﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / Specifications Discussion / Computers </title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Fri, 18 May 2012 10:43:16 GMT</lastBuildDate><ttl>20</ttl><item><title>How to increase system performance</title><link>http://forums.flexradio.com/Topic5519-18-1.aspx</link><description>Trojans and malware applications down the line your personal information and sensitive data are at a stake irrespective of the prevailing PC data Protection . All your web movements are pried upon and all your personal credentials are treacherously stolen without you being totally unaware. Apart from the data theft, viruses are strong enough to impact your system adversely and deteriorate its performance.&lt;br&gt;&lt;br&gt;&lt;br&gt;[url=http://antivirus.igennie.net/pc-protection.html][b]PC Protection[/b][/url] | [url=http://www.igennie.net/aol-support.html][b]AOL Support[/b][/url]</description><pubDate>Mon, 26 Mar 2012 08:57:26 GMT</pubDate><dc:creator>Frad</dc:creator></item><item><title>Reset BIOS for a better performing HP laptop</title><link>http://forums.flexradio.com/Topic5515-18-1.aspx</link><description>BIOS is also functional and responsible when comes to control the system for booting up the operating system, stocked up on the computer hard drive. With an updated BIOS, the booting process becomes prompt and performs at its best of efficiency. This in turn improves the system performance, easily detect new devices and enhance the stability of the computer. With an adept HP Support the&lt;br&gt;&lt;br&gt;&lt;br&gt;[url=http://www.igennie.net/hp-support.html][b]HP Support[/b][/url]| [url=http://antivirus.igennie.net/pc-protection.html][b]PC Protection[/b][/url]</description><pubDate>Sat, 24 Mar 2012 08:29:39 GMT</pubDate><dc:creator>Frad</dc:creator></item><item><title>SDR-1000 no RF recieved</title><link>http://forums.flexradio.com/Topic4624-18-1.aspx</link><description>Just got a used FLEX SDR-1000 up and (sorta) running last night. System is AMD 2.8 dual core, 2 gig memory, vista32 and I am using the Edirol FA66 soundcard. Problem is that when using the radio, only signals present are internal system noise related. All cables are verified connected properly, seated firmly, etc. Running a 3 foot parallel cable. Had to manually enter the resource address into the LPT port info in PSDR as the dropdowns were incorrect. &lt;br&gt;&lt;br&gt;Other forums around the net point to a bad parallel card (I salvaged the MosChips PCI/Parallel from an old computer, my current computer doesn't have a parallel port native to the MB). &lt;br&gt;&lt;br&gt;Does this sound like the right direction to follow, and if so can anyone recommend a good brand of aftermarket pci parallel card known to work with PSDR/SDR-1000?&lt;br&gt;&lt;br&gt;Also would consider the FLEX parallel/usb adapter if I could locate one. Anyone have one that they want to sell?&lt;br&gt;&lt;br&gt;thanks in advance&lt;br&gt;Andy&lt;br&gt;&lt;br&gt;AE5YJ</description><pubDate>Thu, 21 Jul 2011 08:11:38 GMT</pubDate><dc:creator>AE5YJ</dc:creator></item><item><title>Flex 5000 vs. all high end Icom radio's</title><link>http://forums.flexradio.com/Topic2158-18-1.aspx</link><description>The Flex 5000 has 0.3 uV receiver sensitivity while all high end Icom's have 0.1 uV sensitivity.&lt;/P&gt;&lt;P&gt;Does this mean the Icom's can hear weak signals that the Flex 5000 may not even pick up???</description><pubDate>Fri, 08 Jan 2010 16:02:40 GMT</pubDate><dc:creator>joe smith</dc:creator></item><item><title>Windows 7</title><link>http://forums.flexradio.com/Topic1741-18-1.aspx</link><description>Dudley mentioned to me that there are some issues with windows 7 and Power SDR. I'm curious if anyone has explored the use of the Windows 7 beta or RC1 software and if there might be a workaround to get it to work with powersdr prior to a version of powersdr becoming available that is designed to work with it. thanks&lt;br&gt;Jim</description><pubDate>Sat, 16 May 2009 22:51:45 GMT</pubDate><dc:creator>KD7GND</dc:creator></item><item><title>Toshiba Satelite Notebook - FLEX-3000 - PowerSDR v2.0.16</title><link>http://forums.flexradio.com/Topic3968-18-1.aspx</link><description>I purchased a Toshiba Satelite notebook to run PowerSDR and control my FLEX-3000.  I read &lt;/P&gt;&lt;P&gt;the hardware and fire wire suggestions and decided to purchase the Manhattan Firewire 400 &lt;/P&gt;&lt;P&gt;ExpressCard/34.  It has a TI chipset and has two 1394a ports.  My laptop is Toshiba model &lt;/P&gt;&lt;P&gt;A655-S6095, Intel i5 with 4G RAM running WIN 7.  I Installed the Firewire card, PowerSDR &lt;/P&gt;&lt;P&gt;v2.0.16, and powered up the system.  I set the defaults buffer size to 1024 and sample rate &lt;/P&gt;&lt;P&gt;to 96Khz.  Pressed the Start button and the Pandapter froze.  I could toggle the "start" &lt;/P&gt;&lt;P&gt;button to toggle on/off and the Pandapter would run for a "cycle" then freeze. I tried &lt;/P&gt;&lt;P&gt;changing the Operation Modes in FlexRadio, changed the sample rate to 48Khz and buffer size &lt;/P&gt;&lt;P&gt;to 2048 and 512, Finally got it to run for a couple of minutes with 48Khz and buffer 2048, &lt;/P&gt;&lt;P&gt;but the pandapter display would still freeze after a few minutes.  Loaded WIN XP - same &lt;/P&gt;&lt;P&gt;result.  I read where sometimes the IRQ's are shared with the ExpressCard and went in to &lt;/P&gt;&lt;P&gt;the BIOS and tried changing IRQ prority, no change. I was pretty much convinced my problem &lt;/P&gt;&lt;P&gt;was Firewire related. &lt;/P&gt;&lt;P&gt;So decided to try a $40 Dynex Firewire 800 ExpressCard from Best Buy. It has a LSI FW643E &lt;/P&gt;&lt;P&gt;chipset and a 1394a and a 1394b port.  I did not see the LSI chipset in the compatible &lt;/P&gt;&lt;P&gt;list, and it cautioned about dual revision 1394 cards.  But, I had to get another data &lt;/P&gt;&lt;P&gt;point.  I installed it, set the FlexRadio to default 1024 buffer size, and 96Khz.  Powered &lt;/P&gt;&lt;P&gt;up and worked great,  no issues.  What a relief.  So wanted to pass along my experience in &lt;/P&gt;&lt;P&gt;hopes of helping other folks out there.  &lt;/P&gt;&lt;P&gt;Happy Flexing! &lt;BR&gt;Steve - KM4CJ </description><pubDate>Tue, 22 Feb 2011 20:35:18 GMT</pubDate><dc:creator>Steve_45</dc:creator></item><item><title>PowerSDR ver 2.0.16 on 17" MacBookPro Running Windows 7 under Boot Camp 3.2 for Flex 5000A</title><link>http://forums.flexradio.com/Topic3680-18-1.aspx</link><description>Hi, I am setting up a F5K to run on a MacBook Pro 17" laptop.  I discovered the hard way that you DO NOT want to select the legacy version of the 1394 OHCI Complaint Host Controller when running PowerSDR ver. 2.0.16 with Boot Camp 3.2 running Windows 7 Home Premium OS.  The FFT may work initially, but is not stable and will start locking up after a while.  When I reinstalled the default non-legacy 1394 OHCI version, the problem went away.&lt;br&gt;&lt;br&gt;CPU is 2.66 Ghz Intel Core i7 with 4 GB 1067 MHz DDR3 and Mac OS X ver. 10.6.5&lt;br&gt;Firewire: on motherboard (Lucent) using ver. 3.5.8028&lt;br&gt;Firmware: 2.0.7.0 (was originally 2.0.9.0 but somehow regressed to 2.0.7.0)&lt;br&gt;Sampling: 192K&lt;br&gt;Buffer: 1024&lt;br&gt;Mode: Safe mode 1 (runs fine under "normal" mode too).&lt;br&gt;&lt;br&gt;Now, if I can just get the transmitter section to work, I will be in the groove.  I suspect a loose BNC connector after a factory 2RCVR install.&lt;br&gt;&lt;br&gt;73&lt;br&gt;Paul WN7T&lt;br&gt;&lt;br&gt;</description><pubDate>Sat, 01 Jan 2011 19:20:14 GMT</pubDate><dc:creator>WN7T</dc:creator></item><item><title>Flex on MACs up and running</title><link>http://forums.flexradio.com/Topic3339-18-1.aspx</link><description>Hi Folks,&lt;/P&gt;&lt;P&gt;it looks like that flex driver and software run on MACs under XP SP3. I tested it with a MacbookPro 13" (late 2009 Edition) and iMAC (also 2009). &lt;/P&gt;&lt;P&gt;On both Systems XP SP3 installed via Bootcamp, the only real issue was that it took me some hours to find out that XP needs a firewire hotfix from Microsoft- available from knowledge base (hotfix #&lt;FONT face="Courier New"&gt;KB955408) &lt;/FONT&gt;&lt;/P&gt;&lt;P&gt;It's a Microsoft issue, not something from the Macs. After patching the hotfix the driver works fine on FW400. I haven't tried it yet on a VM under Snow Leopard, will do it when the weather gets cold.&lt;/P&gt;&lt;P&gt;comments welcome.&lt;/P&gt;&lt;P&gt;:)</description><pubDate>Wed, 03 Nov 2010 13:08:48 GMT</pubDate><dc:creator>SW</dc:creator></item><item><title>Notebook Recommendations for Flex (F3K)</title><link>http://forums.flexradio.com/Topic2627-18-1.aspx</link><description>My XP Notebook has taken its last gasp and I am going into the market place for a new notebook.  I know what my personal requirements for the notebook are.  Mainly nice big (at least 17") screen for my aging eyes!&lt;/P&gt;&lt;P&gt;I would be interested in having someone give me the recommended specs for a notebook I can use when going portable with my F3K.&lt;/P&gt;&lt;P&gt;I know I will need a Firewire preferaby with the TI chip.  Since I do Softrock stuff on occasion, I will also want a soundcard with a stereo line-in and line-out.&lt;/P&gt;&lt;P&gt;I am resigned to the fact that you are not going to find any more new XP computers  and that Windows 7 Home Premium 64 bit is the likeliest OS that will be found at the usual stores.&lt;/P&gt;&lt;P&gt;I am looking at I3 or I5 notebooks with 4GB.  Will this be enough?  Perhaps Neal has some input on this.  I cannot find through the SEARCH function anything on notebooks.&lt;/P&gt;&lt;P&gt;tx es 73 de robby wb5rvz&lt;/P&gt;&lt;P&gt;&lt;A href="http://www.wb5rvz.com/"&gt;www.wb5rvz.com&lt;/A&gt;</description><pubDate>Fri, 07 May 2010 14:15:19 GMT</pubDate><dc:creator>wb5rvz</dc:creator></item><item><title>Online Radio channels in pc</title><link>http://forums.flexradio.com/Topic1771-18-1.aspx</link><description>Hi Folks, have you ever used www.myradiomix.com? I was at my friend’s place and he highly recommends this website. We listened to live radio stations whole night. It’s actually pretty cool, given the multi cultural music available – sometimes makes it very soothing to listen to. There is no need for a PC TV card because the Radio stations are streamed through your internet connection. You get free automatic Radio station updates so it. Isn’t that cool? highly recommended, do try it out</description><pubDate>Thu, 04 Jun 2009 21:27:37 GMT</pubDate><dc:creator>Alexi1985</dc:creator></item><item><title>Trackball Mouse</title><link>http://forums.flexradio.com/Topic1857-18-1.aspx</link><description>Was looking around at a local Best Buy store and noticed the Logitech Trackball mouse.  The mouse I was using with my Flex 5000A was ok but since we use two monitors, it was cumbersome to drag the mouse over the operating table to bring the cursor where I need it fast enough.  I went ahead and purchased the Trackball ($40) since I had a feeling it would solve my problems.  It came with a program (CD) for changing the way certain things could function such as speed of the cursor, whether or not to lock the left button etc.   I liked the option of using it either wired PS2 or USB.  I opted for using it wired since a USB connection could possibly up the CPU usage gauge.  It took some practice to get it right but now am able to quickly move from one screen to the other with just a flick of the right thumb such as when running MixW on the left monitor and Power SDR on the right one.  It still has the center scroll button which is great for fine tuning stations.  I discovered afterwards that the Trackball is popular with many gamers and the software has that option if so desired.</description><pubDate>Thu, 13 Aug 2009 08:15:26 GMT</pubDate><dc:creator>K3ROJ</dc:creator></item><item><title>5000A Working Well with Vista 64 bit</title><link>http://forums.flexradio.com/Topic1664-18-1.aspx</link><description>Ah, at last thanks to one of the administrators, Tim W4TME, I am up and running well with my 5000A in all modes.  I had it working somewhat in Safe Mode using Vista 64 bit Ultimate but had to put up with "safe mode" warnings all over the screen.  Luckily Tim saw a posting on QRZ since I was somewhat distraught not being able to use my new Vista computer.  Right away Tim E-Mailed me and said to use the F8 key when booting up but instead of going into safe mode, to scoll on down and click on "Run software without signature signing".  I deleted my original firewire driver and started over again. Once I had accepted the unsigned statement, the firewire driver installed right away and then connected the 5000A after booting up after a computer restart.  After turning on the 5000A and running the SDR console, the receiver came to life with a nice sharp image.  At first I was a little disapointed since I couldn't transmit.  I sent Tim an E-Mail and he responded right away and asked if I had unchecked the "receive only" box.  As soon as I did that, I had full transmit capability.  My CW was woking but for some reason didnl't like my Begali key and read a post where someone had used two reed relays to switch the CW input.  It took me an hour to make one up and sure enough, the CW key then worked great.  Only problem now is, my wife hasn;t seen me for two days but hears my CW coming from the ham shack.  As lomg as I remember to keep hitting that F8 key when booting up the computer, I am in business.  Many thanks to Tim who is on the ball.  AL</description><pubDate>Thu, 19 Feb 2009 13:12:45 GMT</pubDate><dc:creator>K3ROJ</dc:creator></item><item><title>Dell processor and video card options</title><link>http://forums.flexradio.com/Topic1783-18-1.aspx</link><description>I'm getting ready to upgrade my computer and want to get one that will do more than get by with a 5000A radio.  I could spec a system but dell has a number of options, that if they will do the trick would probably work out as cheap if not cheaper.  &lt;P&gt;From what I've read, the Intel quad core works well but are there any issues to be aware of with the newer, supposedly faster i7 processor?  The Dell XPS 435 series features this processor. </description><pubDate>Thu, 11 Jun 2009 14:57:15 GMT</pubDate><dc:creator>rmw</dc:creator></item><item><title>MARS, etc.</title><link>http://forums.flexradio.com/Topic129-18-1.aspx</link><description>I am considering this radio, but the only transmitting frequency specs I see are for the amateur bands.  The majority of my operating is in Navy MARS.  I imagine that the radio would operate exactly as well outside the amateur bands, but would like that to be confirmed.&lt;br&gt;&lt;br&gt;Lee KN4GC/NNN0GBL/NNN0SYS&lt;br&gt;NC State NMC MARS Director&lt;br&gt;&lt;br&gt;</description><pubDate>Thu, 11 Jan 2007 11:17:54 GMT</pubDate><dc:creator>kn4gc</dc:creator></item><item><title>AMD or Intel</title><link>http://forums.flexradio.com/Topic1019-18-1.aspx</link><description>I am trying to specify the computer to use and I have been away from the details if the differences between Intel and AMD.&lt;br&gt;&lt;br&gt;In the past the Pentium had a better math co-processor than the AMD so it could do floating point math much faster. AMD made many assembler instructions take fewer clocks, so it could run most non-math intensive programs faster.&lt;br&gt;&lt;br&gt;Now AMD has a 64-bit processor, and Ubuntu has a specially compiled OS to take advantage of the 64-bit instructions. (I plan to use Ubuntu Linux.)&lt;br&gt;&lt;br&gt;Both have multi processor cores, dual and quad.&lt;br&gt;&lt;br&gt;My information is old so I do not know the details about the new processors.  &lt;br&gt;&lt;br&gt;So what is the recommended processor to hold me for a few years? Intel or AMD? Once I choose the processor, I can choose the motherboard.&lt;br&gt;&lt;br&gt;Is there a document on the website with recommended HW for the Flex-5000a I did not see it.&lt;br&gt;</description><pubDate>Mon, 16 Jun 2008 09:54:40 GMT</pubDate><dc:creator>kmoravec</dc:creator></item><item><title>Apple Computers &amp; FlexRadio</title><link>http://forums.flexradio.com/Topic27-18-1.aspx</link><description>Has anyone tried to use PowerSDR and SDR-1000 with an Intel based Apple computer running Windows XP? If so, are you using Parallels or Bootcamp? I'd like to use a MacBook laptop for my Flexradio setup.</description><pubDate>Sat, 28 Oct 2006 04:45:18 GMT</pubDate><dc:creator>LA2REA</dc:creator></item><item><title>Recommendations for add-on Parallel port card</title><link>http://forums.flexradio.com/Topic257-18-1.aspx</link><description>Does anyone have any recommendations for add-on parallel port cards.  My new PC does not have a parallel port and from my understanding the only way to have the SDR-1000 under vista is to the an actual parallel port.  Recommendations?&lt;/P&gt;&lt;P&gt;Thanks,&lt;/P&gt;&lt;P&gt;Jason N4OQ</description><pubDate>Tue, 17 Apr 2007 10:23:24 GMT</pubDate><dc:creator>N4OQ</dc:creator></item><item><title>What is minimum computer I would need to use the SDR-1000?</title><link>http://forums.flexradio.com/Topic85-18-1.aspx</link><description>I would like to know what is the minimum computer I would need to be using with the SDR-1000 and any brands that are not user friendly when hooked to the SDR? I have heard of some motherboards that have sound built onto them and is that a problem. TIA from a newby, 73' de aa8wl,&lt;br&gt;</description><pubDate>Sun, 10 Dec 2006 12:37:13 GMT</pubDate><dc:creator>aa8wl</dc:creator></item><item><title>Computer Setup - W4TME</title><link>http://forums.flexradio.com/Topic5-18-1.aspx</link><description>This is the PC configuration I am using for the SDR-1000 (full stack) with 100 Watt PA (parallel port for system control)&lt;UL&gt;&lt;LI&gt;Processor: AMD Athlon 64 X2 (dual core) +4400 (2.2 GHz clock speed)&lt;/LI&gt;&lt;LI&gt;Motherboard: MSI K8N Neo4 (PCI and PCI-eBus)&lt;/LI&gt;&lt;LI&gt;Sound Card: Edirol FA-66&lt;/LI&gt;&lt;LI&gt;Speakers: Klipsch ProMedia 2.0 &lt;/LI&gt;&lt;LI&gt;Firewire Interface: ADS Pyro PCI 64 (TI chipset)&lt;/LI&gt;&lt;LI&gt;RAM: 1 GB (dual channel DDR400)&lt;/LI&gt;&lt;LI&gt;Video: Nvidia GeForce 7600 GT&lt;/LI&gt;&lt;LI&gt;Hard Drives: Two 250 GB WD SATA Drives (using hardware RAID I)&lt;/LI&gt;&lt;LI&gt;Operating System: Window 2003 Server (32-bit)&lt;/LI&gt;&lt;LI&gt;Monitor: NEC LCD1970GX (LCD monitor)&lt;/LI&gt;&lt;LI&gt;USB Interface: Griffin PowerMate (black)&lt;/LI&gt;&lt;/UL&gt;&lt;br&gt;&lt;br&gt;Software:&lt;UL&gt;&lt;LI&gt;VAC 4.03&lt;/LI&gt;&lt;LI&gt;Vcom 226a&lt;/LI&gt;&lt;LI&gt;Prolog2K version 6.14 (logging)&lt;/LI&gt;&lt;LI&gt;Easylog 5.2.1.2 (logging)&lt;/LI&gt;&lt;LI&gt;MixW 2.17&lt;/LI&gt;&lt;LI&gt;HRD (current version)&lt;/LI&gt;&lt;LI&gt;Dream 1.6.1&lt;/LI&gt;&lt;/UL&gt;&lt;br&gt;&lt;br&gt;Audio Configuration:&lt;UL&gt;&lt;LI&gt;Microphone(s): Marshall MXL 6v, Marshall MXL 990 &amp;amp; Heil PR-20&lt;/LI&gt;&lt;LI&gt;Processing equipment: EQplus by W2IHY&lt;/LI&gt;&lt;/UL&gt;</description><pubDate>Sat, 07 Oct 2006 23:47:22 GMT</pubDate><dc:creator>w4tme</dc:creator></item></channel></rss>
