﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / FLEX-1500 Discussions &amp; Operating Techniques / General  / Power switch Problem / Latest Posts</title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Fri, 18 May 2012 11:09:42 GMT</lastBuildDate><ttl>20</ttl><item><title>RE: Power switch Problem</title><link>http://forums.flexradio.com/Topic3165-56-1.aspx</link><description>I had the same symptoms / problems as described when I received my 1500 mid July.&lt;/P&gt;&lt;P&gt;Spoke with Dudley and sent in for a IC replacement, but no mention of switch replaced but upon return all problems fixed and power switch "felt" firmer to the touch when cycled off and on. &lt;/P&gt;&lt;P&gt;Mike&lt;/P&gt;&lt;P&gt;KG4TGP</description><pubDate>Sun, 26 Sep 2010 21:43:21 GMT</pubDate><dc:creator>MikeB</dc:creator></item><item><title>RE: Power switch Problem</title><link>http://forums.flexradio.com/Topic3165-56-1.aspx</link><description>There still seems to be a problem with powering off the 1500.  For the last couple of times the radio and the computer have been connected for a good part of the day, typically &gt;12 hours.  I select stop the radio, then select the [X] in the upper right corner of the radio display, then power off the computer.  After all that, I press the Power button on the radio to the off position and the blue light is still on.  I cycle the power switch several more times and the only way to turn off the radio is to physically remove it from the power source.  Is this a software issue for the microprocessor and the switch?&lt;br&gt;&lt;br&gt;Fred - N4CLA</description><pubDate>Mon, 06 Sep 2010 12:24:24 GMT</pubDate><dc:creator>N4CLA</dc:creator></item><item><title>RE: Power switch Problem</title><link>http://forums.flexradio.com/Topic3165-56-1.aspx</link><description> My power light stay on also at times, if I shut down PowerSDR and forget to turn off the switch on the 1500 the &lt;/P&gt;&lt;P&gt;on\off switch will turn off. The computer has gone into standby or sleep mode, I have to unplug the 1500 and all&lt;/P&gt;&lt;P&gt;will work ok. I think they should make a selection to automatically turn off the Flex-1500 when shutting down the &lt;/P&gt;&lt;P&gt;software.&lt;/P&gt;&lt;P&gt;Mike</description><pubDate>Thu, 02 Sep 2010 11:47:15 GMT</pubDate><dc:creator>VA3MD</dc:creator></item><item><title>Power switch Problem</title><link>http://forums.flexradio.com/Topic3165-56-1.aspx</link><description>There seems to be an issue with the 1500 power switch that will not power off when the switch is detented "OFF".  I have spoken to someone about this in the past and could not get it to fail since, so here it is again.  I think the scenario is as follows.  If the radio is left powered on and the computer is powered off, like over night, and I then try to power off the radio, the blue led stays lit.  I have had an ammeter connected in line with the radio and when the radio is operating correctly in the receive mode, it is drawing +/- 300 ma.  When I did detent the switch "OFF" and it did not power off, the current drain went to 150 ma in the"OFF" position.&lt;br&gt;&lt;br&gt;Tim what do you suggest?&lt;br&gt;&lt;br&gt;Fred - N4CLA</description><pubDate>Thu, 02 Sep 2010 09:05:12 GMT</pubDate><dc:creator>N4CLA</dc:creator></item></channel></rss>
