﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / FLEX-5000 Software Defined Radio (A and C models) / Hardware  / Upload failed Firmware / Latest Posts</title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Fri, 18 May 2012 10:54:34 GMT</lastBuildDate><ttl>20</ttl><item><title>RE: Upload failed Firmware</title><link>http://forums.flexradio.com/Topic3111-51-1.aspx</link><description>Thank you, Al!&lt;P&gt;In the morning did not wake up the transeiver :-(((. &lt;/P&gt;&lt;P&gt;I wrote letters to support services. Waitng for an answer...&lt;/P&gt;&lt;P&gt;Yuri, UR4IX.</description><pubDate>Tue, 24 Aug 2010 06:17:38 GMT</pubDate><dc:creator>UR4IX</dc:creator></item><item><title>RE: Upload failed Firmware</title><link>http://forums.flexradio.com/Topic3111-51-1.aspx</link><description>If you have not already done so.. Try a an over night power off ( disconnect the radio from the power supply over night ) reset..  If it still does not work contact Flex support.&lt;br&gt;&lt;br&gt;</description><pubDate>Mon, 23 Aug 2010 17:47:28 GMT</pubDate><dc:creator>K0VM</dc:creator></item><item><title>Upload failed Firmware</title><link>http://forums.flexradio.com/Topic3111-51-1.aspx</link><description>During recording Firmware accidentally turn the power off Flex-5000A. Now the transceiver is not turn on using the front panel led power switch!</description><pubDate>Sat, 21 Aug 2010 02:16:01 GMT</pubDate><dc:creator>UR4IX</dc:creator></item></channel></rss>
