InstantForum.NET v4.1.4 © 2021
Execution: 0.063. 13 queries. Compression Disabled.
