The application encountered an unexpected problem.
Unexpected Problem Occurred!
This error has been logged. If this problem persists please contact the web master.
More Information...
The following information about the error was automatically captured:
 • details were written to a text log at:
   C:\HostingSpaces\frssdr\forums.flex-radio.com\wwwroot\Forums\Exceptions.config
Detailed error information follows:
Date and Time:         2/4/2012 9:16:33 PM
Machine Name:          ORCHID
Process User:          ORCHID\forumsflexradi_web
Remote User:
Remote Address:        38.107.179.232
Remote Host:           38.107.179.232
URL:                   http://forums.flexradio.com/Messages.aspx?ForumID=39&PageIndex=1
NET Runtime version:   2.0.50727.4214
Application Domain:    /LM/W3SVC/227/ROOT-1-129728756149643830
Assembly Codebase:     C:/HostingSpaces/frssdr/forums.flex-radio.com/wwwroot/Forums/bin/InstantASP.InstantForum.UI.DLL
Assembly Full Name:    InstantASP.InstantForum.UI, Version=4.1.4.0, Culture=neutral, PublicKeyToken=null
Assembly Version:      4.1.4.0
Assembly Build Date:   11/1/2011 2:47:17 PM
Exception Type:        System.NullReferenceException
Exception Message:     Object reference not set to an instance of an object.
Exception Source:      InstantASP.InstantForum.UI
Exception Target Site: Initialize
---- Stack Trace ----
   InstantASP.InstantForum.UI.Controls.Messages.Initialize(ctlSkin As Control)
       (unknown file): N 01364
   InstantASP.Common.UI.Base.Skin.CreateChildControls()
       (unknown file): N 00087
   InstantASP.InstantForum.UI.Skinning.Base.CreateChildControls()
       (unknown file): N 00107
   System.Web.UI.Control.EnsureChildControls()
   System.Web.UI.Control.PreRenderRecursiveInternal()
       (unknown file): N 00044
       (unknown file): N 00171
   System.Web.UI.Page.ProcessRequestMain(includeStagesBeforeAsyncPoint As Boolean, includeStagesAfterAsyncPoint As Boolean)
       (unknown file): N 00842
---- Collections ----
QueryString
    ForumID                       39
    PageIndex                     1
Cookies
    IF_TopicsRead586              586%7c2%2f4%2f2012+8%3a52%3a02+PM
    ASP.NET_SessionId             e2x2ufer20woto45sadks155
    IF_LastVisit                  2%2f4%2f2012+8%3a54%3a10+PM
    IF_ForumsRead15               15%7c2%2f4%2f2012+8%3a59%3a15+PM
    IF_TopicsRead409              409%7c2%2f4%2f2012+8%3a59%3a15+PM
    IF_TopicsRead2256             2256%7c2%2f4%2f2012+8%3a59%3a34+PM
    IF_TopicsRead2937             2937%7c2%2f4%2f2012+8%3a59%3a57+PM
    IF_TopicsRead2930             2930%7c2%2f4%2f2012+9%3a00%3a20+PM
    IF_TopicsRead3036             3036%7c2%2f4%2f2012+9%3a00%3a43+PM
    IF_TopicsRead2538             2538%7c2%2f4%2f2012+9%3a01%3a02+PM
    IF_TopicsRead3042             3042%7c2%2f4%2f2012+9%3a01%3a22+PM
    IF_TopicsRead2765             2765%7c2%2f4%2f2012+9%3a01%3a45+PM
    IF_TopicsRead2382             2382%7c2%2f4%2f2012+9%3a02%3a03+PM
    IF_TopicsRead2774             2774%7c2%2f4%2f2012+9%3a02%3a21+PM
    IF_ForumsRead40               40%7c2%2f4%2f2012+9%3a02%3a40+PM
    IF_ForumsRead56               56%7c2%2f4%2f2012+9%3a11%3a22+PM
    IF_TopicsRead3165             3165%7c2%2f4%2f2012+9%3a11%3a22+PM
    IF_ForumsRead43               43%7c2%2f4%2f2012+9%3a14%3a56+PM
    IF_ForumsRead50               50%7c2%2f4%2f2012+9%3a15%3a23+PM
    IF_ForumsRead41               41%7c2%2f4%2f2012+9%3a15%3a45+PM
    IF_ForumsRead55               55%7c2%2f4%2f2012+9%3a16%3a12+PM
ServerVariables
    APPL_MD_PATH                  /LM/W3SVC/227/ROOT
    APPL_PHYSICAL_PATH            C:\HostingSpaces\frssdr\forums.flex-radio.com\wwwroot\Forums\
    CONTENT_LENGTH                0
    GATEWAY_INTERFACE             CGI/1.1
    HTTPS                         off
    INSTANCE_ID                   227
    INSTANCE_META_PATH            /LM/W3SVC/227
    LOCAL_ADDR                    174.36.134.128
    PATH_INFO                     /Messages.aspx
    PATH_TRANSLATED               C:\HostingSpaces\frssdr\forums.flex-radio.com\wwwroot\Forums\Messages.aspx
    QUERY_STRING                  ForumID=39&PageIndex=1
    REMOTE_ADDR                   38.107.179.232
    REMOTE_HOST                   38.107.179.232
    REMOTE_PORT                   36103
    REQUEST_METHOD                GET
    SCRIPT_NAME                   /Messages.aspx
    SERVER_NAME                   forums.flexradio.com
    SERVER_PORT                   80
    SERVER_PORT_SECURE            0
    SERVER_PROTOCOL               HTTP/1.1
    SERVER_SOFTWARE               Microsoft-IIS/7.0
    URL                           /Messages.aspx
    HTTP_CACHE_CONTROL            no-cache
    HTTP_CONNECTION               close
    HTTP_PRAGMA                   no-cache
    HTTP_ACCEPT                   text/html,application/xhtml+xml,text/xml;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
    HTTP_ACCEPT_CHARSET           ISO-8859-1,utf-8;q=0.7,*;q=0.7
    HTTP_ACCEPT_ENCODING          gzip
    HTTP_ACCEPT_LANGUAGE          en-us,en;q=0.5
    HTTP_COOKIE                   IF_TopicsRead586=586%7c2%2f4%2f2012+8%3a52%3a02+PM; ASP.NET_SessionId=e2x2ufer20woto45sadks155; IF_LastVisit=2%2f4%2f2012+8%3a54%3a10+PM; IF_ForumsRead15=15%7c2%2f4%2f2012+8%3a59%3a15+PM; IF_TopicsRead409=409%7c2%2f4%2f2012+8%3a59%3a15+PM; IF_TopicsRead2256=2256%7c2%2f4%2f2012+8%3a59%3a34+PM; IF_TopicsRead2937=2937%7c2%2f4%2f2012+8%3a59%3a57+PM; IF_TopicsRead2930=2930%7c2%2f4%2f2012+9%3a00%3a20+PM; IF_TopicsRead3036=3036%7c2%2f4%2f2012+9%3a00%3a43+PM; IF_TopicsRead2538=2538%7c2%2f4%2f2012+9%3a01%3a02+PM; IF_TopicsRead3042=3042%7c2%2f4%2f2012+9%3a01%3a22+PM; IF_TopicsRead2765=2765%7c2%2f4%2f2012+9%3a01%3a45+PM; IF_TopicsRead2382=2382%7c2%2f4%2f2012+9%3a02%3a03+PM; IF_TopicsRead2774=2774%7c2%2f4%2f2012+9%3a02%3a21+PM; IF_ForumsRead40=40%7c2%2f4%2f2012+9%3a02%3a40+PM; IF_ForumsRead56=56%7c2%2f4%2f2012+9%3a11%3a22+PM; IF_TopicsRead3165=3165%7c2%2f4%2f2012+9%3a11%3a22+PM; IF_ForumsRead43=43%7c2%2f4%2f2012+9%3a14%3a56+PM; IF_ForumsRead50=50%7c2%2f4%2f2012+9%3a15%3a23+PM; IF_ForumsRead41=41%7c2%2f4%2f2012+9%3a15%3a45+PM; IF_ForumsRead55=55%7c2%2f4%2f2012+9%3a16%3a12+PM
    HTTP_HOST                     forums.flexradio.com
    HTTP_USER_AGENT               CCBot/1.0 (+http://www.commoncrawl.org/bot.html)
    HTTP_X_CC_ID                  ccc03-02
