﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / FLEX-1500 Discussions &amp; Operating Techniques / General </title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Sat, 04 Feb 2012 21:28:05 GMT</lastBuildDate><ttl>20</ttl><item><title>Beat tone</title><link>http://forums.flexradio.com/Topic5333-56-1.aspx</link><description>Running FLEX -1500&lt;br&gt;&lt;br&gt;I´m having a beat tone appearing every time for a short period every time going from TX to RX.&lt;br&gt;&lt;br&gt;Starts out strong and fades out after about half a second.&lt;br&gt;&lt;br&gt;Don´t know if it is related to the strange error message i get every time starting PSDR &lt;br&gt;&lt;br&gt;I get:&lt;br&gt;"The procedure entry point NtAlpcSendWaitReceivePort could not be located in the dynamic link library ntdll.dll"&lt;br&gt;&lt;br&gt;Any ideas ??&lt;br&gt;&lt;br&gt;SM0JZT Tilman / Sweden</description><pubDate>Tue, 17 Jan 2012 01:34:12 GMT</pubDate><dc:creator>sm0jzt</dc:creator></item><item><title>Flex 1500 /PSDR 2.2.3</title><link>http://forums.flexradio.com/Topic5380-56-1.aspx</link><description>Hi,&lt;br&gt;I'm just trying to set up my Flex 1500 to use with my 23cms transverter. The transverter is 28mhz IF and PTT gnd to TX. Inside my trvtr is a sequencer for the attached 1296mhz PA and LNA. Here is my problem---I would like a short delay on my audio/TX compared to the 1500 PTT out so that all the relays/ etc activated by the sequencer in my trvtr have time to switch/ settle before my 1500 starts to TX.&lt;br&gt;&lt;br&gt;Reading the manual causes confusion. On the antenna form--P32 and P96 as well as PTT enable it is possible to enter a delay---but what is delayed---the PTT line? There is no explanation to accompany the diagram. On page 103 of the manual---Options  Tab--it shows a diagram that mentions Enable--TX out delay. Again this is not explained---whilst it sounds like what I want--the check box and accompanying box to enter delay values  do not appear on my Options Tab in PSDR v 2.2.3&lt;br&gt;&lt;br&gt;So is the delay mentioned in the antenna form the correct place to delay the audio/ tx out or will it delay the PTT line activation? Thanks in advance,&lt;br&gt;73s all</description><pubDate>Tue, 31 Jan 2012 10:49:40 GMT</pubDate><dc:creator>G0EWN</dc:creator></item><item><title>United Kingdom Band Plan 60m</title><link>http://forums.flexradio.com/Topic3889-56-1.aspx</link><description>Having acquired a "Notice of Variation" (NoV) to operate on 5Mhz I have had the firmware on my 1500 updated so the rig is recognised as a UK unit (a turf file was provided by Waters and Stanton for this.).  I was hoping to be able to use it on 60m, however I cannot TX on the channels.  Is it possible to transmit using the 1500 on the following frequencies:&lt;br&gt;&lt;br&gt;&lt;br&gt;Centre	Selected Frequency (USB)     Channel ID&lt;br&gt;5260 kHz	5258.5 kHz	                        FA&lt;br&gt;5280 kHz	5278.5 kHz	                        FB&lt;br&gt;5290 kHz	5288.5 kHz	                        FC&lt;br&gt;5368 kHz	5366.5 kHz	                        FK&lt;br&gt;5373 kHz	5371.5 kHz	                        FL&lt;br&gt;5400 kHz	5398.5 kHz	                        FE&lt;br&gt;5405 kHz	5403.5 kHz	                        FM&lt;br&gt;&lt;br&gt;These frequencies are not part of the standard UK bandplan and may not be used by UK amateurs unless a. NoV has been issued.  As I have one of these any help or guidance would be appreciated.&lt;br&gt;&lt;br&gt;Tony&lt;br&gt;</description><pubDate>Sat, 05 Feb 2011 06:43:44 GMT</pubDate><dc:creator>M0ZZA</dc:creator></item><item><title>Flex1500 and lagging CW - asio drivers helps a lot but...Would the external keyer help even more ?</title><link>http://forums.flexradio.com/Topic5342-56-1.aspx</link><description>Hello om,&lt;br&gt;&lt;br&gt;As an new user, flex/CW is driving me crazy.. :hehe:&lt;br&gt;I really can´t operate my bencher paddle with the flex, the lag is way too big that i could send CW. :w00t::w00t:&lt;br&gt;&lt;br&gt;I noticed that using asio4all Universal ASIO Driver For WDM Audio&lt;br&gt;maded BIG difference. Now the CW keying is much better, almost with no lag&lt;br&gt;&lt;br&gt;[url]http://www.asio4all.com/[/url]&lt;br&gt;&lt;br&gt;But there is still bit a lag, not much but a bit which is making keying bit difficult over 20wpm speed,&lt;br&gt;and i was wondering... would external keyer solve this problem ?&lt;br&gt;&lt;br&gt;Does anyone have any experience with those.At the moment i don´t have any external keyer on my shack&lt;br&gt;and before building one, i like to ask will that help ?&lt;br&gt;&lt;br&gt;All my windows7/64bit sound/recording devices are configurated to 48Khz/16bit&lt;br&gt;&lt;br&gt;Thank you&lt;br&gt;Jari&lt;br&gt;OH2KZK</description><pubDate>Wed, 18 Jan 2012 12:41:48 GMT</pubDate><dc:creator>oh2kzk</dc:creator></item><item><title>New user / Problems with used flex-1500, is my hardware working correctly.</title><link>http://forums.flexradio.com/Topic5296-56-1.aspx</link><description>I have just bought an second hand flex-1500.&lt;br&gt;But it seems that i have some difficulties with that - least on psk-31&lt;br&gt;and there seems to be lots of rx spikes all around on the bands witch can been seen from the SDR waterwall.&lt;br&gt;&lt;br&gt;See the picture.&lt;br&gt;&lt;br&gt;All those spike lines normal when receiving signal ? They all all the bands and seems to originate from 12Mhz.&lt;br&gt;Even without antenna - but not so strong - is this hardware related / normal.&lt;br&gt;&lt;br&gt;Second thing is when i´m transmitting psk-31, nobody is answering,lol&lt;br&gt;&lt;br&gt;I then maded small setup with my second rig/laptop and received my own psk-31 cq with that and noticed that&lt;br&gt;well no it´s not working, psk-31 signal looks fine, but hdr will not decode it ? very strange.? Then when i dropped power &lt;br&gt;very very low then system started to decode psk-31 just fine. But when i increased the ouput (say &gt;5% and over)&lt;br&gt;decoding stopped.&lt;br&gt;&lt;br&gt;I activated the tuning signal from the sdr and noticed from my second receiver/ hdr that it´s waterwall window is full of lines all over the band when flex is transmitting. I then went to the garage and took my old ts-430 and sended with that few watts of CW to confirm that there is only only single line and yes there was only one line on that band.&lt;br&gt;&lt;br&gt;So is it normal that flex has spikes all around when receiving and transmitting ? Or is my hardware broken ?&lt;br&gt;My powersource is an 12v battery.&lt;br&gt;Any ideas, please.&lt;br&gt;&lt;br&gt;Oh and is it normal that sdr s meter shows S3-5 even without antenna. ?&lt;br&gt;&lt;br&gt;Thank you&lt;br&gt;Jari / OH2KZK</description><pubDate>Thu, 05 Jan 2012 11:34:10 GMT</pubDate><dc:creator>oh2kzk</dc:creator></item><item><title>"The procedure entry point NtAlpcSendWaitReceivePort could not be located in the dynamic link library ntdll.dll"</title><link>http://forums.flexradio.com/Topic5334-56-1.aspx</link><description>What is going on when getting this error message ??&lt;br&gt;&lt;br&gt;PSDR starts and I can run the SW all right.&lt;br&gt;&lt;br&gt;SM0JZT   Tilman  ( Sweden)&lt;br&gt;</description><pubDate>Tue, 17 Jan 2012 01:50:38 GMT</pubDate><dc:creator>sm0jzt</dc:creator></item><item><title>HLA 150 Audio Grunge</title><link>http://forums.flexradio.com/Topic4578-56-1.aspx</link><description>I am a new owner of a Flex 1500.  I get perfect audio reports barefoot and also with a Heath SB200 linear  with 5 watts in and 50 watts out.  The audio when monitored on a Yaesu FT-950 is smooth as a baby's behind.&lt;P&gt;I purchased the HLA-150 from H&amp;amp;Y, it makes great power output, but the SSB audio is not a smooth as the tube linear.  I have used the HLA-150 barefoot with the Flex 1500 and also driving the Heath SB-200.  I have had numerious on air reports, the audio is near perfect, but has a little choppyness at times when running the HLA-150 barefoot or the HLA-150 driving the Heath.  &lt;/P&gt;&lt;P&gt;I don't think the HLA-150 is biased just right for SSB.  If I attempt to lower the drive on the Flex to allow lower output, say 80 watts drive into the SB-200 the audio become more choppy and clips.  It is like I have to run the Flex 1500 at full drive for best result of SSB audio.&lt;/P&gt;&lt;P&gt;I called H&amp;amp;Y and Bob said factory warranty would mean shipping it back to Italy, he suggested you don't want to do that.  The only return policy is within 2 weeks of purchase.  He suggested I call a man in Tennesse.  All I get is a phone answering service that the call has been forwared to a voice mail after two calls.&lt;/P&gt;&lt;P&gt;I tried running the HLA-150 both Manual and Auto.  No difference.  Bob at H&amp;amp;Y suuggested I run the SSB switch on, I commented the manual says that only holds the PTT if one is running Auto.  He said no you want to run SSB when running SSB.  So I un-hooked the PTT line, switched the amp to Auto, 3DB swich on and SSB delay on.&lt;/P&gt;&lt;P&gt;Are there some experts with linear building that could tell me if this amp is biased too close to 0 for SSB??&lt;/P&gt;&lt;P&gt;Personal comment, the support from Flex is just great, that from H&amp;amp;Y is on the opposite end of the specturm!  I am waiting for email replies from H&amp;amp;Y.&lt;/P&gt;&lt;P&gt;73&lt;/P&gt;&lt;P&gt;Dave&lt;/P&gt;&lt;P&gt;K0RWM</description><pubDate>Sat, 02 Jul 2011 11:02:33 GMT</pubDate><dc:creator>K0RWM</dc:creator></item><item><title>Yet another microphone question</title><link>http://forums.flexradio.com/Topic5179-56-1.aspx</link><description>Has anyone has any success interfacing a Kenwood MC50 microphone to the Flex 1500?  I have read the recommendations to purchase the Yaesu MH-31A8J (or equivalent) but already having a MC50 begs me to ask the question.&lt;br&gt;&lt;br&gt;Thanks to all and 73,&lt;br&gt;&lt;br&gt;John WW3JR</description><pubDate>Mon, 05 Dec 2011 12:35:17 GMT</pubDate><dc:creator>jromesburg</dc:creator></item><item><title>flex 1500 USB port not acknowledged.</title><link>http://forums.flexradio.com/Topic4795-56-1.aspx</link><description>I have been using my 1500 for about 5 months with ZERO issues. &lt;br&gt;&lt;br&gt;It was in use last week, when I shut down the SDR program and disconnected my 1500. A few moments later, reconnected the 1500 to my laptop and did NOT hear the USB acknowledgement from my laptop.&lt;br&gt;&lt;br&gt;Checked "device manager" and found only the "flex USB kernel".&lt;br&gt;&lt;br&gt;Un-installed all SDR programs and re-loaded the CD. Followed the instruction booklet from 1500. No luck, same problem.&lt;br&gt;&lt;br&gt;The OS is windows XP&lt;br&gt;&lt;br&gt;Any ideas??&lt;br&gt;&lt;br&gt;kb8kco</description><pubDate>Mon, 29 Aug 2011 20:34:49 GMT</pubDate><dc:creator>kb8kco</dc:creator></item><item><title>2m Transverter Success ?</title><link>http://forums.flexradio.com/Topic4223-56-1.aspx</link><description>I am planning to use my Flex-1500 as a prime for a 2m Transverter, what success have 1500 owners had with transverters ?&lt;br&gt;Are any models to be avoided ?&lt;br&gt;Are any particularly suited ?&lt;br&gt;&lt;br&gt;Thanks in advance,&lt;br&gt;Gary Threlfall&lt;br&gt;G7TOK</description><pubDate>Mon, 18 Apr 2011 10:33:59 GMT</pubDate><dc:creator>G7TOK</dc:creator></item><item><title>DJ Console for the Flex 1500</title><link>http://forums.flexradio.com/Topic5297-56-1.aspx</link><description>this to share my experience on installing and using the DJ Console mp3 e2, installation went flawless, just follow step by step Tobias instructions on his site.&lt;br&gt;&lt;br&gt;As to the operation, being able to leave the focus on the logging entry window is priceless, the VFO B knob is also very handy, I did programme the two buttons underneath as Split and MultiRX, this makes the tuning on DX receiving frequency very easy, final touch the slider which allows you to separate VFO A and B on left and right ear.&lt;br&gt;&lt;br&gt;This tool add even more flexibility to your Flex radio and allows to use it to the full extent&lt;br&gt;&lt;br&gt;73, Clay</description><pubDate>Fri, 06 Jan 2012 02:31:36 GMT</pubDate><dc:creator>i4lec</dc:creator></item><item><title>Powersdr 2.2.3 win7 64 bit audio crash !</title><link>http://forums.flexradio.com/Topic5290-56-1.aspx</link><description>After install powersdr 2.23 and turn the rig on and off several times.... then I turn the rig&lt;/P&gt;&lt;P&gt;on...but then ther are no audio from the speaker... then I have to run the setup&lt;/P&gt;&lt;P&gt;again and select the Fix/repair..... &lt;/P&gt;&lt;P&gt;my computer 3.1ghz 4mb-ram win7 64bit</description><pubDate>Wed, 04 Jan 2012 10:39:58 GMT</pubDate><dc:creator>OZ1CT</dc:creator></item><item><title>Flex 1500 Regular White Noise Crash,(FM Noise).</title><link>http://forums.flexradio.com/Topic5279-56-1.aspx</link><description>Hello Fellow Flexers.&lt;br&gt;I've come quite along way these past few days getting acquainted with my Flex 1500.&lt;br&gt;Ive had WSPR running with good success, But I've got problems with Crashing, Loud White Noise(FM type sound) which I have to Turn the Flex 1500 Off and On to correct this.&lt;br&gt;Please any idea's. I need to be able to leave the Flex unattended but can't until this Crash is Sorted.&lt;br&gt;I could do with a quick response to this. I have read of other Flex 1500 users with the same Issue. &lt;br&gt;Happy New Year to all.&lt;br&gt;Thank you&lt;br&gt;Tony 2E0UKX / M6ENG</description><pubDate>Sun, 01 Jan 2012 11:43:45 GMT</pubDate><dc:creator>Tony Fletcher</dc:creator></item><item><title>Remote Operation of the FLEX-1500 via a LAN/WAN?</title><link>http://forums.flexradio.com/Topic4377-56-1.aspx</link><description>Has anyone setup their FLEX-1500 for remote operation via a LAN connection? &lt;br&gt;&lt;br&gt;Due to antenna restrictions where I live, I am setting up a remote base at a friend's house (ham friend ;-). The link will be a fast cable modem connection and I have no problems with that part. &lt;br&gt;&lt;br&gt;As the FLEX-1500 doesn't have an IP port, I am curious to learn how some of you got around this limitation. &lt;br&gt;&lt;br&gt;Now I have my own ideas and I am ready to share them... but I am also interested in reading about other experiences in this area.</description><pubDate>Sat, 28 May 2011 17:39:12 GMT</pubDate><dc:creator>W4AFK</dc:creator></item><item><title>No transverter tx on PA Port</title><link>http://forums.flexradio.com/Topic5253-56-1.aspx</link><description>i just purchased another flex 1500. really wanted to get it going as vhf IF. the problem i am having is that my transverters are all high input. then when you get into the fm portion of the vhf bands the software kicks out with a cant tx on 30mhz error when the PA port is selected.. i am not going to switch all my transvrters to low drive just because of cb'ers. is there a work around or patch for this?&lt;/P&gt;&lt;P&gt;Carey, kc5gtt </description><pubDate>Sun, 25 Dec 2011 16:33:04 GMT</pubDate><dc:creator>kc5gtt</dc:creator></item><item><title>Problems with VAC4.10 Try VAC4.09 Worked Great for me</title><link>http://forums.flexradio.com/Topic5262-56-1.aspx</link><description>Just trying to help anyone with issues with VAC4.10.&lt;br&gt;Anyone Problems with VAC4.10 Try VAC4.09 Worked Great for me.&lt;br&gt;This is given as an downgrade Option when VAC 4.10 is Purchased. I tried ages to get 4.10 to work. My last thing was to try 4.09. Works great.&lt;br&gt;The Navigation problem with Mouse in Panadapter only lags/jerky movement when CAT control is enabled. Maybe something the Flex team could work on.&lt;br&gt; HP laptop Pavilion dv6000, Win XP 32bit O/S. 3gb Ram AMD Turion64 X2.&lt;br&gt;Tony.</description><pubDate>Mon, 26 Dec 2011 14:36:09 GMT</pubDate><dc:creator>Tony Fletcher</dc:creator></item><item><title>Flex 1500 Working Well Now with Just a few Problems - Any Help Please.</title><link>http://forums.flexradio.com/Topic5257-56-1.aspx</link><description>I've had a real tuff time trying to find out why my Flex1.5k wouldn't Decode WSPR signals Properly. But all is good now after downgrading VAC4.10 to VAC4.09.&lt;br&gt;The other Problems are - Navigating around the Panadapter with Mouse is Very Laggy/Jerky. The CPU is fine. It worked great just until the other day&lt;br&gt;Also Power Output on Flex and  WSPR, I'm set a t 20% output on Flex but my PWR meter displays 0.25W. &lt;br&gt;Any Help on these would be appreciated. Thank you.&lt;br&gt;Tony - M6ENG / 2E0UKX.&lt;br&gt;</description><pubDate>Mon, 26 Dec 2011 07:55:17 GMT</pubDate><dc:creator>Tony Fletcher</dc:creator></item><item><title>ComOcom settings for Digital Modes.</title><link>http://forums.flexradio.com/Topic5230-56-1.aspx</link><description>Hello,&lt;br&gt;Big Big learning Curve with the Baby Flex. My first impressions are Fab.&lt;br&gt;I'm into Digital Modes, Psk, WSPR, Ros,Jt65HF ect.&lt;br&gt;I've been watching Dudley's video on Digital modes, but the quality is not to good to see exactly what com0com settings should be.&lt;br&gt;I'm sorry if this has been covered, would really appreciate some one to one help getting the Baby Flex Configured correctly.&lt;br&gt;Thank you. I'm loving the Flex 1500 already. &lt;br&gt;Regards.&lt;br&gt;Tony.&lt;br&gt;tonyfletcher2001@yahoo.com&lt;br&gt;</description><pubDate>Mon, 19 Dec 2011 06:08:47 GMT</pubDate><dc:creator>Tony Fletcher</dc:creator></item><item><title>Flex-1500 Power Output</title><link>http://forums.flexradio.com/Topic5234-56-1.aspx</link><description>  OK.  I've had my Flex-1500 for 2 months, now, and enjoyed using it for SWLing.  But now I finally received my Astatic D-104 Silver Eagle microphone and I've wired it up to the Ethernet cable connection to the Flex-1500.  When I transmit, the TX Meter says I have up to 100% Forward Power and the TX Meter's MIC setting shows the microphone works.  (In fact, I had to reduce MIC gain on the D-104.  MIC level was originally too high!)  I can see the TX spectrum on the computer screen, and it looks good.&lt;/P&gt;&lt;P&gt;  But there's a little problem.  Or, maybe it's not a problem.  I hooked up a wattmeter to the output with a dummy load.  It's a Heathkit HM-102 Wattmeter.  OK, the scale is 200 Watts max, so the little 1 to 5W from the Flex-1500 won't deflect the needle at all!  But I also checked the wattmeter in my Yaesu FT-901 Antenna Tuner.  It has a 25W max scale.  Again, the meter won't deflect at all!  Even when whistling into the MIC on USB mode.&lt;/P&gt;&lt;P&gt;  Am I missing something?  Or, do I just need a lower wattage wattmeter?  If there is no response to this post soon, I'll hook up an HF power amplifier and see if I can get anything out of that.  I sure hope I didn't break something in the Flex-1500.  I don't think I ever transmitted with more that 2:1 SWR.  Is it easy to break with bad termination or high SWR?&lt;/P&gt;&lt;P&gt;  Thanks.&lt;/P&gt;&lt;P&gt;  - Steve</description><pubDate>Tue, 20 Dec 2011 22:06:33 GMT</pubDate><dc:creator>SteveY</dc:creator></item><item><title>Flex1500 with Linrad and WSJT</title><link>http://forums.flexradio.com/Topic5137-56-1.aspx</link><description>I'm using my flex 1500 with Transverter LT2S for EME communication.&lt;br&gt;I would like to implement in my system the LINRAD software and playing with WSJT+LINRAD &lt;br&gt;(I have installed VAC virtual audio cable)&lt;br&gt;Is there anyone who has experience with this configuration?&lt;br&gt;any suggestions will be appreciated.&lt;br&gt;Best 73, de Flavio, ik3xtv</description><pubDate>Tue, 22 Nov 2011 04:53:56 GMT</pubDate><dc:creator>ik3xtv</dc:creator></item><item><title>iphone 4 protection,ipad 2 holder,iPhone 5 Case</title><link>http://forums.flexradio.com/Topic5008-56-1.aspx</link><description>&lt;H3&gt;iphone 4 protection,ipad 2 holder,iPhone 5 Case&lt;/H3&gt;&lt;P&gt;Mother smiled and said: "You little son of it, just made a big fire Baigong Zi You did not see if Canossian willing to air out what I can be that!" Sighed: "I did not get this girl way, his temper is getting big! Mother told me it's difficult to do ah! " iphone 4 protection &lt;BR&gt;Lo Hoi Shan and his wife wants to know which of the girl, he kept asking the two non-stop. Ye Haotian just smile did not answer, finally said: "Now is not the time, so I will get married when you first notice."&lt;BR&gt;Ye Si Wang lucky in mind already, Yu Dong Fang Junlong and no repair the situation here, as long as the East Fangyi Chen and Yu Seduction note, the information revealed to him, he can effortlessly grasp of all, he The rear has to get, now, get in front of the enemy is time. &lt;P&gt;&lt;P&gt;I laughed: "So, can I go see her?" iphone 4 pay as you go &lt;BR&gt;Back to the palace, first of all you see is being eagerly waiting Laner. In their own home, she is like duck to water, the whole people have become more lively and cheerful. She smiled every day, clear laughter spread to every corner of the inner chamber palace.&lt;BR&gt;&lt;P&gt;&lt;P&gt;Qing Zhu and Mother consternation two women looked at me as if seen as a fool. iphone 4 32 &lt;BR&gt;Royal Highness also abolished the daily habit of afternoon tea to the Confucius Temple, the home brew into a tea and chat with Ye Haotian far apart. Is not always serve tea to the girl, but his very cute daughter.&lt;BR&gt;　 &lt;P&gt;&lt;P&gt;Young children helpless: "The son, you really do not know the rules Canossian sister, or is deliberately play the fool? If Canossian sister so easily able to prove that with these people would not be here waiting for a dry in Luoyang Canossian sister and his sister, her three talented woman but to see it even more difficult than the Emperor! " iphone 4 price in uk &lt;BR&gt;At this time, Ye Haotian maturity benefit rolls after the book out on the show. Where both princes said, he can obtain access to it, and each interrupt is key. But he did not empty promises, rhetoric, more often just quietly listening. As a good listener and sometimes easier to like. Several days later, the love of his Royal Highness to the point to be added.&lt;BR&gt;　 &lt;P&gt;iphone 4 battery life, &lt;P&gt;I laughed: "Well, since such a Mother pass on for me, then said she agreed and I have done, let her out to see me!" &lt;A href="http://www.thegerar.com/iPhone-5-cases-iPhone5-case-cases-for-iPhone-5.html"&gt;iPhone 5 Case&lt;/A&gt; &lt;BR&gt;To the eighth month, when Ye Haotian that should be left. People are reluctant to part with the whole family. Queen took Laner's hand and said: "My child, you can do at home more than a few days?"&lt;BR&gt;　 &lt;P&gt;&lt;P&gt;Mother Church, said: "You and Canossian about? No wonder you know Canossian common name, that is, it invites the common name of Agile is not in the know Canossian several people. Do not you met with her?" pay as you go iphone 4 &lt;BR&gt;Laner did not speak, but the cheerful tenderness of eyes have been watching Ye Haotian.&lt;BR&gt;　 &lt;P&gt;&lt;P&gt;I laughed: "Be it, you'll give her that she would understand!" I motioned to a small whole child out of twenty million two drafts drafts to the Mother. iphone 4 uk pricing &lt;BR&gt;Or princes altogether, said: "Let him go Laner, I Haotian feel comfortable with him accompanied, Laner will be very happy."&lt;BR&gt;Volume IV Section II started his career shock &lt;P&gt;&lt;P&gt;"Two ... two hundred and two thousand ?????!!!" Mother stunned the Green Chu watched two women nodded his drafts of the number of started shaking, could not help the screaming, cited to people around the eyes, when you see that stack of million two drafts were changed when the greed and look surprised. compare iphone 4 &lt;BR&gt;Laner knees knock his head to the parents, lookin tears and said: "filial daughter, I will always come back."&lt;BR&gt;　 &lt;P&gt;&lt;P&gt;"Do not go! The money is given to Canossian girl!" I cried. free iphone 4 apps &lt;BR&gt;Her Royal Highness will be pull up, put her hand on Ye Haotian white like the palm, and said: "My child, I entrust her to you, you two be careful, eliminating traitors Shazei I do not care, I just you safely. often come back empty. "&lt;BR&gt;That night, Ye Si Wang Yu on the places in the Seduction of Yung Court in order to appease hearts and minds she was frightened, more obsessed with her own. Then Xiushuyifeng to East Fangjun Long, Dong Fang Yichen told him the story the morning train to do. &lt;P&gt;iphone 4 on pay as you go, &lt;P&gt;Mother looked at the Hua Ting door tumble away, I could not help but laugh, rich feeling quite fun. &lt;A href="http://www.thegerar.com/iPhone-5-accessories-Best-iPhone-5-accessories.html"&gt;iPhone 5 Accessories&lt;/A&gt; &lt;BR&gt;Ye Haotian gift solemn homage, and then use a Xiaojiao lifted Laner out. Has been carried to the Qin Huai River, turn a few laps, surrounded by crowds, Laner was coming out from the chair, with a scarf to cover half the face, coming and going into the ladies with Ye Haotian, Husband of go.&lt;BR&gt;Colorful jade to appease, while waiting to see the emperor leaves Si Wang, Yu small side and amaranth, Zhu Jianqing study of how to kill Shang Hongwu, and strive to keep their strength in the assassination of exposure. &lt;P&gt;&lt;P&gt;Proud glance at others look of envy and jealousy, I put that red a leisurely sip of good tea, the Bai Qinghong surprised expression in the eyes. iphone 4 cost uk &lt;BR&gt;Two people in the Qin Huai River side tour of the day, enjoy the ordinary life of joy in the evening when it is out of the capital.&lt;BR&gt;××××××××××××××××××××××××××××××××××××××× &lt;P&gt;&lt;P&gt;Even no one to please Canossian estimated mine can come up with this, no wonder everyone was surprised, and from the words of their talking about will know. This hand enough to carefully consider whether to deal with Bai Qinghong me, how large sum of money can easily come up with people who have no natural origin will not be a background. price of iphone 4 in uk &lt;BR&gt;From Beijing to meet with 1500 in Taishan, Ye Haotian only way to rest a little while to on Yufeng. To day is not too late, when the two first city in the Mount Tai Tai found a hotel.&lt;BR&gt;"See Huangxiong!"</description><pubDate>Mon, 10 Oct 2011 21:55:57 GMT</pubDate><dc:creator>Bella_Jacquelin</dc:creator></item><item><title>FLEX 1500 SDR</title><link>http://forums.flexradio.com/Topic5213-56-1.aspx</link><description>after setup ,from my location of IO82XP  my first contact was tony  &lt;FONT color=#ff1111&gt;&lt;STRONG&gt;F5VBY&lt;/STRONG&gt;&lt;/FONT&gt; who gave me a report of 5/9+20 for a distance of &lt;FONT color=#ff1111&gt;&lt;STRONG&gt;614.4 miles&lt;/STRONG&gt;&lt;/FONT&gt;  then into rolf &lt;FONT color=#ff1111&gt;&lt;STRONG&gt;DK2MH &lt;/STRONG&gt;&lt;/FONT&gt;who gave me a 5/9 report for a distance of &lt;FONT color=#ff1111&gt;&lt;STRONG&gt;570.1 miles  &lt;/STRONG&gt;&lt;/FONT&gt;  both contacts were made on 40m usb in phono with really good audio reports . set up for my flex is as follows  ,  pc running vista  studio sounds boom mic through 8 channel audio mixing deck ,   to TGM 36SR 3 element multband quad at 40feet  ,&lt;P&gt;how are other stations working with the flex 1500 sdr</description><pubDate>Thu, 15 Dec 2011 12:21:33 GMT</pubDate><dc:creator>robbie M3PQQ</dc:creator></item><item><title>Flex 1500 and Faros</title><link>http://forums.flexradio.com/Topic5068-56-1.aspx</link><description>Faros</description><pubDate>Wed, 02 Nov 2011 13:32:14 GMT</pubDate><dc:creator>OH8GKP</dc:creator></item><item><title>RM Italy, HLA-150 Amplifier 1.8 - 30MHz - works well!</title><link>http://forums.flexradio.com/Topic4142-56-1.aspx</link><description>&lt;br&gt;Just a quick note, I picked up a 'RM Italy' amplifier the other day to use as an alternative to my THP amp.&lt;br&gt;&lt;br&gt;The HLA-150 appears to work well, it has RF-Sensing and automatic band-switching (or manual switching f you wish?)..&lt;br&gt;&lt;br&gt;There is also a PTT input (which isn't necessary with RF-Sense/Switching), so it's plug and play!&lt;br&gt;&lt;br&gt;The amp is designed for inputs of 1-10 Watts, so the output with the Flex-1500's 5W output is 100W on high power and 50W on low  (hi/lo switch). With the aforementioned input, it runs relatively cool, even at 100W.&lt;br&gt;&lt;br&gt;One important feature is that is has the band-pass filtering for 1.8 - 30MHz.&lt;br&gt;&lt;br&gt;73&lt;br&gt;&lt;br&gt;&lt;br&gt;&lt;br&gt;available at: http://www.hyelectronics.com/HLA-150-Amp-by-RM-f18-30MHz/productinfo/HLA-150/</description><pubDate>Sun, 27 Mar 2011 09:24:41 GMT</pubDate><dc:creator>ve3ega</dc:creator></item><item><title>Running Flex 1500 in Parallel's Window on MacBook Pro</title><link>http://forums.flexradio.com/Topic5185-56-1.aspx</link><description>The MacBook is a mid-2010 15.6”, I5 cpu with 8gb RAM, Seagate Momentous hybrid drive, running Lion and the latest version of Parallels 7.  I have 4gb RAM earmarked for&lt;br&gt;the Windows 7 Ultimate 64bit installation. All updates to Windows have been&lt;br&gt;applied. When running radio, I turn off the Wi-Fi and Bluetooth. I used a wired USB mouse and radio was connected with stock USB cable having ferrite at each end. Internet connection was through Ethernet.&lt;br&gt;&lt;br&gt;Radio software includes PowerSDR 2.2.3, VAC 4.09, VSP 1.03 and Fldigi. I run only in digital modes due to very bad hearing. Setup for PowerSDR is pretty standard. I do set&lt;br&gt;buffers at 2048. Fldigi uses the RigCat file from the Fldigi site. All software installed without a glitch.&lt;br&gt;&lt;br&gt;Radio is connected to an Alpha Delta DX-EE fan dipole that I also use with my&lt;br&gt;3000. In that setup, I found that little tuning was needed on the 20-15-10 meter&lt;br&gt;bands. So, I did not use my LDG in initial testing. I also have the THP 45 watt&lt;br&gt;linear amp for use with the 1500 but did not use it in initial testing.&lt;br&gt;&lt;br&gt;After starting PowerSDR, I configured Fldigi, and went to 10 meters. Started&lt;br&gt;seeing signals immediately and was reading them easily-did need to adjust&lt;br&gt;receive font size to help my tired, old eyes. I set the Drive level to 100 and&lt;br&gt;the TX gain to -4; RX gain was at 0. Did a test transmit and my ALC level was&lt;br&gt;-1db. Started transmitting my CQ and received callback from station in North&lt;br&gt;Carolina (I am in Phoenix, AZ). We swapped macros and a bit of extra chat. I&lt;br&gt;switched to 20 meters and had QSO with a Wisconsin station. I also had contacts&lt;br&gt;with station in Cupertino, CA (20m) and North Ridgeville, OH (10m).&lt;br&gt;&lt;br&gt;All of this was with PowerSDR running in a Win 7-window, and Fldigi running in&lt;br&gt;another window both atop the Mac-Lion desktop. Output power was about 4 watts,&lt;br&gt;and a couple of the contacts spoke of the strong, clean signal they were&lt;br&gt;receiving.&lt;br&gt;&lt;br&gt;The antenna is about 35' above ground with ends about a foot lower than center  and runs E-W. It is attached to a mast being held up by tripod used for satellite dishes/TV antennas. The tripod sits atop my flat foam roof.&lt;br&gt;&lt;br&gt;My next step is adding the amp in the TX line, but I don't expect any issues&lt;br&gt;since it is outside the computer link.&lt;br&gt;</description><pubDate>Mon, 05 Dec 2011 23:35:27 GMT</pubDate><dc:creator>K7BAW</dc:creator></item><item><title>Flex -1500 with MacBook</title><link>http://forums.flexradio.com/Topic5093-56-1.aspx</link><description>I am considering purchasing the Flex-1500.  I just finished reading the review in the December issue of QST magazine.  Apparently some USB implementations can cause latency problems for both CW and voice.&lt;br&gt;&lt;br&gt;I have a MacBook Model MacBook6,1 with a Intel Core 2 Duo processor, 4GB of memory, and I am running Windows 7 under Bootcamp.&lt;br&gt;&lt;br&gt;Is anyone using the MacBook and, if so, have you experienced any latency problems?&lt;br&gt;&lt;br&gt;73&lt;br&gt;Pat Turcotte - N4ENF&lt;br&gt;&lt;br&gt;</description><pubDate>Fri, 11 Nov 2011 09:06:09 GMT</pubDate><dc:creator>N4ENF</dc:creator></item><item><title>Flex-1500 &amp; FT-107r</title><link>http://forums.flexradio.com/Topic5062-56-1.aspx</link><description>Hi,&lt;/P&gt;&lt;P&gt;Can anyone tell me how to connect up a Flex-1500 and a Yaesu FT-107R ??</description><pubDate>Tue, 01 Nov 2011 18:16:16 GMT</pubDate><dc:creator>g6tjc</dc:creator></item><item><title>RF Ground a laptop?</title><link>http://forums.flexradio.com/Topic5095-56-1.aspx</link><description>The following is an excerpt from the Flex-1500 User's Manual.&lt;br&gt;&lt;br&gt;"(5) RF Ground Terminal&lt;br&gt;Connect to the single point ground system in your shack. Alternatively, if you have no single point grounding system, ground the FLEX-1500 to the metal chassis of your computer with a low impedance ground strap, such as a 1” braid or copper strip (the screws that hold the computer power supply in place make an excellent grounding point)."&lt;br&gt;&lt;br&gt;This assume you are using a desktop or tower configuration.  How do you RF ground a laptop with a plastic case to the Flex-1500 to your RF ground bus?</description><pubDate>Fri, 11 Nov 2011 09:22:48 GMT</pubDate><dc:creator>N4ENF</dc:creator></item><item><title>Selling Flexradio 1500</title><link>http://forums.flexradio.com/Topic5090-56-1.aspx</link><description>Hope this is OK to post here but I am selling my Flexradio Flex-1500 and it is posted on eBay at this link:&lt;br&gt;     http://www.ebay.com/itm/290631107191?ssPageName=STRK:MESELX:IT&amp;_trksid=p3984.m1555.l2649#ht_1987wt_951&lt;br&gt;&lt;br&gt;It's in great shape!</description><pubDate>Wed, 09 Nov 2011 18:49:32 GMT</pubDate><dc:creator>W2NLS-Neil</dc:creator></item><item><title>Bug Blog</title><link>http://forums.flexradio.com/Topic5031-56-1.aspx</link><description>I found a bug report that matches the same issue I have. I checked with another user of the 1500 who just received his radio a week ago and he has experienced the same issue. So the system says to use the "Bug Blog" to comment on existing bug reports, but where is this bug blog? I think Flex would want to know others experiencing the same issue.&lt;br&gt;&lt;br&gt;Duffy&lt;br&gt;www.wb8nut.com</description><pubDate>Thu, 20 Oct 2011 07:31:42 GMT</pubDate><dc:creator>WB8NUT</dc:creator></item><item><title>1500 preamp noise</title><link>http://forums.flexradio.com/Topic5024-56-1.aspx</link><description>Hello all I am new to the forum and this is my first post question. I have my 1500 setup for receive only. I have noticed that when my preamp is off I hear a rolling rushing noise until I turn it on. Sometimes it goes away at the +10 setting and sometimes it does not go away until I set it at +20. however, when I turn off the spur reduction it goes away. It's hard to notice when a signal is present, but quite noticeable when there is not. It is the same whether the antenna is connected or not. Any ideas Thanx.</description><pubDate>Sun, 16 Oct 2011 13:45:26 GMT</pubDate><dc:creator>disapa</dc:creator></item><item><title>Stacked TNFs ...</title><link>http://forums.flexradio.com/Topic5044-56-1.aspx</link><description>Interesting .... I really like the Tunable Notch Filters but I did find a "birdie" on 10mtrs that is really really loud at times that my TNF did not take care of totally with the deepest setting. So I stacked another on top of it and wow!! It did the job!  I think the loud noise is from a nearby factory and it varies a lot but now I know that the TNF's are additive.  It was probably in the documentation somewhere or posted somewhere but for me it was a new discovery.&lt;br&gt;&lt;br&gt;----Gary WB8ROL</description><pubDate>Mon, 24 Oct 2011 13:05:46 GMT</pubDate><dc:creator>grobin</dc:creator></item><item><title>THP HL-45B Amp and Flex 1500</title><link>http://forums.flexradio.com/Topic5012-56-1.aspx</link><description>I understand that THP in now putting a warning sheet into their instruction booklet that says the warranty is null and void if using the Amp with SDR radios!&lt;br&gt;&lt;br&gt;I talks about SDRs having a factory set fast RF Key Time Delay that is too fast for the Amp. It further states that you must change the Time Delay to a lest 10ms minimum otherwise the amp can be "killed"easily.&lt;br&gt;&lt;br&gt;Anyone else notice this or have any issues? I have not seen any posts from HL-45B users about having any failures with that amp and the Flex 1500. &lt;br&gt;&lt;br&gt;So in looking things over, it appears on the Power SDR software, under the Antenna tab, and under that Flexwire PTT Out that you need to enable the delay there. Is everyone doing this? Are you setting it to 10ms or a little more?&lt;br&gt;&lt;br&gt;Duffy&lt;br&gt;www.wb8nut.com</description><pubDate>Wed, 12 Oct 2011 07:09:47 GMT</pubDate><dc:creator>WB8NUT</dc:creator></item><item><title>digital modes</title><link>http://forums.flexradio.com/Topic4867-56-1.aspx</link><description>HI there i am new to the group and to sdr i order a fkex 1500&lt;br&gt;and was wondering how you operate the flex 1500 and run digital modes does this in tail running 2 computers one for the sdr and one for the digital mode operation???&lt;br&gt;thank you for your help&lt;br&gt;:cool:</description><pubDate>Fri, 16 Sep 2011 10:24:13 GMT</pubDate><dc:creator>w3nrl</dc:creator></item><item><title>Computing power required for good CW operation?</title><link>http://forums.flexradio.com/Topic4923-56-1.aspx</link><description>FLEX-1500 just arrived yesterday, so total newbie here with 20 questions. Less than 10 minutes from opening the box to listening on the bands through the horrible static - nice start. &lt;br&gt;Now starting to play with the transmit modes (into a dummy load) and noticing anomalies that I assume are the fault of the PC(s) I am using. Started with a 2005 vintage Dell Pentium 4, 3.4 GHz machine. Receives ok but maxes out the cpu fairly often. When I transmit on cw, the delay is disconcerting and the tone is very poor (scratchy noises). On any voice mode, the audio is distorted. Switched to a 3 year old Lenovo T60 laptop with Centrino VPro for comparison - the cw tone cleaned up quite a bit and so did the audio (slight artifacts once in a while - I'm listening to the signal on a separate receiver). So I conclude that the old Pentium just doesn't have the hp for the job, and the laptop is close, but not as good as I had hoped it would be. Playing with the buffer size didn't seem to help. Also, the laptop "lump" style power supply generates steady S9 noise - and it's my work PC (not mine) so don't really want to use it for this.&lt;br&gt;So, even though I have looked at all the info on recommended computers, and read lots of anecdotal information in reviews and on this forum, most of the information seems to be aimed at the 3000 and 5000 and the Firewire issues, with little information about what is recommended for the USB based 1500. &lt;br&gt;I was hoping to not have to buy a new PC to run this, but it's looking like I may need to. Looking at the myriad of processors available today, it's a bit bewildering as to what features are important and what isn't. Is the PowerSDR written to take advantage of multi-core CPU's? Is that where the performance stems from, or is clock speed more important? I realize it's a combination of all things that make up the system, but what are the critical elements for this application, as well as the other software one would use with it (digital modes, etc)? &lt;br&gt;I'm not opposed to buying one of the "FLEX ready" PCs, or building one using the components they spell out, but would like to gain a better understanding of the under the hood stuff that makes it work as it should.&lt;br&gt;I really want qsk like a Ten Tec on CW :-) Was that the quietest relay they could find???? Yikes! I find that the sidetone audio delay causes me to send lots of extra dits.&lt;br&gt;73, Tom&lt;br&gt;</description><pubDate>Thu, 22 Sep 2011 15:31:27 GMT</pubDate><dc:creator>NØBS</dc:creator></item><item><title>Hardware Questions - Flex 1500</title><link>http://forums.flexradio.com/Topic4884-56-1.aspx</link><description>I guess since it is an SDR, there is little information about the hardware. I have tried finding some information on the transmitter section of the 1500, but it is either not there or I am missing it. So my questions are:&lt;br&gt;&lt;br&gt;What is the duty cycle of the transmitter? Can I run with digital modes/CW/SSB/FM/AM at 100% drive? &lt;br&gt;&lt;br&gt;Thanks,&lt;br&gt;&lt;br&gt;Duffy&lt;br&gt;WB8NUT&lt;br&gt;&lt;br&gt;</description><pubDate>Mon, 19 Sep 2011 08:34:59 GMT</pubDate><dc:creator>WB8NUT</dc:creator></item><item><title>Note: You must power-cycle the radio when changing between RX-Only and TX/RX...</title><link>http://forums.flexradio.com/Topic4976-56-1.aspx</link><description>I just keep on learning more and more about this FLEX-1500...&lt;br&gt;&lt;br&gt;Installed a MFJ-1788 antenna [i](brand new but had to "Imagineer" a solution as the press-fit nuts broke off due to misalignment between the MFJ hole pattern and the COTS saddles to mount the antenna... but I digress). [/i]&lt;br&gt;&lt;br&gt;No matter what I did, the F-1500 would go into TX but no RF was present. To make a long story short, one item is [u]missing[/u] from the manual: When you change from RX only to TX/RX, you &gt;&gt; MUST &lt;&lt; power-cycle the radio itself!&lt;br&gt;&lt;br&gt;Tested it on FCC  experimental frequencies and all is well now (F-1500 is unlocked)&lt;br&gt;&lt;br&gt;I feel ashamed that it took me a couple of hours of scratching my head, checking to see if my dummy load and meters were good, reading the manual again and again, scouring the Internet, etc. &lt;br&gt;&lt;br&gt;Lesson learned!</description><pubDate>Sun, 02 Oct 2011 22:35:15 GMT</pubDate><dc:creator>W4AFK</dc:creator></item><item><title>usb/or computer microphone by VAC entrance</title><link>http://forums.flexradio.com/Topic4902-56-1.aspx</link><description>hello,&lt;br&gt;Is it possible to get the audio from the microphone VAC, is avoid going through the sound card&lt;br&gt;flex 1500 directly in power sdr&lt;br&gt;Thanks to all 73's&lt;br&gt;F1HMR&lt;br&gt;Patrice</description><pubDate>Wed, 21 Sep 2011 06:52:43 GMT</pubDate><dc:creator>f1hmr</dc:creator></item><item><title>jt65-hf and Flex-1500</title><link>http://forums.flexradio.com/Topic4816-56-1.aspx</link><description>[size=5][b]I recently downloaded jt-65-hf for use with my Baby Flex.  It receives beautifully but I don't seem to be able to trigger the transmit with the software.  As a side note, I am using the VAC recommended by Dudly at flex (it IS free to Flex owners) and it works perfectly both transmit and receive with fldigi.[/b]&lt;br&gt;Pat.[/size][size=5][/size]</description><pubDate>Sat, 03 Sep 2011 21:13:18 GMT</pubDate><dc:creator>wa4eqw</dc:creator></item><item><title>PTT-Control-Cable for HLA-150plus</title><link>http://forums.flexradio.com/Topic4900-56-1.aspx</link><description>I want to connect my Amplifier HLA-150+ to my 1500 with a cable put in the flexwire-connector. How is it made correctly?&lt;br&gt;&lt;br&gt;73 de Konstantin</description><pubDate>Wed, 21 Sep 2011 06:42:45 GMT</pubDate><dc:creator>OE3KSS</dc:creator></item></channel></rss>
