﻿<?xml version='1.0' encoding='UTF-8'?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/"><channel><title>FlexRadio Systems Forums / Hardware / SDR-1000 Software Defined Radio </title><generator>InstantForum.NET v4.1.4</generator><description>FlexRadio Systems Forums</description><link>http://forums.flexradio.com/</link><webMaster>postmaster@flexradio-mailman.com</webMaster><lastBuildDate>Fri, 18 May 2012 10:38:30 GMT</lastBuildDate><ttl>20</ttl><item><title>SDR 1000 issue</title><link>http://forums.flexradio.com/Topic5176-15-1.aspx</link><description>I've been useing the sdr 1000 for a little over a year now and I LOVE IT. I have recieved 2 reports from the same guy that i am transmitting on 2 frequency. For example i was transmitting on 29.050 and he said i was also transmitting on 29.028. So i tuned in with another reciever and i cant find where its xmitting on another frequency.&lt;P&gt;I've been really paying attention today and i do recieve on 2 frequencys. For example ,, im listenin to a couple guys on 29.030 with a signal of -77.0 dbm. I also see the same signal on 29.058 with a signal of -125.0 dbm,, so the signal is much lower than the transmitted frequency but it does show up.&lt;/P&gt;&lt;P&gt;My qeustion is,, does anyone have any idea what might be goin on and what i can do to fix it.&lt;/P&gt;&lt;P&gt;Thanks , Billy.</description><pubDate>Sun, 04 Dec 2011 10:49:56 GMT</pubDate><dc:creator>KF5FWU</dc:creator></item><item><title>Wanted to buy a sdr1000</title><link>http://forums.flexradio.com/Topic4715-15-1.aspx</link><description>Wanted to buy a sdr 1000 , 100 watt, with a fa66 and prefer a 8 pin mic plug but will consider 4 pin, doesnt need tuner but would be nice,&lt;br&gt;email at rainesracing@aim.com&lt;br&gt;601-323-2774</description><pubDate>Wed, 10 Aug 2011 22:12:34 GMT</pubDate><dc:creator>KI5WK</dc:creator></item><item><title>Flex Radio demo and W7 64 bit</title><link>http://forums.flexradio.com/Topic2078-15-1.aspx</link><description>What's my chances of getting the demo software to run under w7-64. It wants to install .net (which won't run under W7).&lt;/P&gt;&lt;P&gt;73 de Chris VK5CP</description><pubDate>Sun, 13 Dec 2009 08:09:49 GMT</pubDate><dc:creator>vk5cp</dc:creator></item><item><title>Invalid Sampe Rate</title><link>http://forums.flexradio.com/Topic1612-15-1.aspx</link><description>I just got a Flex 1000. As soon as I click on the "Start" I get PORT AUDIO ERROR "Invalid Sample Rate"&lt;/P&gt;&lt;P&gt;Could anyone tell me what I need to do to fix this error?&lt;/P&gt;&lt;P&gt;73&lt;/P&gt;&lt;P&gt;KB3XE </description><pubDate>Sun, 25 Jan 2009 19:19:14 GMT</pubDate><dc:creator>jlsxe</dc:creator></item><item><title>Windows 7 64-bit</title><link>http://forums.flexradio.com/Topic2051-15-1.aspx</link><description>Is anyone successfully running on a 64 bit system.  All looks ready to go (using fa-66) but I can't get the radio to turn on.  I have tried two PCI express parallel adapter ports in new Gateway SX-2800 but I cannot bring the Flex to life.  It worked fine in an older Dell with a regular PCI/parallel card from SIIG.  Wonder if problem is PCI express?  So I'm not sure it's the card or the 64 bit vs 32 bit system.&lt;br&gt;</description><pubDate>Sun, 29 Nov 2009 18:38:44 GMT</pubDate><dc:creator>ki4yy</dc:creator></item><item><title>BEAUTIFUL SKINS FOR MODIFIED SDR</title><link>http://forums.flexradio.com/Topic1942-15-1.aspx</link><description>HELLO TO ALL&lt;br&gt;He left several skins for the SDR&lt;br&gt;BEAUTIFUL COLORS WITH THESE SKINS IS FOR&lt;br&gt;PrettyBetty, decompresses the RAR&lt;br&gt;Inside the folder PrettyBetty SKINS&lt;br&gt;&lt;br&gt;DOWNLOAD HERE &lt;br&gt;http://rapidshare.com/files/283591417/SKINS.rar.html  &lt;br&gt;&lt;br&gt; HI8JRG	&lt;br&gt;THANKS</description><pubDate>Tue, 22 Sep 2009 15:25:11 GMT</pubDate><dc:creator>HI8JRG</dc:creator></item><item><title>SDR-1000 Transmit Frequency Limitations</title><link>http://forums.flexradio.com/Topic1698-15-1.aspx</link><description>Having just acquired my SDR-1000 I want to modify the allowable transmit frequencies to align with my microwave transverters - but I can't find any information on where this is set.  Looked through the handbook/userguides, and I may be missing something somewhere, but any help would be appreciated!&lt;br&gt;&lt;br&gt;Thanks for any help!&lt;br&gt;&lt;br&gt;73,&lt;br&gt;Dave</description><pubDate>Mon, 16 Mar 2009 11:03:12 GMT</pubDate><dc:creator>G4HUP</dc:creator></item><item><title>Deaf SDR-1000</title><link>http://forums.flexradio.com/Topic1651-15-1.aspx</link><description>I bought a used SDR-1000 (basic QRP with no ATU) and it worked great for a few days. It had all the updates including better preamp on the RFE and overload protection diodes installed at the factory. After a day or two of fun, I tuned to the Broadcast Band and was listening to a local AM station. After listening for a half hour or so I heard a sort of "hiss" in the audio that lasted a second or two. The audio dropped out and came back on. I thought the station had gone off the air temporarily and paid little attention to it. When I came back to the screen later, I noticed the signal was S-9 instead of the 40 over that it was before. BTW, I had the preamp set to low because the signal was very strong even though the station is 10mi away. When I switched back to the Ham Bands or any HF frequency, there were no signals. I can still hear strong Broadcast stations on the AM band though. Otherwise, there's lots of "noise" in the Panadapter but no signals. I have tried another Delta 44 card and no change. With my old tranceiver on dummy load, I can transmit and hear the signal on the Flex. Changing the preamp settings on the Flex does seem to affect the level of the weak received signal from my other rig, so I'm thinking it may not be the preamp. Also, when I connect and disconnect the antenna from the Flex, there is no noticable difference in noise. I have even tried using a signal generator to inject a weak signal after the bandpass board and the receiver is still almost deaf.&lt;P&gt;Help anyone?&lt;/P&gt;&lt;P&gt;Daryl, VE1DAS</description><pubDate>Sun, 15 Feb 2009 09:34:58 GMT</pubDate><dc:creator>VE1DAS</dc:creator></item><item><title>looking for sdr-1000</title><link>http://forums.flexradio.com/Topic1402-15-1.aspx</link><description>Looking to buy another sdr-1000. Looking for the 100watt pa and sound card .Delta preferred.&lt;/P&gt;&lt;P&gt;thanks for reading.&lt;/P&gt;&lt;P&gt;dale wt4t&lt;/P&gt;&lt;P&gt;&lt;A href="mailto:yash@aol.com"&gt;yash@aol.com&lt;/A&gt;</description><pubDate>Wed, 19 Nov 2008 16:04:00 GMT</pubDate><dc:creator>wt4t</dc:creator></item><item><title>15 meter High SWR faults  .. fixed</title><link>http://forums.flexradio.com/Topic748-15-1.aspx</link><description>For some time PSDR has been giving indications of HIGH SWR on 15 meter band even though external indications were &lt; 1.5: 1.   These occurred on voice peaks, or High output CW  (tune) &gt; 80 watts.  Readings were normal a low power and then suddenly indications of High SWR and several hundred watts output on PSDR with normal readings on external meter. &lt;br&gt;After some debugging I discovered the that the readings were caused by RF pickup on the digital line running between the PA and the TRX board.  This signal is routed in a multiconductor shielded cable between the PA and the RFE board and then a single unshielded wire from the RFE board (J3) to the TRX board.   Replacing the unshielded wire with a shielded wire grounded at the RFE J3 connector solved my problem.&lt;br&gt;&lt;br&gt;Al, K0VM</description><pubDate>Sat, 19 Apr 2008 18:03:07 GMT</pubDate><dc:creator>K0VM</dc:creator></item><item><title>SDR-1000 No TR transition on RFE J2</title><link>http://forums.flexradio.com/Topic498-15-1.aspx</link><description>I have a weird problem with either my RFE board or software setup.&lt;br&gt;&lt;br&gt;As you know, the J2 connector on the RFE board is used for the internal or the external transverter.&lt;br&gt;&lt;br&gt;RF wise, the port is working. I fed in a signal from a generator to this port and it receives well. Measured the output during transmit and got 0.8dBm on this port. All within spec.&lt;br&gt;&lt;br&gt;The problem is with the TTL TR signal that is supposed to be with the RF on this connector. If I set it up with Positive TR Logic, then the DC voltage on this connector stays at 0v whether I am transmitting or not. If I set it up with Negative TR Logic, then the voltage stays at 5V whether I am transmitting or not. The problem is that it is not making a transition from 0 to 5V or vice-versa. &lt;br&gt;&lt;br&gt;This has me baffled.&lt;br&gt;&lt;br&gt;Any help appreciated.&lt;br&gt;&lt;br&gt;Thanks,&lt;br&gt;Raj, N2RD&lt;br&gt;SDR-1000 #0611-9435 &lt;br&gt;&lt;br&gt;Raj, N2RD&lt;br&gt;SDR1K, K3</description><pubDate>Fri, 29 Feb 2008 20:06:24 GMT</pubDate><dc:creator>n2rd</dc:creator></item><item><title>Noise generated from Parallel Port</title><link>http://forums.flexradio.com/Topic409-15-1.aspx</link><description>The problem is most prevalent on 28 Mhz (also downconverted&lt;br&gt;144 Mhz).  When I drag the tuning, the parallel input port on the radio&lt;br&gt;causes noise in the audio and spectrum.  It does this even when the radio is&lt;br&gt;off.  Everything is grounded well and I tried an entirely different&lt;br&gt;computer and parallel cable.  I tried grounding different points with the radio off.  I found that grounding the 5volt line near the connector helped some.  I bypassed the 5 volt line at that point, but that did not cure the problem.  This noise also causes the XVTR Tx relay to clatter when that option is checked on the XVTR screen.   HELP!   Paul WA3GFZ</description><pubDate>Sun, 06 Jan 2008 12:24:58 GMT</pubDate><dc:creator>wa3gfz</dc:creator></item><item><title>Clicking relay during tuning in transverter mode</title><link>http://forums.flexradio.com/Topic408-15-1.aspx</link><description>Hello all, Just got the 2 meter unit hooked up.  This is a factory built unit.  The keying polarity is opposite of what it says it should be.  When I tune using the mouse wheel, a relay clicks proportional to the mouse wheel's motion.  I tried changing the polarity as well as TX enable in the transverter screen, but nothing cured it.  Thanks for any help.  Paul WA3GFZ&lt;br&gt;&lt;br&gt;I subsequently found that the TX RX B+ lines were wired backwards at the DEMI factory.  So much for testing before shipping.   But the relay is still clicking due to noise induced by the parallel port.&lt;br&gt;</description><pubDate>Wed, 02 Jan 2008 00:30:54 GMT</pubDate><dc:creator>wa3gfz</dc:creator></item><item><title>sdr pc board</title><link>http://forums.flexradio.com/Topic386-15-1.aspx</link><description>just came across the ac5og's excellent articles  about SDR on 2002 QEX, &lt;br&gt;relating to pc board(s), so here to ask where  are available.&lt;br&gt;Spotted the Linux gnu software and planning to give it a try .&lt;br&gt;tia, regards</description><pubDate>Wed, 31 Oct 2007 04:41:06 GMT</pubDate><dc:creator>hamgio</dc:creator></item><item><title>Fan Noise</title><link>http://forums.flexradio.com/Topic80-15-1.aspx</link><description>Has anyone disabled the fan or otherwise limited the noise via a resistor, rheostat or some sort of thermistor?</description><pubDate>Thu, 07 Dec 2006 10:41:58 GMT</pubDate><dc:creator>ki4yy</dc:creator></item><item><title>Frequency problem with my new bought SDR-1000</title><link>http://forums.flexradio.com/Topic310-15-1.aspx</link><description>Hello to all.&lt;P&gt;I'm new with the SDR and a think there is a problem.&lt;/P&gt;&lt;P&gt;Equipment: SDR-100 + ATU + 100W PA + 2m XVTR&lt;/P&gt;&lt;P&gt;When i check the receive frequency it changes from time to time. The difference to a reference transceiver is up to -120kHz and it's not possible to calibrate over this wide range. &lt;/P&gt;&lt;P&gt;Please have anyone an idea what's going wrong????&lt;/P&gt;&lt;P&gt;73 de OE8CCQ / Hans-Peter</description><pubDate>Sat, 23 Jun 2007 17:26:46 GMT</pubDate><dc:creator>OE8CCQ</dc:creator></item><item><title>6M</title><link>http://forums.flexradio.com/Topic280-15-1.aspx</link><description>HI ALL&lt;/P&gt;&lt;P&gt;I AM NEW TO SDR&lt;/P&gt;&lt;P&gt;SO I AM THINKING OF GETING THE SDR 100 TO START  WITH&lt;/P&gt;&lt;P&gt;CAN ANY ONE TELL ME WHY  EVEN WITH THE 100W VERSION THE OUTPUT ON THE 6M BAND IS IS ONLY 500MW &lt;/P&gt;&lt;P&gt;IS THERE ANY WAY TO BOOST IT ON 6M  TO GET 100W&lt;/P&gt;&lt;P&gt;THX&lt;/P&gt;&lt;P&gt;ROSS</description><pubDate>Mon, 07 May 2007 06:54:07 GMT</pubDate><dc:creator>M0GTT</dc:creator></item><item><title>SDR-1000 RFE board schematics</title><link>http://forums.flexradio.com/Topic233-15-1.aspx</link><description>Hi,&lt;br&gt;&lt;br&gt;Just bought a SDR-1000.&lt;br&gt;Now try to find out how all schematics fit together.&lt;br&gt;&lt;br&gt;I found all that and downloaded it:&lt;br&gt;SDR-1000_schematics.pdf                  containing PIO,TRX and BPF&lt;br&gt;100WPA_v1.3B_Schematics.pdf           containing PA&lt;br&gt;RFE_v1.4a_Schematics.pdf                 containing RFE&lt;br&gt;&lt;br&gt;but that RFE laylout is not up to date. It contains the SGA-4586 &lt;br&gt;This schould be the SGA-8286 and the resistor R2 should be different.&lt;br&gt;(see ECO025-RFE_Preamplifier_Upgrade.pdf)&lt;br&gt;&lt;br&gt;Where can I find the scematic of the RFE board, that I have bought ?&lt;br&gt;&lt;br&gt;73 de DK9NW Bernhard &lt;br&gt;&lt;br&gt;</description><pubDate>Mon, 09 Apr 2007 07:50:01 GMT</pubDate><dc:creator>dk9nw</dc:creator></item><item><title>Standby</title><link>http://forums.flexradio.com/Topic84-15-1.aspx</link><description>Hi &lt;P&gt;I am new to all this SDR but it seems to me that the solution to the problem of how much energy is being wasted lays with the owner who could switch it off if he thinks he can not afford a few pence on the electricity bill. I am sure Flex-radio are aware of this issue and feel that it is something that does not need addressing.&lt;/P&gt;&lt;P&gt;There are only two alternatives to this problem. Either stick with it or go back to the whistles and bells and the multitude of never used usless buttons on a conventional rig.</description><pubDate>Sat, 09 Dec 2006 06:25:58 GMT</pubDate><dc:creator>shelldrake</dc:creator></item><item><title>SDR-1000 for sale</title><link>http://forums.flexradio.com/Topic83-15-1.aspx</link><description>Basic 1W system with RFE board.  NO CASE, NO CABLES, NO PS.  $450 PayPal or MO only.&lt;br&gt;&lt;br&gt;I picked this up from a previous owner who (I believe) purchased it new in 2004.  No mods that I can see although it does appear to have a factory-installed daughterboard installed.  I seem to remember something about an upgraded oscillator/clock - anyway, it has that as well.  I played with it for awhile but never used it for transmit.&lt;br&gt;&lt;br&gt;paul@ermisch.com</description><pubDate>Fri, 08 Dec 2006 23:08:35 GMT</pubDate><dc:creator>Paul Ermisch</dc:creator></item><item><title>ATU overpriced!</title><link>http://forums.flexradio.com/Topic32-15-1.aspx</link><description>The LDG Z100 has a suggested price from LDG of USD149.... Looking at the Flex-Radio pricinginfo &lt;br&gt;I fint that this option comes for USD235 from Flex-Radio.&lt;br&gt;&lt;br&gt;That is quite some difference for the same unit. Iám not impressed and awaiting &lt;br&gt;a good reason for the pricedifference.&lt;br&gt;&lt;br&gt;Until then I feel that Flex-Radio are selling a fairly overpriced unit with teh SDR1000.</description><pubDate>Sun, 29 Oct 2006 12:08:39 GMT</pubDate><dc:creator>sm0jzt</dc:creator></item><item><title>High stand by current - A fault?</title><link>http://forums.flexradio.com/Topic31-15-1.aspx</link><description>Hi there&lt;br&gt;I have a brand new SDR-1000 her at home for evaluation.&lt;br&gt;&lt;br&gt;I have found that the unit pulls 840mA from the 13.8 supply during stand by (big switch off).&lt;br&gt;When Switch on the unit pulls 930mA.&lt;br&gt;&lt;br&gt;I´m sure there must be something wrong with the unit. This as I can not get any power out&lt;br&gt;of the 100W PA. I have not yet tried the exiter-part to veryfy if there something wrong&lt;br&gt;with this to start with.&lt;br&gt;&lt;br&gt;Anyway. Any other of you having the experience of a very high current drawn in standby ?&lt;br&gt;&lt;br&gt;(the PA heatsink gets warm during stand by of course )</description><pubDate>Sun, 29 Oct 2006 11:33:27 GMT</pubDate><dc:creator>sm0jzt</dc:creator></item></channel></rss>
