﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / FLEX-3000 Discussions &amp; Operating Techniques / General  / Poor 1394 socket on Flex300 / Latest Posts</title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Fri, 18 May 2012 11:08:54 GMT</lastBuildDate><ttl>20</ttl><item><title>RE: Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>For me, the connector is rock solid. I use both the supplied 6x6 cable for the main shack computer and a 6x4 for the laptop, and neither of the 6 ends are loose on my F3k.&lt;/P&gt;&lt;P&gt;73&lt;/P&gt;&lt;P&gt;Simon M0BOX/G6BOX</description><pubDate>Thu, 26 Aug 2010 15:53:34 GMT</pubDate><dc:creator>m0box</dc:creator></item><item><title>RE: Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>I disagree with the statement that apple are to blame for the poor Firewire connector.&lt;/P&gt;&lt;P&gt;The mechanical specifications for the socket and the standard are &lt;STRONG&gt;IEEE specification&lt;/STRONG&gt;.&lt;/P&gt;&lt;P&gt;The mechanical specification calls for the cutout in the back plate to be the same shape as the socket.&lt;/P&gt;&lt;P&gt;This will and does prevent the wrong insertion of the plug.&lt;/P&gt;&lt;P&gt;Full specifications are available to &lt;STRONG&gt;IEEE members like me&lt;/STRONG&gt;.&lt;/P&gt;&lt;P&gt;Apple only holds the rights to the software as far as i know.&lt;/P&gt;&lt;P&gt;Bob&lt;/P&gt;&lt;P&gt;MW0PIC</description><pubDate>Wed, 25 Aug 2010 14:43:07 GMT</pubDate><dc:creator>mw0pic</dc:creator></item><item><title>RE: Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>Hi guys&lt;/P&gt;&lt;P&gt;I have investigated the problem wit the port and it is the PHY chip that has blown.&lt;/P&gt;&lt;P&gt;They are 64 pin SMD and cost £3.75 . and require SMD soldering skills.&lt;/P&gt;&lt;P&gt;If you are using a 4 pin FW cable this problem cannot happen as they have no power connections, only data, so no harm will occur if they are plugged in upside down.&lt;/P&gt;&lt;P&gt;I am sure other people will get this problem .&lt;/P&gt;&lt;P&gt;I will keep you informed.&lt;/P&gt;&lt;P&gt;The moral of this story is to use only 4 pin connectors at the PC end and to be extra carefull when reseating a loose plug.&lt;/P&gt;&lt;P&gt;This problem can also be caused by Hotpluging!&lt;/P&gt;&lt;P&gt;73&lt;/P&gt;&lt;P&gt;Bob</description><pubDate>Sun, 15 Aug 2010 08:01:23 GMT</pubDate><dc:creator>mw0pic</dc:creator></item><item><title>RE: Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>I agree there are not many options when using fire wire but it still would have been better to recess the socket a little to add some mechanical stability to such a poorly designed connector, my main PC has this and it does help substantially. &lt;/P&gt;&lt;P&gt;For me I am still unable to get the Flex-3000 to work properly after two weeks on either of two laptops so I have to be somewhat careful as i am constantly unplugging  the lead during my fault finding.</description><pubDate>Sat, 14 Aug 2010 09:40:11 GMT</pubDate><dc:creator>G6AHY</dc:creator></item><item><title>RE: Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>The physical connector design of the 1394a 6-pin interface is not the best engineered connector.  It doesn't provide much friction or a mechanical mechanism for securing the cable. We can blame Apple for that one.</description><pubDate>Sat, 14 Aug 2010 07:31:14 GMT</pubDate><dc:creator>w4tme</dc:creator></item><item><title>RE: Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>Hi&lt;/P&gt;&lt;P&gt;I also have the flex3000 and have noticed how weak the positioning of this connector is, why it was not recessed to give it a better mechanical support is beyond me. Good luck with getting yours fixed, are you sure the port is dead or is it just a faulty connector ?, if it is just the connector it is not a SM type and with a good eye and fine point solder tip you should be able to change it.</description><pubDate>Sat, 14 Aug 2010 04:32:24 GMT</pubDate><dc:creator>G6AHY</dc:creator></item><item><title>Poor 1394 socket on Flex300</title><link>http://forums.flexradio.com/Topic3080-55-1.aspx</link><description>Hi all.&lt;/P&gt;&lt;P&gt;I have some reservations about the Firewire conector on the Flex3000.&lt;/P&gt;&lt;P&gt;Mine was very loose and quite flimsy and kept falling out at the slightest movement of the radio.&lt;/P&gt;&lt;P&gt;Eventually Sod's law prevailed and it was plugged in the wrong way round !!!!!&lt;/P&gt;&lt;P&gt;This offered no resistance due to the flexing of the socket.&lt;/P&gt;&lt;P&gt;I now have a blown 1394 port on my radio!!!!!!!!.&lt;/P&gt;&lt;P&gt;I live in the UK so i am looking to get it repaired myself as Flex  say wrong connections are not covered in the waranty.&lt;/P&gt;&lt;P&gt;Has anyone experinced a similar problem?</description><pubDate>Fri, 13 Aug 2010 18:56:28 GMT</pubDate><dc:creator>mw0pic</dc:creator></item></channel></rss>
