﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / Hardware / SDR-1000 Software Defined Radio  / Noise generated from Parallel Port / Latest Posts</title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Fri, 18 May 2012 10:40:41 GMT</lastBuildDate><ttl>20</ttl><item><title>Noise generated from Parallel Port</title><link>http://forums.flexradio.com/Topic409-15-1.aspx</link><description>The problem is most prevalent on 28 Mhz (also downconverted&lt;br&gt;144 Mhz).  When I drag the tuning, the parallel input port on the radio&lt;br&gt;causes noise in the audio and spectrum.  It does this even when the radio is&lt;br&gt;off.  Everything is grounded well and I tried an entirely different&lt;br&gt;computer and parallel cable.  I tried grounding different points with the radio off.  I found that grounding the 5volt line near the connector helped some.  I bypassed the 5 volt line at that point, but that did not cure the problem.  This noise also causes the XVTR Tx relay to clatter when that option is checked on the XVTR screen.   HELP!   Paul WA3GFZ</description><pubDate>Sun, 06 Jan 2008 12:24:58 GMT</pubDate><dc:creator>wa3gfz</dc:creator></item></channel></rss>
