The following information about the error was automatically captured:
• details were written to a text log at:
C:\HostingSpaces\frssdr\forums.flex-radio.com\wwwroot\Forums\Exceptions.config
Detailed error information follows:
Date and Time: 2/4/2012 9:29:40 PM
Machine Name: ORCHID
Process User: ORCHID\forumsflexradi_web
Remote User:
Remote Address: 38.107.179.232
Remote Host: 38.107.179.232
URL: http://forums.flexradio.com/Messages.aspx?ForumID=6&PageIndex=1
NET Runtime version: 2.0.50727.4214
Application Domain: /LM/W3SVC/227/ROOT-1-129728756149643830
Assembly Codebase: C:/HostingSpaces/frssdr/forums.flex-radio.com/wwwroot/Forums/bin/InstantASP.InstantForum.UI.DLL
Assembly Full Name: InstantASP.InstantForum.UI, Version=4.1.4.0, Culture=neutral, PublicKeyToken=null
Assembly Version: 4.1.4.0
Assembly Build Date: 11/1/2011 2:47:17 PM
Exception Type: System.NullReferenceException
Exception Message: Object reference not set to an instance of an object.
Exception Source: InstantASP.InstantForum.UI
Exception Target Site: Initialize
---- Stack Trace ----
InstantASP.InstantForum.UI.Controls.Messages.Initialize(ctlSkin As Control)
(unknown file): N 01364
InstantASP.Common.UI.Base.Skin.CreateChildControls()
(unknown file): N 00087
InstantASP.InstantForum.UI.Skinning.Base.CreateChildControls()
(unknown file): N 00107
System.Web.UI.Control.EnsureChildControls()
System.Web.UI.Control.PreRenderRecursiveInternal()
(unknown file): N 00044
(unknown file): N 00171
System.Web.UI.Page.ProcessRequestMain(includeStagesBeforeAsyncPoint As Boolean, includeStagesAfterAsyncPoint As Boolean)
(unknown file): N 00842
---- Collections ----
QueryString
ForumID 6
PageIndex 1
Cookies
IF_TopicsRead586 586%7c2%2f4%2f2012+8%3a52%3a02+PM
ASP.NET_SessionId e2x2ufer20woto45sadks155
IF_LastVisit 2%2f4%2f2012+8%3a54%3a10+PM
IF_ForumsRead15 15%7c2%2f4%2f2012+8%3a59%3a15+PM
IF_TopicsRead409 409%7c2%2f4%2f2012+8%3a59%3a15+PM
IF_TopicsRead2256 2256%7c2%2f4%2f2012+8%3a59%3a34+PM
IF_TopicsRead2937 2937%7c2%2f4%2f2012+8%3a59%3a57+PM
IF_TopicsRead2930 2930%7c2%2f4%2f2012+9%3a00%3a20+PM
IF_TopicsRead3036 3036%7c2%2f4%2f2012+9%3a00%3a43+PM
IF_TopicsRead2538 2538%7c2%2f4%2f2012+9%3a01%3a02+PM
IF_TopicsRead3042 3042%7c2%2f4%2f2012+9%3a01%3a22+PM
IF_TopicsRead2765 2765%7c2%2f4%2f2012+9%3a01%3a45+PM
IF_TopicsRead2382 2382%7c2%2f4%2f2012+9%3a02%3a03+PM
IF_TopicsRead2774 2774%7c2%2f4%2f2012+9%3a02%3a21+PM
IF_ForumsRead56 56%7c2%2f4%2f2012+9%3a11%3a22+PM
IF_TopicsRead3165 3165%7c2%2f4%2f2012+9%3a11%3a22+PM
IF_ForumsRead55 55%7c2%2f4%2f2012+9%3a21%3a47+PM
IF_TopicsRead3080 3080%7c2%2f4%2f2012+9%3a21%3a47+PM
IF_ForumsRead43 43%7c2%2f4%2f2012+9%3a22%3a07+PM
IF_TopicsRead2698 2698%7c2%2f4%2f2012+9%3a22%3a07+PM
IF_ForumsRead46 46%7c2%2f4%2f2012+9%3a22%3a27+PM
IF_TopicsRead3091 3091%7c2%2f4%2f2012+9%3a22%3a27+PM
IF_ForumsRead41 41%7c2%2f4%2f2012+9%3a22%3a50+PM
IF_TopicsRead3147 3147%7c2%2f4%2f2012+9%3a22%3a50+PM
IF_ForumsRead40 40%7c2%2f4%2f2012+9%3a23%3a08+PM
IF_TopicsRead2973 2973%7c2%2f4%2f2012+9%3a23%3a08+PM
IF_ForumsRead48 48%7c2%2f4%2f2012+9%3a23%3a31+PM
IF_TopicsRead3149 3149%7c2%2f4%2f2012+9%3a23%3a31+PM
IF_ForumsRead44 44%7c2%2f4%2f2012+9%3a23%3a54+PM
IF_TopicsRead2333 2333%7c2%2f4%2f2012+9%3a23%3a54+PM
IF_ForumsRead50 50%7c2%2f4%2f2012+9%3a24%3a19+PM
IF_TopicsRead2711 2711%7c2%2f4%2f2012+9%3a24%3a19+PM
ServerVariables
APPL_MD_PATH /LM/W3SVC/227/ROOT
APPL_PHYSICAL_PATH C:\HostingSpaces\frssdr\forums.flex-radio.com\wwwroot\Forums\
CONTENT_LENGTH 0
GATEWAY_INTERFACE CGI/1.1
HTTPS off
INSTANCE_ID 227
INSTANCE_META_PATH /LM/W3SVC/227
LOCAL_ADDR 174.36.134.128
PATH_INFO /Messages.aspx
PATH_TRANSLATED C:\HostingSpaces\frssdr\forums.flex-radio.com\wwwroot\Forums\Messages.aspx
QUERY_STRING ForumID=6&PageIndex=1
REMOTE_ADDR 38.107.179.232
REMOTE_HOST 38.107.179.232
REMOTE_PORT 38828
REQUEST_METHOD GET
SCRIPT_NAME /Messages.aspx
SERVER_NAME forums.flexradio.com
SERVER_PORT 80
SERVER_PORT_SECURE 0
SERVER_PROTOCOL HTTP/1.1
SERVER_SOFTWARE Microsoft-IIS/7.0
URL /Messages.aspx
HTTP_CACHE_CONTROL no-cache
HTTP_CONNECTION close
HTTP_PRAGMA no-cache
HTTP_ACCEPT text/html,application/xhtml+xml,text/xml;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.7
HTTP_ACCEPT_ENCODING gzip
HTTP_ACCEPT_LANGUAGE en-us,en;q=0.5
HTTP_COOKIE IF_TopicsRead586=586%7c2%2f4%2f2012+8%3a52%3a02+PM; ASP.NET_SessionId=e2x2ufer20woto45sadks155; IF_LastVisit=2%2f4%2f2012+8%3a54%3a10+PM; IF_ForumsRead15=15%7c2%2f4%2f2012+8%3a59%3a15+PM; IF_TopicsRead409=409%7c2%2f4%2f2012+8%3a59%3a15+PM; IF_TopicsRead2256=2256%7c2%2f4%2f2012+8%3a59%3a34+PM; IF_TopicsRead2937=2937%7c2%2f4%2f2012+8%3a59%3a57+PM; IF_TopicsRead2930=2930%7c2%2f4%2f2012+9%3a00%3a20+PM; IF_TopicsRead3036=3036%7c2%2f4%2f2012+9%3a00%3a43+PM; IF_TopicsRead2538=2538%7c2%2f4%2f2012+9%3a01%3a02+PM; IF_TopicsRead3042=3042%7c2%2f4%2f2012+9%3a01%3a22+PM; IF_TopicsRead2765=2765%7c2%2f4%2f2012+9%3a01%3a45+PM; IF_TopicsRead2382=2382%7c2%2f4%2f2012+9%3a02%3a03+PM; IF_TopicsRead2774=2774%7c2%2f4%2f2012+9%3a02%3a21+PM; IF_ForumsRead56=56%7c2%2f4%2f2012+9%3a11%3a22+PM; IF_TopicsRead3165=3165%7c2%2f4%2f2012+9%3a11%3a22+PM; IF_ForumsRead55=55%7c2%2f4%2f2012+9%3a21%3a47+PM; IF_TopicsRead3080=3080%7c2%2f4%2f2012+9%3a21%3a47+PM; IF_ForumsRead43=43%7c2%2f4%2f2012+9%3a22%3a07+PM; IF_TopicsRead2698=2698%7c2%2f4%2f2012+9%3a22%3a07+PM; IF_ForumsRead46=46%7c2%2f4%2f2012+9%3a22%3a27+PM; IF_TopicsRead3091=3091%7c2%2f4%2f2012+9%3a22%3a27+PM; IF_ForumsRead41=41%7c2%2f4%2f2012+9%3a22%3a50+PM; IF_TopicsRead3147=3147%7c2%2f4%2f2012+9%3a22%3a50+PM; IF_ForumsRead40=40%7c2%2f4%2f2012+9%3a23%3a08+PM; IF_TopicsRead2973=2973%7c2%2f4%2f2012+9%3a23%3a08+PM; IF_ForumsRead48=48%7c2%2f4%2f2012+9%3a23%3a31+PM; IF_TopicsRead3149=3149%7c2%2f4%2f2012+9%3a23%3a31+PM; IF_ForumsRead44=44%7c2%2f4%2f2012+9%3a23%3a54+PM; IF_TopicsRead2333=2333%7c2%2f4%2f2012+9%3a23%3a54+PM; IF_ForumsRead50=50%7c2%2f4%2f2012+9%3a24%3a19+PM; IF_TopicsRead2711=2711%7c2%2f4%2f2012+9%3a24%3a19+PM
HTTP_HOST forums.flexradio.com
HTTP_USER_AGENT CCBot/1.0 (+http://www.commoncrawl.org/bot.html)
HTTP_X_CC_ID ccc03-02
